    Manor house with early mist
    31 Posts 17 Posters 3.5k Views 17 Watching
      Check the post processing forum for some great tutorials
        davidh
        A view from the other side
        • Bob JamesB Offline
          Bob James
          Incredible job with the water!! Wind rustled area and trail of the swimming bird πŸŽ‰ How did you do that?
          Excellent ground cover variation.
          • ely862meE Offline
            ely862me
            Bravoo!! Love it !
            Elisei (sketchupper)
            Come and See EliseiDesign
              davidh
              2 more from the lake side.The night shot is the daytime shot taken thru the step by step process I recently uploaded to the post-processing forum.The lights were painted in and copied around.
                davidh
                As its the festive season,Ive added some Christmas lights to the night scene.
                  davidh
                  Theres no such thing as too many lights...
                  • irwanwrI Offline
                    irwanwr
                    πŸ‘ πŸ‘ πŸ‘
                      mwm5053
                      Wow incredible
                      2011 iMac
                      SU 2015 Pro, 2017 Make
                      V2 Twilight
                      macOS Sierra 10.12.5
                        davidh
                        An un-cropped image with the full set of lights except the foreground ones which looked a little too clunky.
                          davidh
                          2 very different colour values for these 2 images.My preference is for the purple sky over the blue.I always find that blue skies are much harsher whereas soft evening light can create a mood much,much easier.
                          • soloS Offline
                            David,
                            Your skills are phenomenal in PS, I'm envious.
                            What I'd like to see is a wintery christmas scene, night time, lights, frozen stream, snow, etc.
                            A Christmas card
                            • marked001M Offline
                              marked001
                              the christmas lights are great... so funny.
                              where do you get the material for your images?
                              http://www.revision21vis.com
                              instagram: revi21on
                                davidh
                                Again,thanks for the comments guys.The materials are a mix of purchased entourage from places such as DOSCH.Some are elements rendered out of Sketchup and saved with an alpha channel, and some straight from photos,manipulated in photoshop.
                                I get my inspiration from everywhere,true life,magazines etc.But I am always looking out for something different..
                                The photo below is an example of the picture I will look at before starting a night shot.It has blues,yellows and oranges,all 3 of which I would try and envoke.
                                Often I will blur the image so I can more easily see the colour values/tones and their relationship.I used to do a lot of painting and one of the tips I learned early on was to squint at the picture because the detail becomes secondary and its easier to see the colour relationships.
                                • N Offline
                                  nomeradona
                                  now i dont know if these are artwork by themselves or architectural visulization.. maybe they are both.
                                  you are now setting a name for your self with your excellent post processing skills. excellent attention to details.
                                    jsmith
                                    Truly outstanding and inspirational work you do, you are a photoshop master! Thanks for the time you put into the post processing tutorials you do. I am moved by the moods shown in your renders.
                                      davidh
                                      A clear winters morning.This iamge has a slightly looser feel with a lot of entourage elements overlayed and running into each other.
                                      • irwanwrI Offline
                                        irwanwr
                                        that is VERY beautiful πŸ‘
                                        if you don't mind. where is the source of those trees reflection comes from?
                                        since i don't see immediate source above view point if that was mirrored.
                                          davidh
                                          There were actually 2 layers inadvertently turned off before I saved as a .jpg.The first one missing was the foreground tree casting the reflection at the front of the stream,the second is the trees you are referring to.
                                          They are quite faint but I used artistic licence and reduced the opacity so they wouldn,t obscure the house.The reflection is much stronger though because the trees would in real life have a stronger value against the lighter blue of the water.
                                          The foreground tree reflection dosent match up exactly withe the actual tree,but in my opinion,it is not a problem. Ideally the foreground tree should be closer to the actual waters edge,but again,this would have obscured both the house and the larger darker tree behind.
                                          Its really all about what feels right,rather than what is right.
                                          • stefanqS Offline
                                            stefanq
                                            I just want to say thank you. Because of you, I searched my old PS book(for CS 3) and start reading again. Hopefully, I'll have more free time during this holiday, to really dive in.
                                            Regards,
                                            Stefan
