    Manor house with early mist
    31 Posts 17 Posters 4.0k Views 17 Watching
    • ely862meE Offline
      ely862me
      Bravoo!! Love it !
      Elisei (sketchupper)
      Come and See EliseiDesign
        davidh
        2 more from the lake side.The night shot is the daytime shot taken thru the step by step process I recently uploaded to the post-processing forum.The lights were painted in and copied around.
          davidh
          As its the festive season,Ive added some Christmas lights to the night scene.
            davidh
            Theres no such thing as too many lights...
            • irwanwrI Offline
              irwanwr
              πŸ‘ πŸ‘ πŸ‘
                mwm5053
                Wow incredible
                2011 iMac
                SU 2015 Pro, 2017 Make
                V2 Twilight
                macOS Sierra 10.12.5
                  davidh
                  An un-cropped image with the full set of lights except the foreground ones which looked a little too clunky.
                    davidh
                    2 very different colour values for these 2 images.My preference is for the purple sky over the blue.I always find that blue skies are much harsher whereas soft evening light can create a mood much,much easier.
                    • soloS Offline
                      David,
                      Your skills are phenomenal in PS, I'm envious.
                      What I'd like to see is a wintery christmas scene, night time, lights, frozen stream, snow, etc.
                      A Christmas card
                      • marked001M Offline
                        marked001
                        the christmas lights are great... so funny.
                        where do you get the material for your images?
                        http://www.revision21vis.com
                        instagram: revi21on
                          davidh
                          Again,thanks for the comments guys.The materials are a mix of purchased entourage from places such as DOSCH.Some are elements rendered out of Sketchup and saved with an alpha channel, and some straight from photos,manipulated in photoshop.
                          I get my inspiration from everywhere,true life,magazines etc.But I am always looking out for something different..
                          The photo below is an example of the picture I will look at before starting a night shot.It has blues,yellows and oranges,all 3 of which I would try and envoke.
                          Often I will blur the image so I can more easily see the colour values/tones and their relationship.I used to do a lot of painting and one of the tips I learned early on was to squint at the picture because the detail becomes secondary and its easier to see the colour relationships.
                          • N Offline
                            nomeradona
                            now i dont know if these are artwork by themselves or architectural visulization.. maybe they are both.
                            you are now setting a name for your self with your excellent post processing skills. excellent attention to details.
                              jsmith
                              Truly outstanding and inspirational work you do, you are a photoshop master! Thanks for the time you put into the post processing tutorials you do. I am moved by the moods shown in your renders.
                                davidh
                                A clear winters morning.This iamge has a slightly looser feel with a lot of entourage elements overlayed and running into each other.
                                • irwanwrI Offline
                                  irwanwr
                                  that is VERY beautiful πŸ‘
                                  if you don't mind. where is the source of those trees reflection comes from?
                                  since i don't see immediate source above view point if that was mirrored.
                                    davidh
                                    There were actually 2 layers inadvertently turned off before I saved as a .jpg.The first one missing was the foreground tree casting the reflection at the front of the stream,the second is the trees you are referring to.
                                    They are quite faint but I used artistic licence and reduced the opacity so they wouldn,t obscure the house.The reflection is much stronger though because the trees would in real life have a stronger value against the lighter blue of the water.
                                    The foreground tree reflection dosent match up exactly withe the actual tree,but in my opinion,it is not a problem. Ideally the foreground tree should be closer to the actual waters edge,but again,this would have obscured both the house and the larger darker tree behind.
                                    Its really all about what feels right,rather than what is right.
                                    • stefanqS Offline
                                      stefanq
                                      I just want to say thank you. Because of you, I searched my old PS book(for CS 3) and start reading again. Hopefully, I'll have more free time during this holiday, to really dive in.
                                      Regards,
                                      Stefan
                                        davidh
                                        This is probably the last image in this manor house series.I'm working on a few new projects at the moment and hope to upload something in the new year.
                                        We're actually quite busy with "real" work at the moment but I always try and spend half an hour each day trying new effects.Some images work better than others and some dont work at all,but its actually quite relaxing creating the scenes.
                                        • irwanwrI Offline
                                          irwanwr
                                          πŸ‘ beautiful
                                          • 2 / 2
