    Spanning between two points with an object.
    6 Posts 5 Posters 748 Views 5 Watching
      kb18951452
      I've been looking for a plugin, or something that would allow the following functionality.
      Works like the line tool Click first point, click second point, get a line.
      The change is, When click the second point, instead of a line, it spans a shape, or object between the two points. I have a joint (Puzzle Joint i want to place between to points all over my model)
      The main benefit would be that the object be properly aligned between the two points. If it doesnt stretch between them, thats fine. Infact, what would be preferred would be that the object be palces exactly halfway between the two points and oriented to be aligned with both points. Has anyone heard of such a tool? Where might i find it? I'm finding it hard to describe what i am looking for and maybe, if it exists, thats why i can't find it.
      Thanks,
      Kenneth
        Hi Kenneth,
        I think TIG's Free Rotate tool is the closest to what you are looking for:
        http://forums.sketchucation.com/viewtopic.php?t=30380
        It won't stretch or even align in the middle but at least you are half way there.
        • jeff hammondJ Offline
          use the Align tool in 1001bit
          http://www.1001bit.com/v1.1/download_registration_v1.1.shtml
          [30 day trial to see if you're feeling it]
          [after you get it into position and depending on how your axis is set up in the original component, you can use and to center or stretch etc.]
          • Jean LemireJ Offline
            Jean Lemire
            Hi folks.
            If you create a line between the two points, you can snap components to its midpoint. After that, align with whatever tool or plugin you want, rotating along this midpoint.
            Delete the line.
            Repeat for each instance.
            Just ideas
              kb18951452
              Has a tool come out in the past year or so that would do this? I find myself wishing to no end that the tool existed. I would love a tool that worked just like the line tool, with the exception being that at the midpoint, a custom shape was inseted midway between the end points, and alined with them aswell.
              • sdmitchS Offline
                sdmitch
                You can try my Add&Align Component plugin. You can find it on my blog.
                http://sdmitch.blogspot.com/
