    Problem with color
    14 Posts 4 Posters 788 Views 4 Watching
      Chris88
      Hi all,
      i need some help on a specific problem,
      when i start sketchup with my code by loading my script from the plugin folder or with the command "-Rubystartup" in the cmd, the cuboid will be drawn, but not colored.
      What i'm doing wrong?
      ` require 'sketchup.rb'
      def create_box
      model = Sketchup.active_model
      model.start_operation $exStrings.GetString("Create Box")
      entities = model.active_entities
      group = entities.add_group
      entitites = group.entities
      width = 70 # 70
      depth = 60 # 60
      height = 25 # 25
      color = Sketchup::Color.new(255,240,187)
      pts = []
      pts[0] = [0, 0, 0]
      pts[1] = [width, 0, 0]
      pts[2] = [width, depth, 0]
      pts[3] = [0, depth, 0]
      base = entities.add_face pts
      height = -height
      area = base.area
      base.material = color
      base.back_material = color
      base.pushpull(height)
      model.commit_operation
      create_box`
      Thanks for help.
      P.S. when i execute my script(the same code) in RDE with the Sketchup-Bridge, the color is drawn.
      • Dan RathbunD Offline
        Dan Rathbun
        SIMPLE
        Your ignoring what I told you to do before (in previous posts.)
        ALL YOUR code should be wrapped within your 'author' namespace ( module Chris88, or whatever is unique to you,) to protect it from other code.
        If the Examples are loading after your code, Examples/box.rb will redefine Object.create_box(), and if the Tools/make_pano_pm.rb is also loading, it will again redefine Object.create_box().
        Both of these Google supplied scripts, are examples of POORLY written code.
        I'm not here much anymore.
          Apart from sloppy coding you are muddling up 'color' and 'material'.
          You make a color and then try to assign it to a face as if it were a material - that won't work
          Make a material.
          Give that material a color.
          Add the material to the face.
          mat=model.materials.add("MyLovelyMaterial") mat.color=[255,240,187] face.material=mat
          etc etc
            Chris88
            @ Dan:
            well unfortunately this doesn't help,
            i have only one file with the aforementioned code.
            And if i wrapped it in a namespace, the problem isn't fixed. The cuboid is drawn colorlessly. Only the sketchup-bridge in RDE draw it with color, but it should do that from the plungins folder.
              @chris88 said:
              @ Dan:
              Maybe you can't create geometry like that immediacy as SU starts?
              What happens if you call your command from the Ruby Console, or activate it from a menu? Just a thought since your file calls your method as it loads with SU - maybe SU isn't ready.
                You are wrongly applying a color as if it were a material, if you'd reread my post!
                On the question of it not working at startup why not add a test loop at the very start of your def, along the lines of
                unless Sketchup.active_model;until Sketchup.active_model.active_entities;end;end
                so it waits until there IS an active entities object to add geometry to ???
                  That that doesn't block the processing queue? ❓
                    Haven't tried it...
                    He could also try a timer to kick in after a few seconds from loading the code ?
                      Maybe.
                      But maybe there's another way around this...
                      I think we need to step back and figure out the purpose of this exercise, and not get caught up in an issue that could be a non-issue if there are better alternatives.
                      Why is the method called upon startup? Is it to perform testing? Do you (Chris88) restart SU when you change your code?
                      If you do - then there is an alternative. Just type into the Ruby Console: load 'myrubyfile.rb' to reload the code without restarting SU.
                        Dan Rathbun
                        @chris88 said:
                        @ Dan: well unfortunately this doesn't help,
                        Sorry.. wrong issue. I saw create_box() and assumed.. shame on me. 😳
                        Quitting smoking and working on the dirty underside of my car males me grumpy, but I should not have "snipped" at you. My apologies.
                        True.. but you still need to write code in your own namespace.
                        I have only one file with the aforementioned code.
                        Google installs the other two files.. which conflict with each other.
                        You would best chose another method name, if your going to define that method in the global Objectspace.
                          Chris88
                          Sorry i wasn't online the last days.
                          First of all thanks for your suggestions.
                          I don't prefer the method with the timer, because i have to close and
                          open SU many times in a row. But i like the method "load rubyscript.rb"
                          i will test it.
                          And thanks to TIG, your help me a lot.
                          @Dan It's ok 😉
                            Chris88
                            This unless Sketchup.active_model;until Sketchup.active_model.active_entities;end;end
                            and this load 'myrubyfile.rb' are the solutions for my problem, well it's really so,
                            that SU isn't ready to load the color.
                            Thanks again.
                            Can anyone say how to make the material transparent, please?
                              http://code.google.com/apis/sketchup/docs/ourdoc/material.html#alpha=
                              Note that the Material object doesn't use the alpha channel of the Color object.
                              <span class="syntaxdefault">m </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxstring">'MyMaterial'</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">m</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">color </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxdefault">255</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">128</span><span class="syntaxkeyword">,</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">m</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">alpha </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> 0.5<br /></span>
                                Chris88
                                Great!
                                Thank you, i like this forum more and more.
                                Merry Christmas and happy holidays to all!
