    Prompt windows too small
    19 Posts 6 Posters 1.8k Views 6 Watching
    • gillesG Offline
      gilles
      i'm not going to learn the stuff though! maybe you will?
      I have tried ( a little) but it is really not for me.
      May be I should make a request to mac coders.
      • Didier BurD Offline
        Didier Bur
        i think the problem is with Safari
        I don't think so. This is not a WebDialog, but the usual inputbox Ruby method. No options or parameters in this method related to the OS.
        I'm a bit confused, this is the first time a mac user reports this behavior of the dialog, while a bunch of them are using the plugin since a year or so...
        DB
          driven
          This particular one is Google fixable, it happens because the Input Boxes are a set width, not like the Web Dialogs that can be author/user adjusted. it even happens with the example on the API
          Name, Age, Gender,Address???who+knows
           # With four params, it shows a drop down box for prompts that have
           # pipe-delimited lists of options. In this case, the Gender prompt
           # is a drop down instead of a text box.
           prompts = ["What is your Name?", "What is your Age?", "Gender"]
           defaults = ["Enter name", "", "Male"]
           list = ["", "", "Male|Female"]
           input = UI.inputbox prompts, defaults, list, "Tell me about yourself."
          The Nib doesn't auto resize, so the only work around is to not exceed the 12 characters including space.
          e.g.edited 'input box'
           prompts = ["Full Name?", "Age?", "Gender"]
           defaults = ["Enter name", "in years", "Male"]
          have I bored you enough, yet
          • gillesG Offline
            gilles
            Dear Didier, don't be confuse I show one of your plugins but there are other from other coders with the same issue.
            So I don't know where to dig.
            It is not that important.
            I use and try lots of plugins to work and I'm grateful to you all making such efforts.
            " à cheval donné,on ne regarde pas les dents." 👍
            • jeff hammondJ Offline
              thanks for the lesson john..
              and didier for pointing out that this isn't a web dialog 😳
              i think i might change my sig to:
              if i ever type anything about ruby, please ignore it 😄
                driven
                @gilles said:
                I though I could just change some lines in Ruby and tada!
                I should have clarified that I just changed the words found at prompts = ["", "", ""]
                that's all you need to do in the scripts... john
                • gillesG Offline
                  gilles
                  @ driven, thanks for clarification, I'll try this.
                  When you know why it's half of the problem to be solved.
                  As we say here " s'il n'y a pa de solution c'est qu'il n'y a pas de problème".
                  " If there is no solution , there is no problem."
                    driven
                    Say that in 12 characters... cheers
                    • gillesG Offline
                      gilles
                      • gillesG Offline
                        gilles
                        In this case, no chance to change anything the file is scrambled.
                          Didier Bur
                          The solution would be that I recode it for Mac 🎉
                          I've often used a trick to give prompts more "place" in the dialog, for instance:
                          prompt=["What is your family name:"] becomes prompt=["What is your family name:..............."] (.=space)
                          Inserting spaces in the values dropdown list items should do the trick, too.
                          @gilles: Here is the modified RBS (I guess you have the french version 😉 )
                          If it works OK on Mac I'll publish a Mac version.
                          -> dézippes dans ton sous-dossier "Projection" et écrase le fichier "fr_projection.rbs" précédent. Relances SU et croise les doigts... Tiens-moi au courant.
                          fr_projection_gilles.zip
                          DB
                          • gillesG Offline
                            gilles
                            It works fine.
                            Thank you Didier. 👍
                            Edit: same issue with lines to tubes. 😳
