    [Plugin] bim-tools 0.13.4(june 22, 2015)
    206 Posts 37 Posters 247.3k Views 37 Watching
    • brewskyB Offline
      brewsky
      I think need change this name bim-tools to skp2ifc ,BIM is very very big !
      I know the scope of a project like this is huge, and probably way to much for one person in his spare time.
      It depends on the interpretation of the term "BIM", but IFC alone(and all the necessary tools for defining the objects) is probably equally big...
      If anyone has some spare time they are welcome to help out πŸ˜„.
      The IFC export is an important part of the project, but not it's only purpose.
      I would like a designer to be able to assign building properties to faces of a simple building model. Just by way of: "click side-face" = "wall", "click top-face" = "roof".
      Every face with an "IFC-label" can be exported to IFC, and then be re-used in a "real" BIM-model.
      Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
      • brewskyB Offline
        brewsky
        It's getting real fun now!
        demo image of current wall opening options
        I have improved the walls, so that a component with the options "glue" and "cut opening" will cut a hole through the wall just like it would in a simple face!
        I still have to figure out how to best link the hole with the cutting component, so they move together... and add IFC data so I can update the exporter...
        • jolranJ Offline
          jolran
          Looks exiting!
          • utilerU Offline
            utiler
            WOW....! I have been following this thread since it began and am all of a sudden getting excited!!!!!
            Well done, Brewsky!
            Just Curious...
            • brewskyB Offline
              brewsky
              Thanks! πŸ˜„
              Here is the first demo version with wall-openings:
              BIM Tools for SketchUp - demo wall opening
              It cuts openings, AND you can copy and move them around on the wall!
              How to use:
              • draw some lines and select them
              • open bim-tools plugin
              • open "create" menu
              • click "walls from selection"
              • create a new component with the options "Glue to": Any or Vertical, "Cut opening". And make sure you draw a face or closed profile on the X/Y plane, just like any cutting component.
              • Glue the component to the side of the wall
              • Now it should cut a hole in the wall in the shape of the outer profile(s).
              Best use a nested group/component if you don't want geometry other than the profile interfering with the hole.
              Known bugs/limitations:
              • It's still slow with complex wall openings
              • you can still move opening geometry outside of wall
              • moving multiple openings together will only cut 1 hole
                Please let me know if you find more...
              The IFC exporter does not yet include the wall openings.
                Jim
                Hi Jan,
                Thanks for the update. Would you put the download in the first post of this topic, and update the Subject: to reflect the new version and/or date? Having the download in the first post makes it easier for everyone to find the download. Updating the Subject: allows the plugin to appear in the "Recent Updates" section of the Plugins Index. Thanks.
                • brewskyB Offline
                  brewsky
                  Hi Jim,
                  Thanks for your help! I'm still a bit of a newbie on the forum πŸ˜„
                  I had no idea the plugins list was generated from the topic-subjects!
                  The reason I didn't post the download in the first post is that the exporter is not fully functional, but I realise now that in this way it's not easy to find the latest version...
                  I'll update to the first post!
                    johnnygitarr
                    hi,
                    i've got a installation error
                    (see attachment)
                    bim-tools.rb and bim-tools folder is in the plugins folder from sketchup
                    i use sketch up pro 8 version 8.0.11751
                    os lion 10.7.2
                    anyone a solution for this problem?
                    greetings
                    tobi
                      driven
                      require 'bim-tools\ObjectLibrary.rb' require 'bim-tools\parts\opening.rb'
                      will not run on mac...
                      open the ruby file and change those to require 'bim-tools/ObjectLibrary.rb' require 'bim-tools/parts/opening.rb'
                      back slashes in the path don't work, when you've done that, Change any others and then see what errors come next, and fix or post those...
                      or report success...
                      • bigstickB Offline
                        bigstick
                        Epic work Jan! I think we actually only need a few IFC compliant object types to get basic interoperability with the major BIM apps.
                        Walls and openings are of course the most important, but when we have floors and roofs as well, I suspect most of the work will have been done.
                        When it's working on the Mac, I'll definitely try it out - excellent!
                        • fionmacoolF Offline
                          fionmacool
                          Wow! BIM in Sketchup.... I have to try this! Merci.
                          Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                          • pbacotP Offline
                            "...in ZEE sketch-UP"
                              d_e_x
                              @brewsky said:
                              @dan rathbun said:
                              they were working on an exporter at one time... it never was released as far as I can tell.
                              http://ifc2skpforum.websitetoolbox.com/post?id=2515651
                              An exporter won't be as simple as an importer I guess. Somehow you need to add "building properties" to the "empty" SketchUp geometry.
                              That's exactly what I want to do, not try to re-build revit/archicad in sketchup, but create simple building elements that can be translated/labeled to meaningful objects, which could be re-used(via IFC) in CAD systems.
                              • faces can be given thickness and labeled "wall", "floor" or "roof"
                              • edges can be used as paths for profiles(like my current plugin) and labeled "wall", "floor" or "beam"
                              OMG! great minds think alike πŸ˜„
                              I have been working on the same exact thing for the past few months! I call it SketchUpBIM. Finally, found some courage yesterday to post it on sketchucation. It provides simple tools to create building elements like walls, floors, slabs etc. in SketchUp. Hopefully soon.. these will go out as IFC; and hopefully u can help me with this πŸ˜‰
                              check it out: http://forums.sketchucation.com/viewtopic.php?f=323&t=41840. It might come in handy at your work. other BIM experts, please also feel free to comment!
                              Dex
                              • brewskyB Offline
                                brewsky
                                Hi Tobi,
                                I'm sorry, I didn't see your post until now. I'm reading all over the forum, and missing this 😳 . Somehow I got unsubscribed from the thread...
                                I will look into the problem, as John says, it probably has to do with the backslashes.
                                Does anyone have tips on how to best implement the (back)slashes in file-paths cross-platform?
                                I've tried a few different things, but don't now what's best...
                                Cheers,
                                Jan
                                • brewskyB Offline
                                  brewsky
                                  @didier bur said:
                                  Just a side note: to install, create a folder "bimtools" in the Plugins folder, and put the html file in it.
                                  Hi Didier! Thanks for the explanation. I forgot to mention how to install and use it.
                                  Here some additional info:
                                  • The plugin creates a "BIM Tools" option in the plugins menu.
                                  • When you select this, a webdialog appears with options(wall-width and wall-height).
                                  • Select some edges(they must be horizontal) and click the button in the dialog, it will generate a wall section on every edge with the given width and height.
                                  It nicely fixes the corners of all connecting edges, except for walls with different widths/heights and for very short edges.
                                  I was browsing the forum today and noticed that Thomthom's street generator uses a similar principle. the biggest difference seems to be that my walls are separate objects and the streets are nicely glued together(and have a lot more options).
                                  • brewskyB Offline
                                    brewsky
                                    Hi Toby!
                                    I just posted a new version(0.9.2), I hope it runs on mac! (sorry can't test it myself).
                                    I removed all backslashes from filepaths as John sugested.
                                    Cheers!
                                    Jan
                                    • Dan RathbunD Offline
                                      Dan Rathbun
                                      somepath = %q[a/path\to/some\sub\directory] somepath = File.expand_path(somepath)
                                      I'm not here much anymore.
                                        fionmacool
                                        Sorry, I can't get this to work on Mac.... bummer.
                                        I had to edit the objectlibrary.rb file to insert "/btobjects.rb" instead of "\btobjects.rb", and this allowed the plugin to load without an error. However, all I got was a dialogue that didn't seem to work. Did I miss anything? Check out the image below.
                                        https://lh3.googleusercontent.com/-lFsCqo1K1aQ/T0OazTGGB0I/AAAAAAAAAbk/vWtbEVPI894/s800/Screen%2520shot%25202012-02-21%2520at%252013.02.35.png
                                          All paths in Ruby should use forward slashes - this to ensure cross platform functionality.
                                          • brewskyB Offline
                                            brewsky
                                            Too bad I can't test it myself, the dialog is a webdialog, only tested on internet explorer.
                                            I can however download safari for PC to test the javascript/html, I'll look into that.
                                            During the past months I have re-written my bim-tools plugin from scratch, I think the new concept is a very solid foundation for expanding it into a great BIM-modeller in the SketchUp way of modelling.(I also simplified the dialog, hope it works on mac out of the box...)
                                            The latest code is on google-code: http://code.google.com/p/bim-tools/
                                            I'm currently hunting for bugs, brave people can give it a try πŸ˜‰ , preview added to the post.
                                            At this moment there is a toolbar with 3 buttons:
                                            • The first opens the webdialog with options for BIM elements.
                                            • the second cobnverts selected faces into "BIM objects"
                                            • the third, switches the display between the original "source faces," and generated "BIM" geometry.
                                              The contents of the webdialog adapts to the selected BIM elements(will go wrong once in a while). BIM elements will transform with the source faces...
                                            It is still very easy to screw up the model, for example:
                                            • scaling faces
                                            • "Splitting" of faces
                                            • simultaneously change "name" or "description" for several elements at once.
                                            • each edge can only have two faces
                                            • also connecting faces on the same plane still give an error message.
                                            The project is getting much fun!!! πŸ˜„
                                            Preview, not ready for real use!
                                            • 11
                                            • 3 / 11
