    Mirror object
    13 Posts 6 Posters 907 Views 6 Watching
    • Alan FraserA
      Alan Fraser
      It would be far simpler to use Rotate/Copy.
      Select the arrow then orbit so that you are looking down on it. Choose the Rotate tool, place the rotate cursor on the ground so that it turns blue, then lock it in that position by holding down Shift.
      Move the cursor to the point of the arrow indicated by your smaller drawn arrow and click once on your mouse.
      Press Ctrl once to get a small plus sign next to the cursor (indicating a copy rather than rotation of the original) then click another twice 90Β° apart...preferably on axis so you get a precise 90Β° inference.
      It sound complex the first time, but is very straightforward and takes about two seconds to complete.
      3D Figures
        d12dozr
        Use a temporary guideline, then with the mirror tool, click on the numbers in order
        Click for full size...
        http://goo.gl/f7ooYh
          d12dozr
          The guideline is on the ground plane...kinda hard to tell from my picture. I've attached the SKP so you can try it.
          ...Alan is right of course, but I wanted to show this because in other cases the mirror tool may be easier.
          Mirror Arrow.skp
            suSteve
            thank you d12dozr. Your skp works fine (of course) so now I can see where I am going wrong.
            [Alan your signature reminds me that I proposed to my wife at Formby point many years ago.]
            Still unsure what the two lines do when you draw them after clicking a start point with the mirror tool selected. I have played around with it for ages but can't seem to work out the rules of it.
            thanks again (much appreciated)
            • jeff hammondJ
              the lines define the plane of the mirror.. literally, think of putting a real mirror in your sketchup drawing.. the first line of the mirror plugin tells where to put the bottom (for all intents and purposes of this visual) edge of the mirror and the second line represents the adjacent edge..
                suSteve
                thanks Jeff, playing around with it again after seeing d12dozr's skp revelation and now I can see how it works. Thinking about it like a real mirror helps me visualise it better - thank you
                • Alan FraserA
                  Alan Fraser
                  You wouldn't have wanted to repeat that today, Steve. I took the pooch for a walk on the beach this morning...bloody freezing and blowing a gale. πŸ˜„.
                  3D Figures
                  • Jean LemireJ
                    Jean Lemire
                    Hi Folks.
                    See attached SU file for ideas.
                    Mirror along any plane.skp
                    • pbacotP
                      Jean,
                      In your second example (scene 5) how do you set the rotation using the guide line?
                      Peter
                      • Jean LemireJ
                        Jean Lemire
                        Hi Peter, hi folks.
                        See this page in SketchUp help:
                        Error 404 (Not Found)!!1
                        (support.google.com)
                        Just ideas.
                        • pbacotP
                          @jean lemire said:
                          Hi Peter, hi folks.
                          Just ideas.
                          Doh! πŸ‘Š Thanks Jean. I am sure I've done that before but left the method unused for too long.
                          Peter
