    Square Carnival Tent
    27 Posts 7 Posters 4.8k Views 7 Watching
    • charly2008C Offline
      charly2008
      as David correctly said there are thousand paths. Here with the standard tool "Follow Me".
      Charly
      • david_hD Offline
        david_h
        Wow. . .the follow me tool! Who'da thought?
        Here's a D'uh Moment! πŸ’š
        • irwanwrI Offline
          irwanwr
          thank you all for those quick responses πŸ˜„ i am sorry i just got online tonight though.
          i did looking for suitable tools. tried Extrude Tools too, each one of them and not succesful 😐
          when i saw the Beta Curvy Loft post and see that skinning β˜€ , i thought i'd give it another try and it works. it's a miracle for me.
          i did make some basic figures for it before i read these replies.
          just like what Gaieus and especially David_H posted. and exactly like the one charly2008 showed.
          thank you very much to all.
          love this community forum πŸ˜„
          PS: i've tried Extrude Tools over and again. but i think i still don't understand how it works.
          Curvy Loft Skinning works fast with only making frame of edges (2 quarter of circles) and a click.
          • irwanwrI Offline
            irwanwr
            I made a quickie. I made 1 side of the roof using TIGs Extrusion by Loft tool. And then just did rotate array to do the other 3 sides. Probably a million ways to do this. Good luck.
            i have tried that one too. with no luck. still don't understand how it works. i've read and tried to learn the post on Extrude Tools many times, trying to figure how it works.
            • irwanwrI Offline
              irwanwr
              @alan fraser said:
              The sequence actually shows how to make a square tent, not a round one...but the sequence is exactly the same.
              i have some questions on the scenes. how to:
              1. copy the curve?
              2. "stitch" the nodes?
              3. copy the 1st face to adjacent sides?
              • irwanwrI Offline
                irwanwr
                yes, it didn't come across my mind πŸ˜› especially because the base is square.
                thank you.
                • Jean LemireJ Offline
                  Jean Lemire
                  Hi folks.
                  See this SU file for ideas.
                  Carnival tent.skp
                  • irwanwrI Offline
                    irwanwr
                    @jean lemire said:
                    Hi folks.
                    πŸ‘ another "follow me". thank you.
                    • irwanwrI Offline
                      irwanwr
                      i didn't succeed using follow me tool either.
                      this is what i made using curvy loft.
                      http://i278.photobucket.com/albums/kk102/irwanwr/SketchUp/CarnivalSquareTent.jpg
                      i don't know how to attach the skp file yet.
                        You must learn follow me. Always learn to walk before run. The tent looks good however. πŸ‘
                        See below...
                        • irwanwrI Offline
                          irwanwr
                          thank you. i'll learn the tool again.
                          actually, in the first place i was looking for a plugin that able to make the physic looks on the tent cover surface. the tent cover should have straight diagonal frame. but the surface in the middle of each side should be a bit lower. i need to learn and practice more sketchup i guess. thank you again Gaieus.
                          carnival square tent as component
                          • Alan FraserA Offline
                            Alan Fraser
                            Ah! more like a party gazebo. I wouldn't bother making the fabric sag in the middle of the sides (although it would sag in the middle of the roof ridges, as youve already done)...but I would round some of the edges a little. After all, the fabric will roll gently over the poles, not form razor sharp creases.
                            http://www.formfonts.com/requestFile.php?type=1&id=3731&img=1_gazebo_canvas.jpg
                            3D Figures
                            • irwanwrI Offline
                              irwanwr
                              yes, thank you for reminding me about the round corner πŸ˜„ nice tent design and image by the way πŸ‘
                                Jean Lemire
                                Hi Irwan, hi folks.
                                The Follow me tool needs two things:
                                1 - A facethat will follow a path.
                                2 - A paththat the face will follow.
                                A faceis any closed flat shape delimited by connected edges and is coplanar (of course since it is flat).
                                A pathis made of any number of connected edges.
                                Another important thing is that the facemust be perpendicular to the first edge of the path. If the faceis not perpendicular to the first segment of the path, the facewill be projected on a plane perpendicular to the first segment of the path. This will cause a scaling which may prove detrimental to the wanted result.
                                The Follow me tool works in two ways.
                                1 - Manual follow
                                1.1 - Click on the Follow me tool to select it
                                1.2 - Click on the face.
                                1.3 - Follow the pathsegment per segment.
                                1.4 - Click to finish when the face is at the end of the last segment of the path.
                                2 - Automatic follow
                                2.1 - Select the whole path. Use whatever selection method you want.
                                2.2 - Select the Follow me tool. The pathwill get deselected, don't bother.
                                2.3 - Click once on the face.
                                This last method is very efficient and super quick to lathean object around a circle, for example.
                                In the example shown in my previous file, I use the perimeter of the horizontal square as the pathand the vertical shape as a faceand I latheit around the square path.
                                Don't worry if you select a pathwith a double click on a face enclosed by this path. Only the perimeter will be used by the Follow me tool.
                                Just ideas.
                                • irwanwrI Offline
                                  irwanwr
                                  Jean Lemire
                                  thank you, for step by step instruction provided.
                                  • irwanwrI Offline
                                    irwanwr
                                    here's my homework on Follow Me tool (thank you Jean and all others).
                                    http://i278.photobucket.com/albums/kk102/irwanwr/SketchUp/SquareCarnivalTents.jpg
                                    the second on the left have significant larger size than the earlier. is it probably because there are more geometry on the tent cover after using Round Corner plugin?
                                    Square Carnival Tent.skp
                                    • irwanwrI Offline
                                      irwanwr
                                      @alan fraser said:
                                      ... I would round some of the edges a little. After all, the fabric will roll gently over the poles, not form razor sharp creases.
                                      if you don't mind, i'd like to know how to make those round edges as smooth as the image above?
                                        Unless Alan really rounded them (adding geometry) which I doubt as he likes to keep his models low poly, simply use the Erasertool while holding down the Ctrlkey to soften edges. Very sharp edges do not look nice when softened but for a shallow roof like that, they may not be too sharp.
                                          Alan Fraser
                                          Actually, I did add geometry...but Gaius is right, I do like low polygon counts, so I only used 3 segments to the curve.
                                          Find the Round Corners ruby script by Fredo. It gives you 3 options...round corners, sharp corners and bevel edges. Select the top of the tent, plus the four corners that hang down and choose the round corners option. You'll see a dialog appear at the top of the drawing window...and also the same parameters in the VCB (Measurements box)...the spread of the curve followed by the number of segments, separated by a comma. Retype your own parameters...these would be something like 1" or 2cm and 3 segments. Press Enter, see if the preview lines look ok on your model then use the tick on the end of the cursor to accept them.
                                          3D Figures
                                            Okay, so my eyes did not deceive me (it indeed looks like something is added there but the image was not too large to precisely see)
