    Square Carnival Tent
    27 Posts 7 Posters 5.3k Views 7 Watching
    • david_hD
      david_h
      I made a quickie. I made 1 side of the roof using TIGs Extrusion by Loft tool. And then just did rotate array to do the other 3 sides. Probably a million ways to do this. Good luck.
      square tent.skp
      • charly2008C
        charly2008
        as David correctly said there are thousand paths. Here with the standard tool "Follow Me".
        Charly
        • david_hD
          david_h
          Wow. . .the follow me tool! Who'da thought?
          Here's a D'uh Moment! πŸ’š
          • irwanwrI
            irwanwr
            thank you all for those quick responses πŸ˜„ i am sorry i just got online tonight though.
            i did looking for suitable tools. tried Extrude Tools too, each one of them and not succesful 😐
            when i saw the Beta Curvy Loft post and see that skinning β˜€ , i thought i'd give it another try and it works. it's a miracle for me.
            i did make some basic figures for it before i read these replies.
            just like what Gaieus and especially David_H posted. and exactly like the one charly2008 showed.
            thank you very much to all.
            love this community forum πŸ˜„
            PS: i've tried Extrude Tools over and again. but i think i still don't understand how it works.
            Curvy Loft Skinning works fast with only making frame of edges (2 quarter of circles) and a click.
            • irwanwrI
              irwanwr
              i have tried that one too. with no luck. still don't understand how it works. i've read and tried to learn the post on Extrude Tools many times, trying to figure how it works.
              • irwanwrI
                irwanwr
                @alan fraser said:
                The sequence actually shows how to make a square tent, not a round one...but the sequence is exactly the same.
                i have some questions on the scenes. how to:
                1. copy the curve?
                2. "stitch" the nodes?
                3. copy the 1st face to adjacent sides?
                • irwanwrI
                  irwanwr
                  yes, it didn't come across my mind πŸ˜› especially because the base is square.
                  thank you.
                  • Jean LemireJ
                    Jean Lemire
                    Hi folks.
                    See this SU file for ideas.
                    Carnival tent.skp
                    • irwanwrI
                      irwanwr
                      @jean lemire said:
                      Hi folks.
                      πŸ‘ another "follow me". thank you.
                      • irwanwrI
                        irwanwr
                        i didn't succeed using follow me tool either.
                        this is what i made using curvy loft.
                        http://i278.photobucket.com/albums/kk102/irwanwr/SketchUp/CarnivalSquareTent.jpg
                        i don't know how to attach the skp file yet.
                        • GaieusG
                          You must learn follow me. Always learn to walk before run. The tent looks good however. πŸ‘
                          See below...
                          • irwanwrI
                            irwanwr
                            thank you. i'll learn the tool again.
                            actually, in the first place i was looking for a plugin that able to make the physic looks on the tent cover surface. the tent cover should have straight diagonal frame. but the surface in the middle of each side should be a bit lower. i need to learn and practice more sketchup i guess. thank you again Gaieus.
                            carnival square tent as component
                            • Alan FraserA
                              Alan Fraser
                              Ah! more like a party gazebo. I wouldn't bother making the fabric sag in the middle of the sides (although it would sag in the middle of the roof ridges, as youve already done)...but I would round some of the edges a little. After all, the fabric will roll gently over the poles, not form razor sharp creases.
                              http://www.formfonts.com/requestFile.php?type=1&id=3731&img=1_gazebo_canvas.jpg
                              3D Figures
                              • irwanwrI
                                irwanwr
                                yes, thank you for reminding me about the round corner πŸ˜„ nice tent design and image by the way πŸ‘
                                • Jean LemireJ
                                  Jean Lemire
                                  Hi Irwan, hi folks.
                                  The Follow me tool needs two things:
                                  1 - A facethat will follow a path.
                                  2 - A paththat the face will follow.
                                  A faceis any closed flat shape delimited by connected edges and is coplanar (of course since it is flat).
                                  A pathis made of any number of connected edges.
                                  Another important thing is that the facemust be perpendicular to the first edge of the path. If the faceis not perpendicular to the first segment of the path, the facewill be projected on a plane perpendicular to the first segment of the path. This will cause a scaling which may prove detrimental to the wanted result.
                                  The Follow me tool works in two ways.
                                  1 - Manual follow
                                  1.1 - Click on the Follow me tool to select it
                                  1.2 - Click on the face.
                                  1.3 - Follow the pathsegment per segment.
                                  1.4 - Click to finish when the face is at the end of the last segment of the path.
                                  2 - Automatic follow
                                  2.1 - Select the whole path. Use whatever selection method you want.
                                  2.2 - Select the Follow me tool. The pathwill get deselected, don't bother.
                                  2.3 - Click once on the face.
                                  This last method is very efficient and super quick to lathean object around a circle, for example.
                                  In the example shown in my previous file, I use the perimeter of the horizontal square as the pathand the vertical shape as a faceand I latheit around the square path.
                                  Don't worry if you select a pathwith a double click on a face enclosed by this path. Only the perimeter will be used by the Follow me tool.
                                  Just ideas.
                                  • irwanwrI
                                    irwanwr
                                    Jean Lemire
                                    thank you, for step by step instruction provided.
                                    • irwanwrI
                                      irwanwr
                                      here's my homework on Follow Me tool (thank you Jean and all others).
                                      http://i278.photobucket.com/albums/kk102/irwanwr/SketchUp/SquareCarnivalTents.jpg
                                      the second on the left have significant larger size than the earlier. is it probably because there are more geometry on the tent cover after using Round Corner plugin?
                                      Square Carnival Tent.skp
                                      • irwanwrI
                                        irwanwr
                                        @alan fraser said:
                                        ... I would round some of the edges a little. After all, the fabric will roll gently over the poles, not form razor sharp creases.
                                        if you don't mind, i'd like to know how to make those round edges as smooth as the image above?
                                        • GaieusG
                                          Unless Alan really rounded them (adding geometry) which I doubt as he likes to keep his models low poly, simply use the Erasertool while holding down the Ctrlkey to soften edges. Very sharp edges do not look nice when softened but for a shallow roof like that, they may not be too sharp.
                                          • Alan FraserA
                                            Alan Fraser
                                            Actually, I did add geometry...but Gaius is right, I do like low polygon counts, so I only used 3 segments to the curve.
                                            Find the Round Corners ruby script by Fredo. It gives you 3 options...round corners, sharp corners and bevel edges. Select the top of the tent, plus the four corners that hang down and choose the round corners option. You'll see a dialog appear at the top of the drawing window...and also the same parameters in the VCB (Measurements box)...the spread of the curve followed by the number of segments, separated by a comma. Retype your own parameters...these would be something like 1" or 2cm and 3 segments. Press Enter, see if the preview lines look ok on your model then use the tick on the end of the cursor to accept them.
                                            3D Figures
