Sketchup intermittently not responding upon load of model
Lately, I've been having sketchup freeze up on me during the loading of a file. It can be any file. Sometimes it's also during a fresh dwg import. The only way to un-hang sketchup is to force close it. After closing, I can restart sketchup and load the same model and everything will be fine. Same with dwg imports that will work the second or third time.
I've tried repairing sketchup, and it doesn't help. At first I thought it had to do with the fact I was lacking space on my
drive, but that I solved, so it's not that anymore... (that was causing different problems of not being able to load more than one or two sketchup sessions)I would like to know what might be causing this. It might be one of the plugins I've installed some time ago. I removed a few of the latest plugins... but it's still happening. I really don't feel like going through all of my plugins, especially if the bug is intermittent... so I can't always know if I've solved the problem.
Is there a way I could find an error log or something of the sort that will show me when sketchup is hanging!?
I just noticed that I don't even have to load a model. Sometimes it's enough that I just draw the first line, or move the camera a bit and it jams up again.
