    Vrfsu settings - interior render
    renderpluginsextensions
    20 Posts 3 Posters 2.4k Views 3 Watching
    • kaluK Offline
      kalu
      @andybot said:
      @stefanq said:
      Hi!
      The only thing that caught my attention, is your irradiance map min and max rate. They are way off.
      @3200x2400
      min/max = -6/-3
      Good point - definitely decrease your irrmap rates as you render larger size. I'm curious - what is your time to render at 800x600? Also, what are your material settings for your glossy materials? Seems like there's perhaps some glossy reflection settings that are very high? By the way, which version are you using right now? Are you using 1.49.01? It has many fixes that help with render speed over the older versions.
      Hi Andy I am using the 1.49.01 and I show some of the material settings for some reflection. the time for a render in 800x600 i will test right now and I will post. Thank you so much for your info.
      THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
      • kaluK Offline
        kalu
        I make a render test ful in color in 400 x 300 and the time was 0h13m14.0s. This is the sample.
        • andybotA Offline
          andybot
          Interesting - I would try rendering without the brushed stainless steel material. I've found that one tends to make my rendering times longer. Actually, one troubleshooting you can do is to do a render with global material override and turn materials on one at a time and see the difference in time to render.
          • kaluK Offline
            kalu
            Hi andy:
            I think the problem is the stainless steel material of the kitchen oven and the fridge, and the dishwasher, I replace the material and I have the same time to render 10.5 hours to do a simple render of 1600x 1200. This is crazy time. I save the Lc and the IR and I render with this parameter to a 3200x2400 and when I was 7 hours of process and 60% I just quite the render. I have to make 11 renders and I have not idea what to do. I follow all your comments, watch all the videos and webinars that I paid in ASGVIS with fernando Rentas and I am frustrated and lost....
            Any other comment or help will be appreciate.
            Please if you have any material that work great as stainless steel in the latest version of vray let me know.
            Kalu. πŸ˜•
            • stefanqS Offline
              stefanq
              I use all the time brushed metal material, that come with v-ray. It doesn't render fast, but it's not obscene. I attached an image to see how it's rendered.
              At this point, regarding the problems you're facing, I have a doubt that your glass it's ok.I mean, maybe the sun has so much trouble to bring the light inside through that glass. I would hide the glass, and see what's going on. As well, it would be good if you just upload the scene, and hopefully someone will have the time to test it.
              By the way, do you have a deadline?
              Good luck!
              Stefan
              • kaluK Offline
                kalu
                Hello Stefanq,
                Thank you for your advide, i will try that now, I have a deadline but at this point I am stuck with a ggood result and understand the problem and fix that instead make it happened without understand the problem. Since i have a mix of materials new and older can you attach the material that you use in your kitchen (the metal) I use all the materials that i have and I never achieve the same look. I really appreciate, if you can't can you place all the settings either will be good help. I place my interior settings for someone that want to take a look maybe work for others. I made the settings base on webinars that i take on ASGIVIS, read almost all the comments in the forum and watch video training.
                I attach my render settings, If someone have an a idea what is the wrong settings will be good. I just want to reduce my time, a render in 3200 x 2400 should not take more than 5 hours in HQ but 10.5 hours? It's just crazy...
                (www.filesonic.com)
                Again I take any good suggestions.
                kalu 😲
                • stefanqS Offline
                  stefanq
                  OK, just to be sure it's the right material, I had to dig through the chaosgroup forum, as I knew someone asked me about that material. So, I'll post a link where I put some images, one with a print screen of the settings, one with the bump texture.But you have to schroll down 'cause it's king in the middle of the page. It's a reply for an user named 40'th. I dld your settings, but I didn't had time to test it, and I thought you will share the sketchup scene, not the visopt. Anyway, from your settings images, I didn't find anything that could ruin your rendering time. Even your reflective materials,they have default samples (8) and here I usually use 32. Your noise and color threshold is default (0,01) and here I use 0,005 most of the time. That being said, I don't know what's wrong, maybe some of the guru's will find time to help you. Sorry for this big "bla-bla", my English is not forte.
                  PS: you should try Teofas's visopt, see the attachment
                  Cheers,
                  Stefan
                  http://www.chaosgroup.com/forums/vbulletin/showthread.php?58309-Post-your-Simple-Render-here./page31
                  TEOFAS.rar
                  • andybotA Offline
                    andybot
                    A few things I found that makes render time for this scene very long:
                    -image sampler noise thresh is .008
                    -You have detail enhancement on
                    -LC is 1200
                    -the ss material has anisotropy on and subdivs of 32.
                    -most of your materials have subdivs of 32,
                    I tried rendering at 800x533 with noise thresh at .015, DE off, LC at 800, and subdivs for the metal and countertops and most other materials at 16. My render time was just under 30 minutes. (My processor is an AMD Phenom II X6 1055T)
                    Best,
                    Andy
                    • andybotA Offline
                      andybot
                      here's the scene again with just sunlight and GI. It's possible to get a nice day-lit render without all the hidden lights. I think processing the blurry reflections for many light sources is probably the biggest contributor to the long render times. The time is reduced by more than 4 times!
                      previous render
                      sunlight and GI only
                      • stefanqS Offline
                        stefanq
                        Andy, you are spot on! I was about to remove all those omni lights, but I got a bug splat and because it was late at night, I gave up. Before that, I noticed that the rendering buckets stayed to much over that beige-brown wall, and that's simple diffuse material. It was all those lights, as you figure yourself.
                        Another thing I noticed, was the fact that he have rectangular lights in some of the windows, even if he use Fernando's method for bringing more light through the GI, without having the sun there.So, no need for those lights.
                        Kalu, as a general advice, you should use components instead groups.The scene will not be as heavy as it is.
                        • kaluK Offline
                          kalu
                          Hi to all, Good morning:
                          I really appreciated all the comments, Andy you make things happened. I make the first render yesterday and now I work on the 3rd. Stefan I really appreciate all the comments too. I was follow all the tricks and comments of Fernando Rentas, and some things may not work well in my scene, things that I was missing was the rect. lights and the omni lights without that all was normal in the time for render. Wow it take quite some time to figure out but thanks to Andy and Stefan and fernando Rentas we make a success. I hope others learn from my mistakes and get some of piece of the pie...
                          Again guys, you are awesome as usual.
                          Thank you to all for all the time and effort spend in this matter.
                          Kalu-Kelper. πŸ‘
                          • kaluK Offline
                            kalu
                            Thank you about al your comments, one more thing, about the weight and components, the owner make so much changes that was impossible to make components since change every aspect so many times...
                            Thanks for the advise... πŸ‘
                            Kalu-Kelper
                            • andybotA Offline
                              andybot
                              Hey Kalu, Glad to help! We all learn something.
                              Stefan, I hadn't even seen the rectangular lights at the windows. No wonder the render times were so high, that's a lot of competing lights. I used the global "lights" option to turn off all the light sources. My thought is that if you can't see the difference of the light in the scene with the GI on, you probably shouldn't have it in the scene.
                              Andy
