    SketchyPhysics3 FAQ.
    38 Posts 27 Posters 97.8k Views 27 Watching
      demigamer
      hey guys
      he says where emitters are; its such as ''hidden''
      why? i want to make a twilight render
      but even sketchyreplay doesn't see my emitters ๐Ÿ˜ž
      can someone help me? its for a project ๐Ÿ˜„ so i need it
      thanks anyway
      greetz,demi
        KSJ100
        Only SketchySolids works for me!! I have a mac PowerPC 10.5.8 mac!!!!!
        the ruby consle says this [img]Picture%201.png[/img]
        First click
        potentialParent #<Sketchup;;Drawingelement;0xc9d77c0>
        Error; #<NoMethodError; undefined method `getKeyState' for #<MSketchyPhysics3;;CreateJointTool;0xc9d8b70>>
        /Users/justin/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyPhysics3/JointTool.rb;432;in `onLButtonDown'
        First click
        Error; #<NoMethodError; undefined method `getKeyState' for #<MSketchyPhysics3;;CreateJointTool;0xc9c26f4>>
          KSJ100
          First click
          First click
          • jgbJ Offline
            jgb
            Hi Chris. I need to get back into SP again.
            I "left" only because I found the learning curve got too steep too soon, but now I am determined to get it to work.
            BUT.....
            "Now that you have installed SketchUp, use the following link to view the latest SketchyPhysics downloads...
            http://code.google.com/p/sketchyphysics2/downloads/list?can=1&q=&sort=-uploaded&colspec=Filename Summary Uploaded Size DownloadCount
            And which file(s) would that be????? I would have expected the latest file(s) to be, and remain, at the top of the list, but it is buried down and I am confused as to which one(s) I need (Win XP) to get going. ๐ŸŽ‰
            jgb
              ahnvtk
              @sgal said:
              can move linearily along his axe.. The object axe points to the joint.. the Universal joint won't allow the object to rotate around his axe.
              I believe you mean "axle", not "axe"? ๐Ÿ˜‰
              • jgbJ Offline
                jgb
                Still no answer on which file(s) is the latest release.
                I went to the Download page and noticed a few things that make no sense; to me, anyhow.
                What is a Deprecated file?? โ“ โ“
                Why is the release level not fully defined in the file name?
                3.x is meaningless. ๐Ÿ‘Ž ๐Ÿ‘Ž
                Why is the "Release Date" column blank? ๐Ÿ˜ฎ โ“ โ“
                Why are the file descriptions/summaries so terse and literally non-informative? ๐Ÿ˜’
                I sorta expected better than this based on the quality of SP in general and the high level of user support Chris and users deliver.
                jgb
                  ahnvtk
                  Even with these helps I'm still having a very hard time identifying the newest SketchyPhysics download. Is it SetupSketchyPhysics3x-Apr2.exe @ this page?
                  Dying for SketchyPhysics IV. Seeing small SketchyPhysics solids fall through the floor in the version I have installed now ๐Ÿ˜ž
                    mptak
                    Whenever I miss the brilliant things that CP drops out of the sky every now and then I just go back to the Sketchy Physics Piano and try plunk out a little tune. I hope all is well.
                    • jgbJ Offline
                      jgb
                      Me thinks Mr. Phillips is loosing (lost โ“ ) interest in supporting SketchyPhysics. ๐Ÿ˜ฒ
                      He is less than responsive to posts, and updates are non-existant. ๐Ÿ‘Ž
                      We've known for a long time he doesn't like documenting much, which is an occupational hazard for innovative developers. But super simple stuff like maintaining his SketchUcation page with basic release info has fallen to the wayside. ๐Ÿคข
                      It's a shame though. SP is really neat, but in need of some upgrades Chris promised that never transpired. ๐Ÿ˜ข
                      jgb
                        Crankston Shnord
                        Question:
                        I am trying to use a slider to power a simple gun. I grouped the slider to the "bolt" (the part that I want to slide) but when I try to parent it to the barrel than nothing happens. I select the parent tool, and than CTRL-Click the barrel. All that happens is that the joint-connector tool selects the barrel, but it doesn't parent the slider. Any thoughts? EDIT: I am using Sketchup8 and SP 3.1.
                        Crankston Shnord
                        Sketchup Modeler,
                        Blender Designer,
                        Renderer
                        My Models
                        • E Offline
                          emanuelson87
                          @sgal said:
                          1. Object can be linked to more than one joint, and vice versa.
                          Actually, Connecting two objects to a single controlled joint will not work correctly. Either object will take on a static position once the simulation is commenced.
                          I have a problem I can not see the SketchyPhysics Inspector window comes in blue and does not make me change the parameters of my project ... I'm going crazy aiutatemieeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
                          • E Offline
                            emanuelson87
                            Hi I have a problem with SketchyPhysics every time I try to activate the SketchyPhysics Inspector gives me an error in the console and the ruby code
                            quietly_force_sync_mats_cb just calledpotentialParent #Sketchup::ComponentInstance:0x1844c6b4
                            • O Offline
                              openhatch
                              Really confused . . .
                              At the moment the project home page lists a release date of Sept 27 2010, the download page it links to says Dec 10 2010, and the newest Windows release in the list of all downloads without a "deprecated" tag says Apr 2009, and the post starting this thread says the newest will always be listed at the top of a page it links to, but it only links a search page that links back to the same post . . . three different dates on three different pages, and one red herring on another. . .
                              To compound this, if you search the plugins index for SketchyPhysics it lists several posts for several different versions, and I'm not sorting out which one is newest . . .
                              HALP!
                                malveira
                                What setting should I add to the buoyancy settings to allow the simulated water to interact with a propeller for example in the model, to allow its movement to propel the boat?
                                Cheers!
                                  mptak
                                  "What setting should I add to the buoyancy settings to allow the simulated water to interact with a propeller for example in the model, to allow its movement to propel the boat?"
                                  I don't think that direct action/reaction between the propeller and bouyant water is possible. You can link the propeller rotation and perhaps a push ([x,y,x]) function in some ruby script or else a hidden thruster attached to the boat. Hope this helps
                                    StevenGerritsen
                                    Hello,
                                    how do i export an sketchy Physics animation? F.a. in avi or any other size.
                                    gr Steven
                                      deskpilot
                                      Steven, see "Exporting animation" in my 'Simulation Aborted' thread. Anton takes you through the steps but it's not straight forward nor easy.
                                        Anton_S
                                        Good to see deskpilot helping out ๐Ÿ˜„
                                        Steven, here is the thread that deskpilot talked about: http://sketchucation.com/forums/viewtopic.php?f=61%26amp;t=60419#p552495
                                        Also, SketchyPhysics 3.5.5 main thread has various "how to" links, including how to export animation.
                                        • luckyvacL Offline
                                          luckyvac
                                          I would like to have information on the units of the mechanical adjustments. Example: Density in kg / m-cubic yes? For motors: Max acceleration, Strength ( force en newton ) what are these settings for from a physical point of view.
                                          How to make the link with the reality of indoor tests and measurements?
                                          how to use them.
                                          Are there any examples of calibrations? Where to find this information. Thanks, happy New Year.
                                          jean-luc
                                          • 2 / 2
