    SketchyPhysics3 FAQ.
    38 Posts 27 Posters 98.5k Views 27 Watching
      sf741852963
      why does my SketchyPhysics 3x freeze when I press play? ๐Ÿ˜•
        arjunmax09
        where can i get tutorial for sketchyphysics 3...maybe a pdf file...??
        when you fail at something....you haven't really failed...you've found one way the thing will not work out
          CPhillips
          http://sketchyphysics.wikia.com/wiki/SketchyPhysicsWiki
          • robintR Offline
            robint
            Hi all
            great stuff pls keep it up. I will try to add my 2 cents as i progress
            I cant post any links or skp models to demo my points, this is very limiting
            As one door closes another one slams in your face
              MikeR
              i got a SketchUp v6 and want to try and learn sketchy physics. what version should i download? thanks ๐Ÿ˜•
                demigamer
                hey guys
                he says where emitters are; its such as ''hidden''
                why? i want to make a twilight render
                but even sketchyreplay doesn't see my emitters ๐Ÿ˜ž
                can someone help me? its for a project ๐Ÿ˜„ so i need it
                thanks anyway
                greetz,demi
                  KSJ100
                  Only SketchySolids works for me!! I have a mac PowerPC 10.5.8 mac!!!!!
                  the ruby consle says this [img]Picture%201.png[/img]
                  First click
                  potentialParent #<Sketchup;;Drawingelement;0xc9d77c0>
                  Error; #<NoMethodError; undefined method `getKeyState' for #<MSketchyPhysics3;;CreateJointTool;0xc9d8b70>>
                  /Users/justin/Library/Application Support/Google SketchUp 7/SketchUp/Plugins/SketchyPhysics3/JointTool.rb;432;in `onLButtonDown'
                  First click
                  Error; #<NoMethodError; undefined method `getKeyState' for #<MSketchyPhysics3;;CreateJointTool;0xc9c26f4>>
                    KSJ100
                    First click
                    First click
                    • jgbJ Offline
                      jgb
                      Hi Chris. I need to get back into SP again.
                      I "left" only because I found the learning curve got too steep too soon, but now I am determined to get it to work.
                      BUT.....
                      "Now that you have installed SketchUp, use the following link to view the latest SketchyPhysics downloads...
                      http://code.google.com/p/sketchyphysics2/downloads/list?can=1&q=&sort=-uploaded&colspec=Filename Summary Uploaded Size DownloadCount
                      And which file(s) would that be????? I would have expected the latest file(s) to be, and remain, at the top of the list, but it is buried down and I am confused as to which one(s) I need (Win XP) to get going. ๐ŸŽ‰
                      jgb
                        ahnvtk
                        @sgal said:
                        can move linearily along his axe.. The object axe points to the joint.. the Universal joint won't allow the object to rotate around his axe.
                        I believe you mean "axle", not "axe"? ๐Ÿ˜‰
                        • jgbJ Offline
                          jgb
                          Still no answer on which file(s) is the latest release.
                          I went to the Download page and noticed a few things that make no sense; to me, anyhow.
                          What is a Deprecated file?? โ“ โ“
                          Why is the release level not fully defined in the file name?
                          3.x is meaningless. ๐Ÿ‘Ž ๐Ÿ‘Ž
                          Why is the "Release Date" column blank? ๐Ÿ˜ฎ โ“ โ“
                          Why are the file descriptions/summaries so terse and literally non-informative? ๐Ÿ˜’
                          I sorta expected better than this based on the quality of SP in general and the high level of user support Chris and users deliver.
                          jgb
                            ahnvtk
                            Even with these helps I'm still having a very hard time identifying the newest SketchyPhysics download. Is it SetupSketchyPhysics3x-Apr2.exe @ this page?
                            Dying for SketchyPhysics IV. Seeing small SketchyPhysics solids fall through the floor in the version I have installed now ๐Ÿ˜ž
                              mptak
                              Whenever I miss the brilliant things that CP drops out of the sky every now and then I just go back to the Sketchy Physics Piano and try plunk out a little tune. I hope all is well.
                              • jgbJ Offline
                                jgb
                                Me thinks Mr. Phillips is loosing (lost โ“ ) interest in supporting SketchyPhysics. ๐Ÿ˜ฒ
                                He is less than responsive to posts, and updates are non-existant. ๐Ÿ‘Ž
                                We've known for a long time he doesn't like documenting much, which is an occupational hazard for innovative developers. But super simple stuff like maintaining his SketchUcation page with basic release info has fallen to the wayside. ๐Ÿคข
                                It's a shame though. SP is really neat, but in need of some upgrades Chris promised that never transpired. ๐Ÿ˜ข
                                jgb
                                  Crankston Shnord
                                  Question:
                                  I am trying to use a slider to power a simple gun. I grouped the slider to the "bolt" (the part that I want to slide) but when I try to parent it to the barrel than nothing happens. I select the parent tool, and than CTRL-Click the barrel. All that happens is that the joint-connector tool selects the barrel, but it doesn't parent the slider. Any thoughts? EDIT: I am using Sketchup8 and SP 3.1.
                                  Crankston Shnord
                                  Sketchup Modeler,
                                  Blender Designer,
                                  Renderer
                                  My Models
                                  • E Offline
                                    emanuelson87
                                    @sgal said:
                                    1. Object can be linked to more than one joint, and vice versa.
                                    Actually, Connecting two objects to a single controlled joint will not work correctly. Either object will take on a static position once the simulation is commenced.
                                    I have a problem I can not see the SketchyPhysics Inspector window comes in blue and does not make me change the parameters of my project ... I'm going crazy aiutatemieeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
                                    • E Offline
                                      emanuelson87
                                      Hi I have a problem with SketchyPhysics every time I try to activate the SketchyPhysics Inspector gives me an error in the console and the ruby code
                                      quietly_force_sync_mats_cb just calledpotentialParent #Sketchup::ComponentInstance:0x1844c6b4
                                      • O Offline
                                        openhatch
                                        Really confused . . .
                                        At the moment the project home page lists a release date of Sept 27 2010, the download page it links to says Dec 10 2010, and the newest Windows release in the list of all downloads without a "deprecated" tag says Apr 2009, and the post starting this thread says the newest will always be listed at the top of a page it links to, but it only links a search page that links back to the same post . . . three different dates on three different pages, and one red herring on another. . .
                                        To compound this, if you search the plugins index for SketchyPhysics it lists several posts for several different versions, and I'm not sorting out which one is newest . . .
                                        HALP!
                                          malveira
                                          What setting should I add to the buoyancy settings to allow the simulated water to interact with a propeller for example in the model, to allow its movement to propel the boat?
                                          Cheers!
                                            mptak
                                            "What setting should I add to the buoyancy settings to allow the simulated water to interact with a propeller for example in the model, to allow its movement to propel the boat?"
                                            I don't think that direct action/reaction between the propeller and bouyant water is possible. You can link the propeller rotation and perhaps a push ([x,y,x]) function in some ruby script or else a hidden thruster attached to the boat. Hope this helps
                                            • 2 / 2
