    Does anyone have...
    59 Posts 11 Posters 4.3k Views 11 Watching
    • soloS Offline
      Hey, it's Jeff!!
        Maybe some problems at the extremity? Or with the cross-hatching all is blocked?
        • jeff hammondJ Offline
          [attachment=0:2vas8oe1]<!-- ia0 -->plaque8b.jpg<!-- ia0 -->[/attachment:2vas8oe1]
          yeah, the cross hatching would fill the void.
          @solo said:
          Hey, it's Jeff!!
          [attachment=0:2vas8oe1]<!-- ia0 -->jeff.jpg<!-- ia0 -->[/attachment:2vas8oe1]
          hahaha
          nice
            90% of team pain's wood projects over the past decade are my projects
            The corkscrew loop that Tony Hawk nailed first? Or was it Bob Burnquist?
            Anyway, I'd like to see some of your builds in SketchUp and Tony Hawk's autograph πŸ˜‰
              About the kidknee2_reducedfilesize.pdf
              There is not a general page for these pieces?
              Each piece is only on one page? As seen on the file that i have loaded πŸ˜„
                yeah, i designed/built that (the corkscrew)... it's actually one of the first complex projects i used sketchup for (i worked on tony's first loop, the first one in history, inside a bullring in tijuana but that one was designed by tim payne himself β€” i've built maybe 6 or 7 since then)..
                i found bob's corkscrew folder on an old hard drive.. v4 😲 πŸ˜†
                check out this file i used to help get my brain around wether or not the dimensions/angles/etc were right πŸ˜„
                view->animation->play… i basically held my left hand palm facing down then made a peace sign (fingers being the legs of a skateboarder) then moved my hand across the screen with the animation… πŸ˜† πŸ˜†
                burnquist 2 slice3animated copy.skp
                prior to building the corkscrew at bob's, i also built him a loop which was a convertible (the top opened up so there was a 14' gap which he aired upside down.. built that thing on two successive weekend while also building the first mega ramp for danny way β€” 2 weeks of hell πŸ˜„ ).. anyway, tony hawk's worst fall ever happened on that loop .. check it.
                [flash=640,360:u4ha0rjq]http://www.youtube.com/v/FGAso_G7SSA?version=3&amp;hl=en_US&amp;rel=0[/flash:u4ha0rjq]
                  there's a dialog for selecting your material size.. each page of the pdf represents one sheet of my selected material size.. with the dimension i chose for the final object and the size of one sheet of material i chose, only one piece fit on the material with a lot of waste left over.
                  if i were really going to have that cut to order, i'd want to readjust my parameters in order to maximize material/minimize waste. πŸ’š
                    Ooooooow 😲
                    That's a story to tell the grandkids.
                      I have seen that the maxi % of the PDF is 6400 %
                      Seems your little piece at the page one is 50 cm
                      So you can make it at 32 meters! πŸ’š
                      So a gorgeus stadium! πŸ˜‰
                        meh, 32m… here's a bowl i built that's closer to 35 meters long.. and 4 meters deep πŸ˜„
                        the deep end view from the other side..
                        another one around 22m x 29m:
                        that said, i'm liking the smaller kidney shown in this thread a lot better.. more classy or something..
                          Yes that is effectly truelly soft wood sculpture! 😎
                          But I said 32 meters for the piece number 37 of the page one! πŸ˜‰
                          So stadium size wil be more like this! πŸ˜‰
                          http://farm5.static.flickr.com/4090/5007740126_4897e35561.jpg
                          http://farm5.static.flickr.com/4130/5007129189_0097a8352f.jpg
                            haha
                            ok, i see now πŸ˜„
                            [where did you get the velodrome construction photos? looks interesting]
                            • StinkieS Offline
                              Stinkie
                              [attachment=2:2863kepg]<!-- ia2 -->eastern_01.jpg<!-- ia2 -->[/attachment:2863kepg]
                              [attachment=1:2863kepg]<!-- ia1 -->eastern_deep_end.jpg<!-- ia1 -->[/attachment:2863kepg]
                              Oooh, that's nice! None of those 'round here when I was a teenager. 😠
                                @Jeff
                                here
                                I believe that is the Olympic velodrome of London ?
                                Ps : What are the files formats of Importation inside 123D Make? Thx by advance β˜€
                                • 3 / 3
