To much faces!!
Hi everyone,
So I've try all your advices and some stuff are solved and some other bring questions.
For the of the use UV mapping plugin it's work really well.... but just once. After It crash SU 90% of the time, whish is sucks.
Is it the plugin or my SU, don't know.
But the result is much better.I've remodel the curve (profil) in different ways.
-In Illustrator first, but the number of segment is supper high so I guess it's not the best solution and I get some hole when I use the function follow me (I think it's due to the high nub or segments).
-Then I try directly in SU, not using the function arc to not have high poly as Gaeius you advise me, but instead I try to draw it with the pen tool...
I 've aslo try to use the previous curve (the one with the high poly arc) to keep the exact same path but I don't, couldn't find a way to break this arc and have it in segment. If you know how to do I'm interested.
-For the option follow me, there is something I don't get then. Dereeei advise me to "reduce the number of edges for the circle you used in Follow-Me operation" so if it's not necessary to increase the number of segment in the circle, how then I will not be able to see this faces in my rendering in Keyshot or even SU?
-For the rendering in Keyshot I've try to lower the number of segment in the circle, to smooth the object too and to group the object, but it's still the same problem, facets. all over
???I don't know if you have any Idea or advices but they are welcom if you have time.
Thank you anyway for your help till now.
Have great day!
An arc has 12 segments and a circle 24 segments by default. You can always change this number in various ways:
- After drawing it, right click > Entity info and change the segment count there.
- After drawing it, type the desired number of segments folloed by an s (for "segment") and press Enter. Like
8sthenEnter.
As for rendering in keyshot: did you make a group of the object as I suggested? Triple click on the surface to select all the geometry > right click > make group (or component). Then try to render that way.
Ok thank you for this tip I didn't know how to do this segment number change before.
Yes as you told me, I indeed group my object on my previous tries. But it's still the same problem many facets!
And do you have any clue why SU shut down when I use the plugin UV mapping, do you think it's from my SU install or just the plugin?
I don't know about Keyshot but here's a quick and dirty render in Kerkythea. This is from the ZIP file posted on the first page.
@N08/6317912453/" target="_blank" rel="noopener noreferrer nofollow ugc">
I scaled the material up so it doesn't repeat so obviously since it isn't seamless and I applied it as a projected material. It's clearly got some issues on the edge but I was mostly interested in your faceting issue. I can't see any faceting at all. Maybe you need to look at Keyshot instead of SketchUp to sort out the facets problem.
I see it is indeed ugly faceted. As Dave says, it must be some keyshot issue then. Maybe a setting which we do not know about (like welding vertices or smoothing edges).
You might be right. I'm gonna join a Keyshot forum and dig in this direction.
But you render is perfect and no faceting issue.
But I've been trying again and found out that the model you have was exported in .3ds and this file doesn't work properly (faceting) but I export it again in .obj and it's so so working still problem with some detail that doesn't appear and some faceting issue, still there but lighter.
Here's a shiny version of the ring rendered in KT. And with the hidden geometry from SU.
@N08/6318648290/" target="_blank" rel="noopener noreferrer nofollow ugc">
@N08/6318729066/" target="_blank" rel="noopener noreferrer nofollow ugc">
No facets at all.
So maybe it is your export type contributing to the problem. On the other hand, maybe it's the renderer. If you were using KT, you'd have been done days ago.
Ah, you did not mention (or I just overlooked) that you exported in 3ds.
See this post with a screenshot:
http://forums.sketchucation.com/viewtopic.php?p=363918#p363918Unfortunately, if you choose to weld vertices, you cannot keep UV co-ordinates. 3ds is a rather old and deprecated format. Try obj instead.
No facets at all.
Hello Dave R,
Thank you to for showing me that the model is not that bad.
I agree with you, but more on the fact that If I knew better my tools It will probably be done days ago.
But as I'm kind of beginner, in both, SU and Keyshot I'm still wondering around and finding my way with this them.
The problem is that I don't want to change again for the rendering softer, maybe I should, but for now I'm trying to get better at this one and see how things goes. Is KT easy as Keyshot to use? never heard of this one before but your renders are really good.I keep trying to find the right solution..
Thank for your help.
I understand wanting to stick with it until you get it right. Good luck doing so.
As to KT being easy, well, I'm probably not the best one to ask. I think it is easy but I only ever do very basic stuff and I usually do essentially the same thing every time. These renders only took a few minutes to complete and other than making some adjustments to the material using a preset, I didn't really do anything special. The background in the last one is just your concrete material inserted as the background in KT. A few seconds to do and I think it really improved the way the ring looks.
Keep plugging away and you'll have it.
