    Select all in layer
    4 Posts 3 Posters 784 Views 3 Watching
      T.M
      Hi everyone,
      I was wondering if it was possible to select all objects in a given layer in code, without having to pre-select an object in the same layer?
      I know it's possible through various plugins to add to the selection all the objects that are in the same layer as the selected one, but I would like to do it without having to make this pre-selection.
      Thanks for your help!
        All you need is a reference to the required layer - that's all you get from the preselected object with layer=object.layer in any case.
        So if you know its name (e.g. "MyLayer") then you can use xlayer=Sketchup.active_model.layers["MyLayer"].
        Now you can select all active entities that share that layer with
        Sketchup.active_model.selection.clear Sketchup.active_model.active_entities.each{|e|Sketchup.active_model.selection.add(e) if e.layer==xlayer}
        or alternatively do it by layer name directly [comparing strings is probably slower]
        Sketchup.active_model.selection.clear Sketchup.active_model.active_entities.each{|e|Sketchup.active_model.selection.add(e) if e.layer.name=="MyLayer"}
        etc etc...
          T.M
          Thanks a lot that was helpful!
            It is. Much slower! At all times avoid string comparisons if possible.
