    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Sunset
    23 Posts 16 Posters 3.2k Views 16 Watching
      davidh
      Another old model with some new landscape elements added and re-rendered,with grass and additional trees added in post-process.The external plaster is a bit patchy,mostly because I increased the contrast of the image to try and pull the colours out,but I think it actually helps.Similarly to a recent "Storm" Image I uploaded,a part of the image,in this case the left hand side,is more successful than the full image,regarding the lighting and feel I was originally looking for.I much prefer small areas of intense light and colour against a backdrop of darker tones.
      • mitcorbM Offline
        mitcorb
        Hi, davidh:
        Both are pleasing images. The patchy plaster looks perfectly natural to me, as if the weather did it. Both images convey your high technical expertise. The first one obviously,"tells the story". I see the second one as more of an analytical view, although all of the elements seem well integrated.
        I am curious which applications you used for the render?
        (ps: are you really still using Sketchup6?)
        • N Offline
          nomeradona
          very nice. how i wish you write tutorial for this and the storm/
            davidh
            These were rendered in maxwell,and yes I still use sketchup 6! It does what I need it to do so its good enough for me at the moment.Because Maxwell results in some grain in the render,I usually take it through a denoiser program to reduce this effect.
            As Ive said before,I do a lot of post processing and I always find something to add to the original render.Most of the post processing involves vegetation- grass,trees etc which would take forever to render.This is where having a good selection of entourage really comes into its own.
            Regarding tutorials,I will start to put one together for both the storm and sunset images next week and will upload as soon as I can,together with as much of the entourage I have used,except for any that were purchased (due to licensing issues).
            One thing I will say about post processing,I always build up layers of vegetation,some with depth of field blur,others with different colour tones.It helps to give a more natural image,with elements overlapping each other such as you would see in real life.
            • tademaT Offline
              tadema
              First image looks perfect to me ๐Ÿ‘
              • boofredlayB Offline
                boofredlay
                Stunning.
                • AdamBA Offline
                  AdamB
                  +1 Be great to see this deconstructed to help me/us learn.
                    davidh
                    Attached is a second version with additional landscape elements,in this case a reflecting pool.It wasn't part of the original scheme but I have some time on my hands to revisit older projects and thought the original scheme could have been better.I have also changed the external plaster to stone - more expensive but isn't it great that we can actually look at something and decide - err...emm... wouldn't that look better in timber,stone,something else?
                    Although it does look naked without a foreground overhanging tree- I think I need to stop using those guys!
                    • hellnbakH Offline
                      hellnbak
                      I would sell my soul, my cat, and half my bologna sandwich to be able to create something this fantastic! ๐Ÿ‘ ๐Ÿ‘
                      • DanielD Offline
                        Daniel
                        I'm with hellnbak on this one...I'd sell his soul, his cat, and half his bologna sandwich for your talent, David. Very nice images.
                        My avatar is an anachronism.
                          lapx
                          One of the best i've seen. Very nice colors on materials and lighting. Certainly captures a relaxing mood. David excellent job and cant wait for the tut.
                          Where can we get a copy of your grasses and trees. I love 'em.
                            Roger
                            Regardless of technical brilliance, I think David's greatest rendering asset is his power of observation.
                            http://www.azcreative.com
                            • soloS Offline
                              And his PS skills.
                                rvdkruk
                                @solo said:
                                And his PS skills.
                                I second that... please show us how you PS the grass!! I've been searching for ages for someone to teach me.
                                  davidh
                                  The grass is really easily done.I saw a tutorial on here showing how to do it a while back but all you do is load a selection of grass under the main image,add a layer mask to the main image and paint in the grass on the layer mask using the grass brush(available here, http://qbrushes.net/plants/photoshop-grass-brushes/),changing the size of the brush as you go.Usually I would then add a few additional plants over the grass with gaussian blur,just to add depth of field.Ive attached a screensnap showing quickly what it looks like in photoshop.
                                  • artysmediaA Offline
                                    artysmedia
                                    Thanks for the link! ๐Ÿ˜„
                                    Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                                    Blog: Artysmedia
                                      rvdkruk
                                      Very usefull info. Thanks.
                                      I'm beginning to see the value of custom brushes ๐Ÿ˜„
                                      I use Paintshop Pro in stead of PS. Anyone know nice brushes for that?
                                        davidh
                                        here's a website that you can download some grass brushes for paintshop pro:
                                        (www.brushouse.com)
                                          cadmunkey
                                          Nothing much to add apart from 'fantastic!'. Your post pro skills are very impressive, hoping for a tutorial soon, even if you dont want to give away all your secrets!
                                            davidh
                                            A tutorial for the sunset is forthcoming,although this is probably one of the least post processed images I have uploaded.There will be a tutorial for the "Storm" and "Moonlight" images also uploaded.
                                            Its really all about composition and light,particularly light, where you can use shadows to really accentuate and alter an image.
                                            From my own experience,the best images are not harshly lit,i.e noon light, but low evening/early morning.The light is diffused,the building is warmer and the colours are accentuated.
                                            Maybe there is room for a subsection on tutorials where we concentrate on light .
                                            On a side note,I have seen some amazing images but my idol is Alex Roman(http://www.thirdseventh.com/)This man is so far ahead,so able to create atmosphere and basically makes you feel so,so inadequate.
