    [Plugin] Bolt Maker (Final Update 7-Feb-2012)
    101 Posts 31 Posters 95.9k Views 31 Watching
    • sdmitchS
      sdmitch
      Jim, Thanks for the info. That is something I never tested because I assumed the components would be unique since "drilling" a hole in one would effect them all.
      http://sdmitch.blogspot.com/
        Jim
        Sam, I'm getting this error when trying to bolt through the same instance:
        Error: #<NoMethodError: undefined method distance' for nil:NilClass> C:/Plugins/bolt maker.rb:205:in drill_hole'
        C:/Plugins/bolt maker.rb:148:in `onLButtonDown'
          Jim
          I wonder if it would be better to allow the user to select 2 points (using inference) to set the length and direction of the bolt, rather than having the plugin attempt to calculate? I do like pulling off the edges to mark the center; so after this just 2 more clicks to set the length and direction.
          Also, what if the bolt were made as a Component rather than a Group? Then it could be re-used and accounting for the hardware in the model would become easier.
          • HumpmetwiceH
            Humpmetwice
            Works Great now but I do like Jim's idea about making it a component instead of a group but beggers can't be choosey.
            • sdmitchS
              sdmitch
              As I see it, the problem with making the nut and bolt set a component is that you would have to create one for every conceivable diameter and length which wouldn't be any different than creating them as groups. I also see no advantage in requiring 2 additional points to define length and direction. Drilling the hole through the components would be impossible if direction is not perpendicular to the faces. The head of the bolt is always on the first component so the order of selection determines direction.
              • kenK
                ken
                I am curious, why does the objects to be bolted need to be a component? I use component, but I also use groups and was just wondering why it only would work on a component and not a group.
                Thanks for the plugin.
                Ken
                • sdmitchS
                  sdmitch
                  Because of the nature of components, how could you possibly drill a single hole through the two copies. There is only one situation where that is possible and that is if two instances are stacked and orientated exactly the same. Otherwise, at best you get a bolt on one end and an empty hole on the other.
                  • sdmitchS
                    sdmitch
                    Ken
                    Primarily because that's what the original request was. Groups and components are very simuliar but does require some additional code to handle either.
                      Jim
                      What I am trying to suggest is there are too many edge cases - too many ways that people need to fasten things together for a plugin to attempt to guess what the user wants. For example, it appears you are assuming there are ever only 2 plates that need bolted together. What if I need 3 plates bolted together? Or if I need a spacer between the plates? By using a 2-point selection procedure for setting the direction and length, you do not need to make any assumptions or guesses - it seems like it would greatly simplify the procedure for placing bolts in all possible cases since the bolt is drawn in the selected direction and length set by the user.
                      True, this will likely complicate hole-cutting, but I'd rather have a quick way to place bolts before worrying about getting the holes cut.
                      • kenK
                        ken
                        I show bolt in all my designs, some time is the hundreds. Yes I would like to have a method of making a bolt with just a line. With the line giving direction and length. I use the bolt dynamic component, and I have to work around showing bolts that not fully engage, in other words, just above the selection but not tightened. I use the plugin drill to make the holes, and just being able to connect multiple pieces together, than add the bolt above the pieces or partly though or completely though would be great.
                        Well, it is a needed plugin.
                        Again thank you.
                        • N
                          Niffler
                          Greetings, โ˜€
                          I downloaded "Bolt Maker.rb" and dropped it into the proper plug-in folder and then experienced my first error message after I restarted SketchUp 8.
                          Error Loading File Bolt Maker.rb
                          undefined method `file_loaded?' for main:Object
                          How can I resolve this without using percussion maintenance? ๐Ÿ˜‰
                          Peace
                            Jim
                            Open the file "Bolt Maker.rb" in a text editor - say notepad.exe, then move the following line up roughly 7-8 lines so it appears just after the comment lines (which begin with #) but before any other lines in the file.
                            require "sketchup"
                            Save the file, and restart SketchUp.
                            • C
                              CalypsoArt
                              Great plugin. Love the ability to pull from the sides to set position. I got a bug splat but can't remember exactly where in the process. Worked fine after that. I Agree with others it would be nice to be able to pic a top face and a bottom face in a set of stacked components/groups and have the plugin drill/cut through them all. But I can work with it as is.
                              Thanks.
                              • sdmitchS
                                sdmitch
                                CalypsoArt,
                                Stack away. Just posted update allows that and it drills holes through them all.
                                The bug splats and failures are caused by the usually benign start_operation statements.
                                I got a lot of those also until I removed them.
                                • sdmitchS
                                  sdmitch
                                  OOPS!!!! Sorry Bolt Maker fans. Dispite what I thought was adaquate testing, I found a problem while playing around with the plugin this morning. It has been corrected and a new copy posted.
                                  • N
                                    Niffler
                                    Help!! I can't get bolt maker to run anymore.
                                    1. I have used both copies of bolt maker: bolt maker and bolt maker 7.
                                    2. I run the programs in SketchUp 8.
                                    3. I have run successfully, both versions (obviously, one at a time) in either SketchUp/Plugins or SketchUp/Tools folder. Both copies had worked in either folder. FYI
                                    4. It took me several dozen retrys to figure out those terrible instructions; and in one glorious moment, it worked. I went to repeat my success AND...nothing! I clicked the Bolt-maker icon in the toolbar and then...nothing. I clicked the Bolt-maker icon a number of times. It stopped working.
                                    5. I downloaded and tried out new copies in place of the others in the SketchUp root folder and still nothing. I even reversed the file's location from Plugins folder to the Tools folder, still nothing happened.
                                    6. I even created two, new group components, thinking that it was probably the models. Nope!
                                    7. I went to another older system where I had backup copies of both files of bolt maker and of SketchUp 8. I fired up SketchUp and lo-and-behold, bolt maker worked. I mucked about with the instructions for many times (don't ask me how many), then the same thing happened on that computer: the Bolt-Maker button died.
                                    The only thing I can figure happened with this challenge is that this program is crippleware, that is a program that deactivates itself after a number of reactivations. This program probably detects: "This person is an idiot! It is much too dangerous to be in the hands of such a simpleton." DELETE DELETE DELETE LOL
                                    Can someone help with this?
                                    • sdmitchS
                                      sdmitch
                                      You must have me and my Bolt Maker confused with someone else. Mine doesn't have a Toolbar Icon or Button!
                                      No, my Bolt Maker is not "crippleware", there are no limits on its use.
                                      • N
                                        Niffler
                                        Hello, sdmitch,
                                        Thanks for the reply. I'm sorry, I used the wrong phrase and confused the menu bar with the toolbar (considering that, well the majority of my tools are found under Tools on the menu bar).
                                        I'm pretty sure that the plugin I'm using is yours (it's found under the menu bar, Plugins > Bolt Maker). I'm just pretty frustrated. I managed to get the plugin to work once on SketchUp 8 but, since then, any time I click on the Bolt Maker button under the Plugins menu, the dialogue box for using it wouldn't even appear; its as if I never clicked on it at all.
                                        I apologize if my original post was a bit combative; it's frustrating having a vastly time-saving plugin on my system that doesn't work for whatever reason.
                                        So, can you help me? Have you encountered this problem before with your program, or know of anything that would cause the plugin to only work only once? I appreciate any help you can render.
                                        • kenK
                                          ken
                                          Note, I also have the same problem. I just didn't mention the problem as I use the bolt maker dynamic component. However, I do wish your plugin would work.
                                          What is does on my machine, it will work one to two times than that is the last it will work. One time removed the txt file and it work one more time. But as of now it does not function each and every time.
                                          I hope you get this sorted out as I use a lot of bolts.
                                          Thank you for your work and the plugin.
                                          Ken
                                          • N
                                            Niffler
                                            Thank you, Ken! It's good to know I am not alone in my plight!
                                            I have since deleted and reinstalled using the version of Bolt Maker found on sdmitch.blogspot.com. When I went to use that one, the dialogue box appeared normally. I then went to use the plugin, but it would not recognize my created groups as actually being groups. I then clicked out of the Bolt Maker dialogue box to make another component, in the hopes that would work, and then went to reopen Bolt Maker. Nothing happened; same problem as before.
                                            I closed down SketchUp and replaced the Bolt Maker.rb file with a backup I had made earlier. I am unsure if it was designed for 7 or 8, but I replaced it. Now, no matter how many times I delete the .rb file, restart my system, and reinstall using a new file downloaded directly from blogspot, the program will not work.
                                            This may be a silly question, but where is this .txt file in SketchUp associated with Bolt Maker? I may try deleting that as well when I reinstall, but there is no .txt file that I can see under C:\Program Files\Google\Google SketchUp 8\Plugins
                                            Also, I'm running Vista, and, unlike all other times, the last couple times I went to delete the .rb file, User Account Control did not pop up to ask me for permission to delete the file. Weird...
                                            • 1 / 6
