    [Plugin] Bolt Maker (Final Update 7-Feb-2012)
    101 Posts 31 Posters 90.4k Views 31 Watching
    • kenK Offline
      ken
      I am curious, why does the objects to be bolted need to be a component? I use component, but I also use groups and was just wondering why it only would work on a component and not a group.
      Thanks for the plugin.
      Ken
      • sdmitchS Offline
        sdmitch
        @jim said:
        Sam, I'm getting this error when trying to bolt through the same instance:
        Error: #<NoMethodError: undefined method distance' for nil:NilClass> C:/Plugins/bolt maker.rb:205:in drill_hole'
        C:/Plugins/bolt maker.rb:148:in `onLButtonDown'
        Because of the nature of components, how could you possibly drill a single hole through the two copies. There is only one situation where that is possible and that is if two instances are stacked and orientated exactly the same. Otherwise, at best you get a bolt on one end and an empty hole on the other.
        http://sdmitch.blogspot.com/
        • sdmitchS Offline
          sdmitch
          Ken
          Primarily because that's what the original request was. Groups and components are very simuliar but does require some additional code to handle either.
            Jim
            What I am trying to suggest is there are too many edge cases - too many ways that people need to fasten things together for a plugin to attempt to guess what the user wants. For example, it appears you are assuming there are ever only 2 plates that need bolted together. What if I need 3 plates bolted together? Or if I need a spacer between the plates? By using a 2-point selection procedure for setting the direction and length, you do not need to make any assumptions or guesses - it seems like it would greatly simplify the procedure for placing bolts in all possible cases since the bolt is drawn in the selected direction and length set by the user.
            True, this will likely complicate hole-cutting, but I'd rather have a quick way to place bolts before worrying about getting the holes cut.
            • kenK Offline
              ken
              I show bolt in all my designs, some time is the hundreds. Yes I would like to have a method of making a bolt with just a line. With the line giving direction and length. I use the bolt dynamic component, and I have to work around showing bolts that not fully engage, in other words, just above the selection but not tightened. I use the plugin drill to make the holes, and just being able to connect multiple pieces together, than add the bolt above the pieces or partly though or completely though would be great.
              Well, it is a needed plugin.
              Again thank you.
              • N Offline
                Niffler
                Greetings, β˜€
                I downloaded "Bolt Maker.rb" and dropped it into the proper plug-in folder and then experienced my first error message after I restarted SketchUp 8.
                Error Loading File Bolt Maker.rb
                undefined method `file_loaded?' for main:Object
                How can I resolve this without using percussion maintenance? πŸ˜‰
                Peace
                  Jim
                  Open the file "Bolt Maker.rb" in a text editor - say notepad.exe, then move the following line up roughly 7-8 lines so it appears just after the comment lines (which begin with #) but before any other lines in the file.
                  require "sketchup"
                  Save the file, and restart SketchUp.
                    CalypsoArt
                    Great plugin. Love the ability to pull from the sides to set position. I got a bug splat but can't remember exactly where in the process. Worked fine after that. I Agree with others it would be nice to be able to pic a top face and a bottom face in a set of stacked components/groups and have the plugin drill/cut through them all. But I can work with it as is.
                    Thanks.
                    • sdmitchS Offline
                      sdmitch
                      CalypsoArt,
                      Stack away. Just posted update allows that and it drills holes through them all.
                      The bug splats and failures are caused by the usually benign start_operation statements.
                      I got a lot of those also until I removed them.
                      • sdmitchS Offline
                        sdmitch
                        OOPS!!!! Sorry Bolt Maker fans. Dispite what I thought was adaquate testing, I found a problem while playing around with the plugin this morning. It has been corrected and a new copy posted.
                        • N Offline
                          Niffler
                          Help!! I can't get bolt maker to run anymore.
                          1. I have used both copies of bolt maker: bolt maker and bolt maker 7.
                          2. I run the programs in SketchUp 8.
                          3. I have run successfully, both versions (obviously, one at a time) in either SketchUp/Plugins or SketchUp/Tools folder. Both copies had worked in either folder. FYI
                          4. It took me several dozen retrys to figure out those terrible instructions; and in one glorious moment, it worked. I went to repeat my success AND...nothing! I clicked the Bolt-maker icon in the toolbar and then...nothing. I clicked the Bolt-maker icon a number of times. It stopped working.
                          5. I downloaded and tried out new copies in place of the others in the SketchUp root folder and still nothing. I even reversed the file's location from Plugins folder to the Tools folder, still nothing happened.
                          6. I even created two, new group components, thinking that it was probably the models. Nope!
                          7. I went to another older system where I had backup copies of both files of bolt maker and of SketchUp 8. I fired up SketchUp and lo-and-behold, bolt maker worked. I mucked about with the instructions for many times (don't ask me how many), then the same thing happened on that computer: the Bolt-Maker button died.
                          The only thing I can figure happened with this challenge is that this program is crippleware, that is a program that deactivates itself after a number of reactivations. This program probably detects: "This person is an idiot! It is much too dangerous to be in the hands of such a simpleton." DELETE DELETE DELETE LOL
                          Can someone help with this?
                          • sdmitchS Offline
                            sdmitch
                            You must have me and my Bolt Maker confused with someone else. Mine doesn't have a Toolbar Icon or Button!
                            No, my Bolt Maker is not "crippleware", there are no limits on its use.
                            • N Offline
                              Niffler
                              Hello, sdmitch,
                              Thanks for the reply. I'm sorry, I used the wrong phrase and confused the menu bar with the toolbar (considering that, well the majority of my tools are found under Tools on the menu bar).
                              I'm pretty sure that the plugin I'm using is yours (it's found under the menu bar, Plugins > Bolt Maker). I'm just pretty frustrated. I managed to get the plugin to work once on SketchUp 8 but, since then, any time I click on the Bolt Maker button under the Plugins menu, the dialogue box for using it wouldn't even appear; its as if I never clicked on it at all.
                              I apologize if my original post was a bit combative; it's frustrating having a vastly time-saving plugin on my system that doesn't work for whatever reason.
                              So, can you help me? Have you encountered this problem before with your program, or know of anything that would cause the plugin to only work only once? I appreciate any help you can render.
                              • kenK Offline
                                ken
                                Note, I also have the same problem. I just didn't mention the problem as I use the bolt maker dynamic component. However, I do wish your plugin would work.
                                What is does on my machine, it will work one to two times than that is the last it will work. One time removed the txt file and it work one more time. But as of now it does not function each and every time.
                                I hope you get this sorted out as I use a lot of bolts.
                                Thank you for your work and the plugin.
                                Ken
                                • N Offline
                                  Niffler
                                  Thank you, Ken! It's good to know I am not alone in my plight!
                                  I have since deleted and reinstalled using the version of Bolt Maker found on sdmitch.blogspot.com. When I went to use that one, the dialogue box appeared normally. I then went to use the plugin, but it would not recognize my created groups as actually being groups. I then clicked out of the Bolt Maker dialogue box to make another component, in the hopes that would work, and then went to reopen Bolt Maker. Nothing happened; same problem as before.
                                  I closed down SketchUp and replaced the Bolt Maker.rb file with a backup I had made earlier. I am unsure if it was designed for 7 or 8, but I replaced it. Now, no matter how many times I delete the .rb file, restart my system, and reinstall using a new file downloaded directly from blogspot, the program will not work.
                                  This may be a silly question, but where is this .txt file in SketchUp associated with Bolt Maker? I may try deleting that as well when I reinstall, but there is no .txt file that I can see under C:\Program Files\Google\Google SketchUp 8\Plugins
                                  Also, I'm running Vista, and, unlike all other times, the last couple times I went to delete the .rb file, User Account Control did not pop up to ask me for permission to delete the file. Weird...
                                  • kenK Offline
                                    ken
                                    Here is the txt file, "Bolt Maker7.txt".
                                    Ken
                                    • sdmitchS Offline
                                      sdmitch
                                      Niffler, The .txt file is automatically created when it doesn't exist and just keeps the last input parameters for future runs.
                                      The only problems I have had with the plugin relate to the .start_operation/commit_operation block but those are not active in the plugin I posted.
                                      If you would please open the Ruby Console before running the plugin and post any errors that appear there.
                                      • N Offline
                                        Niffler
                                        Greetings Sdmitch,
                                        As you requested...
                                        Error: #<ArgumentError: Cannot convert "0.167'
                                        " to Length>
                                        C:/Program Files/Google/Google SketchUp 8/Plugins/Bolt Maker.rb:48:in to_l' C:/Program Files/Google/Google SketchUp 8/Plugins/Bolt Maker.rb:48:in dialog'
                                        C:/Program Files/Google/Google SketchUp 8/Plugins/Bolt Maker.rb:41:in initialize' C:/Program Files/Google/Google SketchUp 8/Plugins/Bolt Maker.rb:25:in new'
                                        Niffler
                                        • N Offline
                                          Niffler
                                          Greetings Sdmitch,
                                          As you requested...
                                          " to Length>
                                          Niffler
                                          [UPDATE] I have found it! I found the bug!
                                          Last night, I went into my old system and deleted all remenants of Bolt-maker.rb from SketchUp8/Plugins. I then copied the latest version of Bolt-maker.rb I had downloaded from sdmitch.blogspot.com.
                                          I fired-up SketchUp 8, and clicked on Bolt-maker 7 in the menu bar. It worked! Now, I was very cautious about the parameters I set. So I stayed with the 1/4 inch bolt-size.
                                          After a number of dry runs, I was finally able to confidently create a half-dozen bolts "joining" those plates. Great!
                                          Now, I decided to push the limits. I clicked the Boltmaker7 (button) in the menu bar. After the dialog box appeared, I set the bolt's size to 2 inches. The plugin worked. However, when I went to repeat my thought experiment, the dialog box failed to appear, which is good, too.
                                          I clicked open the Ruby Console. After I clicked the Bolt-maker7 (button), the same error appeared as it had in the lines above.
                                          Sdmitch, made a good program, but needs to adjust the parameters of the bolt sizes from: Tiny to Colossal (for all you D&D fans). I think that might set it right.
                                          Peace
                                          • N Offline
                                            Niffler
                                            Greetings All,
                                            I was thinging again about a phenomenon from Bolt-Maker. What doesn't make sence to me is that if I deleted Bolt-Maker.rb from the SketchUp/Plugins folder, shutdown my computer, purged my RAM, rebooted Windows, downloaded a "new" copy Bolt-maker.rb from sdmitch.blogspot.com, then reinstalled that program into the SketchUp/Plugins folder, fired-up SketchUp 8, clicked 'Plugins' on the menu bar, then clicked Bolt-maker, you would expect it to work wouldn't you? Of course you would expect it to work?
                                            Nope!
                                            My question is: what the heck is happening that is telling my computer that the Bolt-maker program is still broken?
                                            • 2 / 6
