    [Plugin] Bolt Maker (Final Update 7-Feb-2012)
    101 Posts 31 Posters 93.5k Views 31 Watching
    • HumpmetwiceH
      Humpmetwice
      I also love this plugin but while using it, it messes up the hole some how. See image to see whats happening.
      Thanks Kurt
      • sdmitchS
        sdmitch
        @jonorman said:
        :berserk:
        Dang that is sweet, just like the one i`m used to at work...
        couple of questions. can the bolt be made more "realistic" ?? Is the bolt made by the script or can it pick one from a folder or a "bolt inventory" ??
        Bug: the bolt has reversed faces..
        Again a million thank you for this script.... ☀
        More "realistic"? In what way?
        The bolt is totally made by script.
        Reversed faces. Is that a significant problem?
        http://sdmitch.blogspot.com/
        • sdmitchS
          sdmitch
          Thanks Kurt
          I've never seen that problem before? How often does it occur? At what diameter?
            Jim
            Thanks for this, Sam.
            It happens to me when I bolt 2 of the exact same instances. When I make one of the instances unique, it does not happen.
            Also...
            • sdmitchS
              sdmitch
              Jim, Thanks for the info. That is something I never tested because I assumed the components would be unique since "drilling" a hole in one would effect them all.
                Jim
                Sam, I'm getting this error when trying to bolt through the same instance:
                Error: #<NoMethodError: undefined method distance' for nil:NilClass> C:/Plugins/bolt maker.rb:205:in drill_hole'
                C:/Plugins/bolt maker.rb:148:in `onLButtonDown'
                  Jim
                  I wonder if it would be better to allow the user to select 2 points (using inference) to set the length and direction of the bolt, rather than having the plugin attempt to calculate? I do like pulling off the edges to mark the center; so after this just 2 more clicks to set the length and direction.
                  Also, what if the bolt were made as a Component rather than a Group? Then it could be re-used and accounting for the hardware in the model would become easier.
                  • HumpmetwiceH
                    Humpmetwice
                    Works Great now but I do like Jim's idea about making it a component instead of a group but beggers can't be choosey.
                    • sdmitchS
                      sdmitch
                      As I see it, the problem with making the nut and bolt set a component is that you would have to create one for every conceivable diameter and length which wouldn't be any different than creating them as groups. I also see no advantage in requiring 2 additional points to define length and direction. Drilling the hole through the components would be impossible if direction is not perpendicular to the faces. The head of the bolt is always on the first component so the order of selection determines direction.
                      • kenK
                        ken
                        I am curious, why does the objects to be bolted need to be a component? I use component, but I also use groups and was just wondering why it only would work on a component and not a group.
                        Thanks for the plugin.
                        Ken
                        • sdmitchS
                          sdmitch
                          Because of the nature of components, how could you possibly drill a single hole through the two copies. There is only one situation where that is possible and that is if two instances are stacked and orientated exactly the same. Otherwise, at best you get a bolt on one end and an empty hole on the other.
                          • sdmitchS
                            sdmitch
                            Ken
                            Primarily because that's what the original request was. Groups and components are very simuliar but does require some additional code to handle either.
                              Jim
                              What I am trying to suggest is there are too many edge cases - too many ways that people need to fasten things together for a plugin to attempt to guess what the user wants. For example, it appears you are assuming there are ever only 2 plates that need bolted together. What if I need 3 plates bolted together? Or if I need a spacer between the plates? By using a 2-point selection procedure for setting the direction and length, you do not need to make any assumptions or guesses - it seems like it would greatly simplify the procedure for placing bolts in all possible cases since the bolt is drawn in the selected direction and length set by the user.
                              True, this will likely complicate hole-cutting, but I'd rather have a quick way to place bolts before worrying about getting the holes cut.
                              • kenK
                                ken
                                I show bolt in all my designs, some time is the hundreds. Yes I would like to have a method of making a bolt with just a line. With the line giving direction and length. I use the bolt dynamic component, and I have to work around showing bolts that not fully engage, in other words, just above the selection but not tightened. I use the plugin drill to make the holes, and just being able to connect multiple pieces together, than add the bolt above the pieces or partly though or completely though would be great.
                                Well, it is a needed plugin.
                                Again thank you.
                                • N
                                  Niffler
                                  Greetings, ☀
                                  I downloaded "Bolt Maker.rb" and dropped it into the proper plug-in folder and then experienced my first error message after I restarted SketchUp 8.
                                  Error Loading File Bolt Maker.rb
                                  undefined method `file_loaded?' for main:Object
                                  How can I resolve this without using percussion maintenance? 😉
                                  Peace
                                    Jim
                                    Open the file "Bolt Maker.rb" in a text editor - say notepad.exe, then move the following line up roughly 7-8 lines so it appears just after the comment lines (which begin with #) but before any other lines in the file.
                                    require "sketchup"
                                    Save the file, and restart SketchUp.
                                    • C
                                      CalypsoArt
                                      Great plugin. Love the ability to pull from the sides to set position. I got a bug splat but can't remember exactly where in the process. Worked fine after that. I Agree with others it would be nice to be able to pic a top face and a bottom face in a set of stacked components/groups and have the plugin drill/cut through them all. But I can work with it as is.
                                      Thanks.
                                      • sdmitchS
                                        sdmitch
                                        CalypsoArt,
                                        Stack away. Just posted update allows that and it drills holes through them all.
                                        The bug splats and failures are caused by the usually benign start_operation statements.
                                        I got a lot of those also until I removed them.
                                        • sdmitchS
                                          sdmitch
                                          OOPS!!!! Sorry Bolt Maker fans. Dispite what I thought was adaquate testing, I found a problem while playing around with the plugin this morning. It has been corrected and a new copy posted.
                                          • N
                                            Niffler
                                            Help!! I can't get bolt maker to run anymore.
                                            1. I have used both copies of bolt maker: bolt maker and bolt maker 7.
                                            2. I run the programs in SketchUp 8.
                                            3. I have run successfully, both versions (obviously, one at a time) in either SketchUp/Plugins or SketchUp/Tools folder. Both copies had worked in either folder. FYI
                                            4. It took me several dozen retrys to figure out those terrible instructions; and in one glorious moment, it worked. I went to repeat my success AND...nothing! I clicked the Bolt-maker icon in the toolbar and then...nothing. I clicked the Bolt-maker icon a number of times. It stopped working.
                                            5. I downloaded and tried out new copies in place of the others in the SketchUp root folder and still nothing. I even reversed the file's location from Plugins folder to the Tools folder, still nothing happened.
                                            6. I even created two, new group components, thinking that it was probably the models. Nope!
                                            7. I went to another older system where I had backup copies of both files of bolt maker and of SketchUp 8. I fired up SketchUp and lo-and-behold, bolt maker worked. I mucked about with the instructions for many times (don't ask me how many), then the same thing happened on that computer: the Bolt-Maker button died.
                                            The only thing I can figure happened with this challenge is that this program is crippleware, that is a program that deactivates itself after a number of reactivations. This program probably detects: "This person is an idiot! It is much too dangerous to be in the hands of such a simpleton." DELETE DELETE DELETE LOL
                                            Can someone help with this?
                                            • 1 / 6
