    WebDialog.set_html fails under Safari 5.0.6
    111 Posts 7 Posters 29.9k Views 7 Watching
      @dan rathbun said:
      I remember that execute_script suffered from a string size limitation on Mac?
      Well there's always injecting a external script file.
      dlg.execute_script %[
      >   var xx = document.createElement('script');
      >   xx.type = 'text/javascript';
      >   xx.src = "file;//some/path/to/script.js";
      >   document.getElementsByTagName('head')[0].appendChild(xx)
      But we wanted to send the HTML itself to the webdialog for replacement as a way to avoid temp files.
      • Dan RathbunD
        Dan Rathbun
        Right ok.. same kind of deal.
        assume you have a block of html text in Ruby htmltext
        1. You open the dialog with a blank body template using set_file()
        2. Then create a Js var called bodytext (as above)
        3. Successively...
          ... take chucks of htmltext and assign to htmlpart
          ... and use execute_script("body_text += '#{htmlpart}'")
          .. or similar until all the Ruby-side text has been transfered.
        4. then call execute_script("document.body.innerHtml=body_text;")
        I'm not here much anymore.
          Yea, I was planning on adding a large data pump to my library anyway. But I need to work out what the data limit is... Hopefully I can just send a very large string from ruby and compare it in JS.
            Actually, what I really hope for is that at_exit works under OSX.
            • Dan RathbunD
              Dan Rathbun
              @thomthom said:
              Cursed - this is more troublesome than I thought.
              Under Windows I can clean up all temps by using AppObserver.onQuit - but under OSX it appear to never trigger.
              So then there's no way under OSX that my proposed workaround for the Instance Observer can work for SU8.
              Makes me wonder if "they" just turned off the onQuit() callback (for OSX,) as a 'quick-temporary-fix' for the BugSplat! on close issue?
                hm... when was that fix issued? I'd like to try with an older SU to check.
                • Dan RathbunD
                  Dan Rathbun
                  I am speculating... remember during v8 beta the Instance Observer OSX BugSplat! on close without saving the model first?
                  It was not fixed for 8.0M1.
                  However you have that onQuit() works for v7.1 on OSX.
                    I tried onQuit and at_exit on OSX SU 7.1.6859 and I could not get them to trigger either...
                    • Dan RathbunD
                      Dan Rathbun
                      It's a bit confusing to have your Observer table combined with both platforms, have you thot about having a table for each platform?
                      • Dan RathbunD
                        Dan Rathbun
                        And just to be clear, your testing using the Ruby ver that ships with the Sketchup version? (v1.8.5-p0)
                        What happens if your change the Sketchup Ruby symbolic links on the Mac to a newer Ruby install (v1.8.6-p287 or higher?)
                        • Dan RathbunD
                          Dan Rathbun
                          And also you might try to trap the SystemExit exeception, which is supposed to be called, unless Google used exit!() in which case your out of luck.
                          I'm not sure if Kernel.set_trace_func will catch a call to exit!() or not.
                            Wouldn't having two tables make it harder to get an overview of what observers has issues?
                            Yes - I only test SketchUp out of the box. And that is complicated and time-consuming enough...
                            • Dan RathbunD
                              Dan Rathbun
                              I wish someone could make a one-click dmg installer for Sketchup Mac that would bring their Ruby up to par with the PC edition.
                              • fredo6F
                                The problem seems to be in all versions after 5.0.6
                                A user encountered the problem on Safari Version 5.1 (7534.48.3): images not shozing and Update (via xmlhttprequest not working)
                                Fred
                                • P
                                  Pout
                                  I'm a bit confused here.
                                  So if you would use set_file then all should work fine?
                                  I'm using that method and it loads a html file but the linked js files inside do not seem to work.
                                  They do however work when just opening the html file with Safari. (So not in a webdialog)
                                    Yes, set_file should work. Got a sample of what is not working?
                                    • P
                                      Pout
                                      here you go
                                      unzip, put the rb in plugisn and the Grid directory to
                                      thx for testing!
                                      test.zip
                                      • P
                                        Pout
                                        and in SU you can launch by TESTOLA.testing in ruby console
                                          driven
                                          With your WebDialog in Safari 5.0.6 Web Inspector shows this error
                                          TypeError: 'null' is not an object (evaluating 'navigator.userAgent.match(/(?:KHTML\D*|VERSION\D*)(\d[\d\.]+)/i)[1]')
                                          I'd look into that to start.
                                            hmm... why are you sniffing the userAgent string? It's preferred to test for features instead of testing the user agent string.
                                            • 5 / 6
