    WebDialog.set_html fails under Safari 5.0.6
    111 Posts 7 Posters 32.4k Views 7 Watching
      I got lots of Fredo tracelogs in my Window folder...
        @driven said:
        SketchUpUndo0.log is an on quit event
        Doesn't seem to trigger from the Ruby API...
          I'm finding no way to get anything to trigger when OSX exits. onDelete model triggers when you close a model, but not upon exit. It's like all Ruby callbacks are stopped when SU exits under OSX.
            driven
            sorry if I'm barking up the wrong tree, but this bit of code overwrites an existing file.
            could something similar not work for .html's
            	@sfile = "/Library/Application\ Support/Google\ SketchUp\ 8/SketchUp/plugins/audit_mac_ruby/audit.txt "
            		@debug_file = File.new(@sfile, "w")
            • fredo6F
              Normally LibFredo6 keeps the last 10 or 15 log files (purge is done above).
              This is to allow consulting traces from previous sessions.
              • fredo6F
                @thomthom said:
                Cursed - this is more troublesome than I thought.
                Under Windows I can clean up all temps by using AppObserver.onQuit - but under OSX it appear to never trigger.
                You should not worry too much with the temporary file.
                You create it with a unique name and then delete it when you close the dialog box (I guess you have a hook in the on_close() event).
                And if there are a few files remaining, the user or the system will purge them at some points.
                The question I had on temp file is whether the html file should absolutely be in the ENV["TMPDIR"] folder or in any folder (like /tmp)
                  driven
                  I just did a test and
                  @tempfile = File.join( "/Library/Application Support/Google\ SketchUp\ 8/SketchUp/plugins/TT_Lib2/webdialog", filename )
                  runs the same as the former, but I can find it easier...
                    I'm thinking I might not need temp files at all. I just need to send the HTML to the webdialog via .execute_script to a proxy HTML document that replaces the content.
                      driven
                      another thing...
                      I decided to check the html temp files from both paths to see if they where identical (they are)
                      I also get this identical message when opening in TextWrangler.
                      never seen that for any other html files, so I checked Fredo's tmp htmls as well and they are fine.
                      here's the other file, contents is the same
                      EDIT- it may be this <title>CleanUp� unidentified character(in TextWrangler)
                        @driven said:
                        If the file is in the system temp then it's more likely that stray files will be removed.
                        @driven said:
                        another thing...
                        That's because I have sent a ³ character in ANSI format instead of UTF-8. It's nothing important.
                          driven
                          if your proxy is in your webdialog folder, all your links are then relative... I'd vote for that... if I can
                            w = WebDialogPatch.new( 'Hello World' ) w.show w.set_html( 'Lorem Ipsum' ) w.close w.show # HTML file would now be missing...
                              • fredo6F
                                I remember that execute_script suffered from a string size limitation on Mac?
                                Maybe this is fine now.
                                  driven
                                  by proxy HTML document I assumed you meant a html file that is basically populated by your current window.html + ruby, which is then sent to web dialog and is then updated via ruby.
                                  if that's what you mean, and it lived beside window.html can't all your links then be relative i.e. href=css/ui.css, src=js/base.js, etc...
                                    Arrgh - yea I've heard rumors about that. Cursed how troublesome the WebDialog should be under OSX!
                                    Yes. In fact, I made them relative in 2.5.5 because they relied on the BASE tag in the header which pointed everything to the root dir of the webdialog.
                                    • Dan RathbunD
                                      Dan Rathbun
                                      Well there's always injecting a external script file.
                                      dlg.execute_script %[
                                        var xx = document.createElement('script');
                                        xx.type = 'text/javascript';
                                        xx.src = "file;//some/path/to/script.js";
                                        document.getElementsByTagName('head')[0].appendChild(xx)
                                      I'm not here much anymore.
                                        But we wanted to send the HTML itself to the webdialog for replacement as a way to avoid temp files.
                                        • Dan RathbunD
                                          Dan Rathbun
                                          Right ok.. same kind of deal.
                                          assume you have a block of html text in Ruby htmltext
                                          1. You open the dialog with a blank body template using set_file()
                                          2. Then create a Js var called bodytext (as above)
                                          3. Successively...
                                            ... take chucks of htmltext and assign to htmlpart
                                            ... and use execute_script("body_text += '#{htmlpart}'")
                                            .. or similar until all the Ruby-side text has been transfered.
                                          4. then call execute_script("document.body.innerHtml=body_text;")
                                            Yea, I was planning on adding a large data pump to my library anyway. But I need to work out what the data limit is... Hopefully I can just send a very large string from ruby and compare it in JS.
                                            • 5 / 6
