    WebDialog.set_html fails under Safari 5.0.6
    111 Posts 7 Posters 29.9k Views 7 Watching
      driven
      @TT new patch works on Safari 5.0.3 as well, updated above... and temp files also don't purge.
        It appears that the Garbage Collector is no invoked when SketchUp exits under OSX - as oppose to under Windows. Gonna have to look for another way to cleanup.
          Cursed - this is more troublesome than I thought.
          Under Windows I can clean up all temps by using AppObserver.onQuit - but under OSX it appear to never trigger.
            driven
            SketchUpUndo0.log is an on quit event, so it is possible. and I think Fredo's DebugLog class purges the old trace files in his tmpdir
            /Library/Application Support/Google SketchUp 8/SketchUp/plugins/LIBFREDO6_Dir_40/Lib6PluginDialogs.rb line1047
              I got lots of Fredo tracelogs in my Window folder...
                Doesn't seem to trigger from the Ruby API...
                  I'm finding no way to get anything to trigger when OSX exits. onDelete model triggers when you close a model, but not upon exit. It's like all Ruby callbacks are stopped when SU exits under OSX.
                    driven
                    sorry if I'm barking up the wrong tree, but this bit of code overwrites an existing file.
                    could something similar not work for .html's
                    	@sfile = "/Library/Application\ Support/Google\ SketchUp\ 8/SketchUp/plugins/audit_mac_ruby/audit.txt "
                    		@debug_file = File.new(@sfile, "w")
                    • fredo6F
                      Normally LibFredo6 keeps the last 10 or 15 log files (purge is done above).
                      This is to allow consulting traces from previous sessions.
                      • fredo6F
                        You should not worry too much with the temporary file.
                        You create it with a unique name and then delete it when you close the dialog box (I guess you have a hook in the on_close() event).
                        And if there are a few files remaining, the user or the system will purge them at some points.
                        The question I had on temp file is whether the html file should absolutely be in the ENV["TMPDIR"] folder or in any folder (like /tmp)
                          driven
                          I just did a test and
                          @tempfile = File.join( "/Library/Application Support/Google\ SketchUp\ 8/SketchUp/plugins/TT_Lib2/webdialog", filename )
                          runs the same as the former, but I can find it easier...
                            I'm thinking I might not need temp files at all. I just need to send the HTML to the webdialog via .execute_script to a proxy HTML document that replaces the content.
                              driven
                              another thing...
                              I decided to check the html temp files from both paths to see if they where identical (they are)
                              I also get this identical message when opening in TextWrangler.
                              never seen that for any other html files, so I checked Fredo's tmp htmls as well and they are fine.
                              here's the other file, contents is the same
                              EDIT- it may be this <title>CleanUp� unidentified character(in TextWrangler)
                                @driven said:
                                If the file is in the system temp then it's more likely that stray files will be removed.
                                @driven said:
                                another thing...
                                That's because I have sent a ³ character in ANSI format instead of UTF-8. It's nothing important.
                                  driven
                                  if your proxy is in your webdialog folder, all your links are then relative... I'd vote for that... if I can
                                    w = WebDialogPatch.new( 'Hello World' ) w.show w.set_html( 'Lorem Ipsum' ) w.close w.show # HTML file would now be missing...
                                      • fredo6F
                                        I remember that execute_script suffered from a string size limitation on Mac?
                                        Maybe this is fine now.
                                          driven
                                          by proxy HTML document I assumed you meant a html file that is basically populated by your current window.html + ruby, which is then sent to web dialog and is then updated via ruby.
                                          if that's what you mean, and it lived beside window.html can't all your links then be relative i.e. href=css/ui.css, src=js/base.js, etc...
                                            Arrgh - yea I've heard rumors about that. Cursed how troublesome the WebDialog should be under OSX!
                                            Yes. In fact, I made them relative in 2.5.5 because they relied on the BASE tag in the header which pointed everything to the root dir of the webdialog.
                                            • 4 / 6
