    WebDialog.set_html fails under Safari 5.0.6
    111 Posts 7 Posters 24.6k Views 7 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @dan rathbun said:
      Has anyone logged this with Google ?? I'd think they'd wish to release patches if Safari 5.0.6 will break WebDialogs on all Mac versions.
      TT ?
      I'm not here much anymore.
        I've not logged anything yet. Been bugging a couple to see if they could shed some light.
          Driven: I implemented a patch. Update to TT_Lib 2.5.5
          http://forums.sketchucation.com/viewtopic.php?f=323&t=30503
          • fredo6F Offline
            To all,
            Can we summarize what is the problem and what could be the workaround.
            From what Driven has signaled, there are problems in both 5.0.3 and 5.0.6 Safari versions.
            Also it would be good to hear from the Google SU Team, as they can perfectly implement a central solution that makes set_htmlwork.
              Dan Rathbun
              OK.. then your on "top of this"... I suppose "they'll" ask you to log a formal bug # if they don't do it themselves.
              @Fredo.. agreed, and I hope they'll monitor this topic for ideas.
                I tried to summarize here: http://forums.sketchucation.com/viewtopic.php?f=180&t=39842&p=352375#p352375
                Not sure about 5.0.3 - but there has been some discussions on how to format the URLs linking to local resources. We found that file:/// worked on both platforms.
                  Submitted!
                  • fredo6F Offline
                    The issue with file:// on Mac/Safari was already there since the beginning.
                    So at the end, the workaround is just to use set_file on Mac
                    • which works on Safari 5.06 (and to be confirmed on 5.03)
                    • which also works on previous versions, though set_html still works in Safari up to 5.01
                    Is this correct?
                      I've used a mix of .set_html and .set_file in my plugins and have not had any problems until 5.0.6 came out.
                        @driven said:
                        TT_SelectionToys works EXCEPT for 'cheat sheet' which shows as about:blank and loads nothing, not even error messages, so may be a different issue.
                        I believe it's a different issue as it's an older plugin. Lets look away from this one.
                        @driven said:
                        TT_CleanUp3 all now work with the latest patch EXCEPT temp file are not purged on close of dialog or SU.
                        Really? They should be erased when SketchUp is exited. hmm... Gonna look at it again on my Mac.
                          driven
                          on my computers, both running OSX 10.5.6.
                          under Safari 5.0.3
                          Fredo's WD all work correctly.
                          TT_CleanUp3 all works with original file (will test new one now) UPDATE: new file works
                          under Safari 5.0.6
                          Fredo's WD failed to load images and failed on check for updates . with the temp file test, it will now switch from about:blank if a manual reset is induced, It THEN works correctly.
                          TT_SelectionToys works EXCEPT [as above]
                          temp files accumulate...
                          from my testing .set_file and .set_url seem to be interchangeable (with the corrected path), i.e. the same resource from the same source can be used with either method.
                            driven
                            @TT new patch works on Safari 5.0.3 as well, updated above... and temp files also don't purge.
                              It appears that the Garbage Collector is no invoked when SketchUp exits under OSX - as oppose to under Windows. Gonna have to look for another way to cleanup.
                                Cursed - this is more troublesome than I thought.
                                Under Windows I can clean up all temps by using AppObserver.onQuit - but under OSX it appear to never trigger.
                                  driven
                                  SketchUpUndo0.log is an on quit event, so it is possible. and I think Fredo's DebugLog class purges the old trace files in his tmpdir
                                  /Library/Application Support/Google SketchUp 8/SketchUp/plugins/LIBFREDO6_Dir_40/Lib6PluginDialogs.rb line1047
                                    I got lots of Fredo tracelogs in my Window folder...
                                      Doesn't seem to trigger from the Ruby API...
                                        I'm finding no way to get anything to trigger when OSX exits. onDelete model triggers when you close a model, but not upon exit. It's like all Ruby callbacks are stopped when SU exits under OSX.
                                          driven
                                          sorry if I'm barking up the wrong tree, but this bit of code overwrites an existing file.
                                          could something similar not work for .html's
                                          	@sfile = "/Library/Application\ Support/Google\ SketchUp\ 8/SketchUp/plugins/audit_mac_ruby/audit.txt "
                                          		@debug_file = File.new(@sfile, "w")
                                          • fredo6F Offline
                                            Normally LibFredo6 keeps the last 10 or 15 log files (purge is done above).
                                            This is to allow consulting traces from previous sessions.
                                            • 4 / 6
