    [Plugin] 2dBoolean ver1.3.1 beta UPDATE 20 dec 2013
    88 Posts 8 Posters 59.2k Views 8 Watching
      β˜€
      At last I can see the issue too. πŸ˜’
      I was missing some points in one of your earlier posts. 😳
      So... after all of the edges2go are collected and erased we might still have some 'never-split' faces over 'holes' that will still need to be removed, or also such faces over 'holes' that are abutting a 'perimeter' of the face.
      Therefore we MUST go back to earlier ideas... πŸ˜’ πŸ˜’
      After the midpoint tests of the group's edges and the 'edges2go' tidy up [which WILL remove a lot of unwanted dross] we MUST examine the group's faces in turn.
      We can get a point on each of these faces and test it using face.classify_point(pt) if it returns as 'off the face' [i.e in a hole] then we .erase! it.
      Finally we then do a final 'tidy up' - i.e. removing faceless-edges left after unwanted faces are removed.
      Here's the whole test/fix...
      faces=[] group.entities.each{|e| faces << e if e.class==Sketchup::Face } tedges=[] faces.each{|gface| pt=gface.bounds.center.project_to_plane(face.plane) if face.classify_point(pt)==Sketchup::Face::PointOutside tedges << gface.edges gface.erase! end } tedges.flatten! tedges.uniq! tedges.each{|e| e.erase! if e.valid? and not e.faces[0] }
      Once that's all done we can worry about making the group into the gluing/cutting component, with corrected axes as before... 😲
      • jolranJ
        jolran
        He he! No worries πŸ˜„
        Sometimes when I reread my posts I wonder what the heck I was talking about. That's why I post so many pictures πŸ˜„ To clear things up.
        This new code of yours look very nice. Can't wait to test it out.
        tedges.uniq!
        Haven't seen that command before? To remove duplicates? Need to read more about pure Ruby...
        I was thinking of putting in the option to make group instead of component, should one wish. Could be useful if the user only has edges with no faces.
        Thanks a lot for your help, TIG!
        • jolranJ
          jolran
          I'm having trouble with this part of the code. Maybe should add some parameters to it?
          faces.each{|gface|
          if face.classify_point(pt)==Sketchup;;Face;;PointOutside
          gface.erase!
          If you look at the picture, you will see that it might not work in all cases with that code.
          Especially when having big faces.
          In the earlier posts I was trying to figure out a way to erase faces more selectively.
          By using IF the FACES center==HOLES center >> erase.faces! (Simplified code)
          However, when I did that, sometimes there where errors. Or faces that would not get deleted.
            The .flatten! combines nested arrays
            The .uniq! removes duplicates
            Also [not applicable to THIS tool] .compact! would remove 'nil' array elements, or .sort! puts the list 'in order'...
            Now to the chase.........
            I also see this 'unexpected' possibility of faces we want to keep being false-flagged as 'holes'.
            So we need to trap for real 'hole' faces - the outer_loop edges will always have two faces...
            faces2go=[]### rather than erase as we go we'll collect them...
            faces.each{|gface|
              ### we skip the gface IF it's NOT a 'hole'
              ### just 1 one-faced edges is enough for != hole
              hole=true
              gface.outer_loop.edges.each{|e|
                if e.faces.length==1
                  hole=false
                  break
              next if not hole
                faces2go << gface ### save them up
            THEN erase_entities on faces2go and then erase! any of the tedges that don't have a face...
            • jolranJ
              jolran
              πŸ‘ Great to know. Will be useful.
              Your code works! Almost
              Like with the method I used before(face.clone holes.centers), I'm experiencing some faces don't get erased. (Having a model that look like a swiss cheese)
              I wonder why this happends. Your code should be working...
              For ex. I run the plugin once. Maybe 3 faces are not deleted but the edges are trimmed to fit. I run the plugin again with the component selected, then it is OK!
              It is like it needs another rescue operation? πŸ˜• Or maybe run the last command twice? Seems excessive..
              I will check my code as well. Been moving snippets back and forth, it need some cleaning up.
              And another thing. Was it GO for NOT using faceclone? Intersect with SS or Glue face?
              I havent implemented that yet, still using face.clone. Shouldent matter in this regard...
              • jolranJ
                jolran
                Think it is ok...
                Breaks sometimes, but only if using a simple squarish component. One have to consider what this tool is going to be used for.
                  Try intersecting the group.entities with the face.edges+[face] twice ?
                  Will make it slightly slower... BUT it might fix the potential glitch ??
                  • jolranJ
                    jolran
                    Yes TIG, I think you are on the right track there! Good thinking.
                    I was about to report that intersection is not working properly. One cannot erase a face if it can't be selected πŸ˜„
                    This can be due to my code being a bit shabby at the moment, moving stuff back and forth as mentioned.
                    I will "clean it" and report back later.
                    • jolranJ
                      jolran
                      2 intersection gave a big improvement! Not 100% accurate, but I think it's good enough. One can force it by selecting the component and running the plugin again. It almost always sort out the fuzz, then.
                      Still intersecting with face.clone. Had some problem with intersecting with Sketchup.active.model selection...Expecting entitiy something..
                      Speed is better, even with 2 intersections πŸ˜‰
                      Did a test with a "heavy" component, ver 1.1 VS current dev.code. VER 1.1: 41.483 seconds. current dev.code: 4.278 seconds 😲
                      Do we move forward, TIG? Or delve deeper in this problem, to make perfection?
                      • jolranJ
                        jolran
                        Ok, I have put out the new version 1.2 for testing. So you have something to play with this weekend.
                        It should be an improvement..
                        KEEP THE OLDER VERSION AT HANDS! I won't be able to fix issues this weekend πŸ˜„
                        Thank you TIG for all the help.
                        I haven't optimized the iterator exactley as TIG suggested, so that can be improved...
                        There are more issues to deal with later on.. But let's not spoil all the fun.
                        • andybotA
                          andybot
                          Joel, thanks so much for this plugin!! I have 2d elevations that I needed to glue to a massing, and this works absolutely perfect for my needs. Good work!
                          Andy
                            AcesHigh
                            can anyone check if this pluging works with meshes?
                            when importing several pieces from GoogleMaps, the pieces usually end overlapping each other, causing texture errors.
                            You cant use 3D boolean because obviously, meshes, are not solids.
                            So I would usually "zorro" the different meshes, and cut the parts that overlap. Obviously, a HUGE work when you are dealing with dozens of different GoogleEarth imported meshes. If this plugin works with those, it will be great!
                            • jolranJ
                              jolran
                              Hey, I missed some posts in here!
                              Andybot. I'm glad someone have use for this plugin! Appreciate it!(we all know TIG's part of this of course)
                              AcesHigh.
                              I've seen your request in other post regarding this subject. Like I said. I think it lies more in the 3d domain, since the surfaces are not flat.
                              IF the intersecting geometry would be flat at intersectionpoints, 2dBoolean should activate. But I see your case you would need a subtraction-algorythm.
                              At this point 2dboolean only subtracts geometry outside the face it's lying on(or selected face).
                              What you are asking for is really needed, and I will see what can be done about that in the future. I'm kinda busy at the moment.
                              Have to deal with Hatchfaces webdialog, which unfortunaly proves very difficult.
                              I thought I only had to learn Javascript, HTML, CSS and JQUERY πŸ˜‰ . But there is need for some JSON and maybe AJAX as well. Kinda much required to make a simple dialog if you ask me.
                              • jolranJ
                                jolran
                                Nice update.
                                But! If you are gonna further developp this tool, and display it in this thread with my icons included. Please don't scramble the code, so other can benefit from your code like you did on mine and Tig's.
                                Besides your plugin will be lost in this thread posting it here.
                                Best regards.
                                • JuantxoJ
                                  Juantxo
                                  Sorry, but actually I prefer the code scrambled. The code is not very optimized because I did it to translate to C after.
                                  I don't use any line of your code. I used a simplicans planar theory. (I taked your one icon, feel free of use my icons)
                                  Best regards
                                  • jeff hammondJ
                                    Best regards
                                    watch out, the πŸ€“ 's around here will unscramble your code and make sure you're telling the truth πŸ’š
                                    • jolranJ
                                      jolran
                                      Ok. If you say so.
                                      That's ok. I don't mind that. 2 min PS for me.
                                      Ok, about that. I find it somewhat strange to post stuff for free, scrambled. thats not very helpful for other programmers.. Personally I rather tell to much then nothing at all.
                                      • JuantxoJ
                                        Juantxo
                                        Actually I'm working in 2D boolean of polygons in Sketchup because I need for other stuff. I did this plugin using simplicians theory.
                                        May be could be usefull for someone.
                                        You need to select two groups with a general planar polygon.
                                        General planar polygon = A single polygon or a polygon consisting of a set of non-intersecting single polygons.
                                        DOWNLOAD 2d_simplex_bool.rbz
                                        http://skelion.net/bool/2dbool.jpg
                                        • jolranJ
                                          jolran
                                          New version 1.3.1 added:
                                          404 Not Found
                                          (sketchucation.com)
                                          Whole lot is rewritten so there may be lot of things broken. I suggest a lot of testing and report back bugs and wishes πŸ˜„
                                          Intersections should now be a Little quicker. And some new stuff as well.
                                          Make sure to read the manual in second post.
                                          Will try and add to pluginstore later.
                                          • jolranJ
                                            jolran
                                            Manual
                                            Since ver 1.3.1
                                            manual_2dBoolean.zip
                                            • 4 / 5
