    [Plugin] 2dBoolean ver1.3.1 beta UPDATE 20 dec 2013
    88 Posts 8 Posters 57.6k Views 8 Watching
    • jolranJ Offline
      jolran
      Wow, TIG! Will be interesting to test your new approach.
      BTW:
      tr=Geom::Transformation.new()
      group.entities.intersect_with(true,tr,group.entities,tr,true,(face.edges+[face]))
      You then then collect all of the edges in the group.
      Make an array - edges2go=[]
      Test each edge in turn.
      pts=edge.start.position
      then
      pte=edge.end.position
      against face.classify_point(pts) etc
      Isent this what I'm doing already? Except (face.edges+[face)] is a group(gp3) for me?
      Or did I misunderstand you? Anyway, that may not be of relevance for fixing the problem.
      I think the main problem is that, after the collection of points "outside" face I have been using if edge.used_by? point to select and erase the edges. Passing on the point as argument. (In reality point gets converted to vertices). That way I can never erase an edge if it's not used by "something".
      I guess your way is to tell Sketchup. If point is on edge? Put that edge in the "erase" array. Is that correct?
      This all have to be done in an iterator, right? With some conditionals inside the iterator. I spent all day yesterday to find suitable API methods to fit the need, but really need some IF, NOT and OR statements? Or am I wrong here in my assumption?
      I guess the iterator will be faster if the statements are made outside..
      I will try those things and pt=tface.bounds.center.project_to_plane(face.plane) and the edge.midpoint test as well.
      Again, thanks a lot!
      • jolranJ Offline
        jolran
        Wait. I think I got it backwards, TIG..
        I was looking in the API, and the closest thing to compare an point on edge was, point3d on_line.
        What I could see.
        Then realized, maybe you meant that there should be only 1 iteration, in edge.array?
        Iterate through edge.array, do the tests. If true or false(depending on the test) then edges2go << edge ?
        After that, erase arrays entitiesedges2go?
        Is it something like that what you had in mind, TIG?
          NO, NO, NO! πŸ˜’
          When you do face.classify_point(pt) you get ONE of a list of possible results:
          http://code.google.com/apis/sketchup/docs/ourdoc/face.html#classify_point
          The list is
          0: Sketchup::Face::PointUnknown (indicates an error),
          1: Sketchup::Face::PointInside (point is on the face, not in a hole),
          2: Sketchup::Face::PointOnVertex (point touches a vertex),
          4: Sketchup::Face::PointOnEdge (point is on an edge),
          16: Sketchup::Face::PointOutside (point outside the face or in a hole),
          32: Sketchup::Face::PointNotOnPlane (point off the face's plane). So if the result of either of the vertex.position points is Sketchup::Face::PointInside then it's OK.
          If either are Sketchup::Face::PointOutside it has to GO!
          If both are Sketchup::Face::PointOnVertex OR Sketchup::Face::PointOnEdge then it might be OK - you test for the midpoint etc and if it's Sketchup::Face::PointOutside it has to GO!...
          πŸ˜•
          Iterate the edges just once and collect all that fail; then erase them en mass...
          • EarthMoverE Offline
            EarthMover
            @tig said:
            NO, NO, NO! πŸ˜’
            Tough on your students as all great masters are! I'm just picturing the huge face palm from a steamed but brilliant TIG as he has to constantly communicate with us "less brained" folk. πŸ˜„ Seriously, though your patience and constant help is much appreciated. I've been trying to follow both threads with you and Joel going back and forth and I'm starting to pick up a little of what is going on, although it's still all over my head.
            Content Creator at Skapeup
              I need my dinner and a drink! πŸ˜„
              • jolranJ Offline
                jolran
                NO, NO, NO!
                πŸ˜„ I think I explained the question poorly. SWEnglish at it's worst. Haven't you seen the Swedish chef in the Muppet show?
                I know about http://code.google.com/apis/sketchup/do%20...%20sify_point Im already using it in the code πŸ˜‰
                The question was. Only 1 iteration?
                If you have looked at my code you see that I first collect edge.start, edge.end and edges. THEN I collect the points outside the face. After that I collect edges that are connected to those vertices. So all in all 3 iterators for just 1 purpose.
                What I meant about point3d on_line, was that WHEN I was looking at that method in the API I realized I should use 1 iterator, NOT that I should use point 3d on_line. That's a whole different matter πŸ˜„
                You bet! I'm deeply greatful.
                Therefore Here Ya go!
                  No... try to simplify your code. πŸ˜„
                  I'm trying to suggest a streamlined approach, that both faster and 'easier to get your head around'.
                  After the intersecting etc... edges will be split by every edge of the face and then these possibly split edges will either fall 'on' the face, 'off' the face, OR with both vertices on the face's perimeters...
                  Collect all of the edges inside the group.
                  Check each edge in turn, looking at its two vertices' positions and seeing where they are 'on' the face.
                  Some edges are clearly 'on' - some are clearly 'off'... from testing a vertex.position in the face.classy_point() method... There are several possible results but careful interpretation will prove VERY useful...
                  If there are questionable edges [with both vertices on the face's edges or face's vertices] you can check if that edge is 'spanning' a convex or concave corner. If it's 'concave' the midpoint of the edge is not on the face so it has to be erased later on...
                  So just do the tests as I described... and make an array of 'edge-failures'.
                  Once you've been through all of the edges in the group you can then erase the array of edge-failures 'en mass'.
                  Done - the group is trimmed to every perimeter of the face - including its 'holes'.
                  Because faces need edges they'll also go with the 'removed edges'.
                  this is much simpler... πŸ˜„
                  • jolranJ Offline
                    jolran
                    I will try to do my best. I think I know now what you mean. If I do it right, I think we will see some speed improvements as well.
                    Finally time to do some coding, been preoccupied with bunch of boring things today.
                    Off to work πŸ˜„
                    • jolranJ Offline
                      jolran
                      Well I think we are back to par with this method!
                      And it seams a whole lot faster. Haven't tried on heavy geometry. But It really feels faster.
                      It seams to erase edges as it should be. And on the + side edges inside holes get's erased, which is really good.
                      Actually point outside is all you need. I don't think there is any need to test on every scenario?
                      I've set up the iterator like this. Where gp2edge is edge.array and comparefaces are the face to be used in classify point.
                      Names will get shorter later on. I think it's good when workin on the code to have explaining names..
                       gp2edge.to_a.each{|edge|
                                    comparefaces.to_a.each{|face|
                      	                    if face.classify_point(edge.start)==Sketchup;;Face;;PointOutside and
                                                 face.classify_point(edge.end)==Sketchup;;Face;;PointOutside
                      						   gp2ptogo << edge
                      						if face.classify_point(edge.start.position.offset(edge.line[1], edge.length/2))==Sketchup;;Face;;PointOutside
                      						   gp2ptogo << edge
                      Now if we could just get rid of the faces in the holes. I'm gonna try pt=tface.bounds.center.project_to_plane(face.plane) and see what happends....
                        Testing for one of the vertex 'points outside' the face will remove most unwanted edges... BUT imagine this... in a face's hole you have an intersected line drawn across if from one edge to the other, you don't want that line BUT neither of the vertices test 'outside' because they are both on the face's edges or vertices... so they pass... just as if they were the perimeter to the form... BUT my suggestion will find these - test the edge's midpoint for being 'on the face' or on a face's edge if it is then it's NOT in a hole so we keep it [i.e. it's a perimeter edge or a line spanning from one edge to another across the face itself rather than across a hole], but if NOT then it's to be erased as it is spanning over a hole...
                        You must test for this scenario.
                        Make a large linear group that will span over a whole face with single lines - without that test they'll all get erased as none of them will have vertices on a face?
                        β˜€
                        πŸ’­ Instead of testing both vertices for every edge test every edge's midpoint [which is easy enough to find!], for being 'on face' [not in a hole] OR 'on edge' OR 'on vertex' - if it passes ANY one of these it's kept, BUT if it passes NONE of these then it goes on the list for erasing at the end - this reduces the number of tests by over a half! It will have noticeable speed improvements and less convoluted checking... πŸ˜•
                        • jolranJ Offline
                          jolran
                          Yes, this code, no? if face.classify_point(edge.start.position.offset(edge.line[1, edge.length/2))==Sketchup::Face::PointOutside]
                          I'm working on the face thing now.. If I get that working there should be some serious testing, and then come back and fix things if needed.
                          And yeah! There are speed increases. I will time it later when doing som more complex geometry.
                          Thanks for this TIG.
                          If this will get OK, Hatchfaces would use this intersection as well. Am doing some JS, html tutorials at the same time as coding πŸ˜‰
                          • jolranJ Offline
                            jolran
                            I don't think we can use face.bounds.center as a point in face.classify method. Eg (face.bounds.center.project_to_plane(face.plane))
                            The center point of a face can be in a hole if the face is surrounding the hole. Hope the pic explains..
                            (the big face gets erased!)
                            The BIG problem was to erase edges inside holes. Wich you fixed πŸ˜„ !!
                            So now when that seams to be working. I'm thinking, recreating the holes a' la face.clone. Then erasing the faces. This would not have been possible before if there where edges inside the hole.
                            Edited: Hm, since there already are faces in the holes, the new one ends up on top and intersection is needed. Could be difficult to retrieve them for erasing after that.. OR rather, it might be excessive to create the faces just the get hold of them..
                              Please reread my posts, we are not talking about finding the center of any faces OR making any 'face clones'... πŸ˜•
                              Just intersect the group's entities with the face.edges+[face] etc.
                              Find all of the edges in the intersected group.
                              Look at each edge...
                              mid=edge.start.position.offset(edge.line[1],edge.length/2)
                              Then use
                              result=face.classify_point(mid)
                              To see if it's on the face or an edge/vertex - if it's not it's earmarked to go!
                              Done.
                              • jolranJ Offline
                                jolran
                                I have reread your posts, over and over πŸ˜„
                                Then use
                                This IS what I'm doing already. Edges are being erased as they should be.
                                						   gp2ptogo << edge
                                						   gp2ptogo << edge
                                The problem is that faces inside holes wont get erased unless we tell'em to. πŸ˜„
                                If you mean to reread your posts to take care of THIS particular problem, I'm sorry did not understand how, by information provided. I'm working at the problem right now, and it should not be as difficult as erasing the edges inside holes.
                                • jolranJ Offline
                                  jolran
                                  Hmm. This problem I havent got a clue about..
                                  The calculation is irregular. Sometimes it fails to erase the required faces..
                                  I don't know If it's worth killing thyself for.. Most of the times there will be plenty of geometry so this calculation isent needed anyway... But I would like to know why comparison fails and if there are any resque methods for these kinds of failures.
                                  • jolranJ Offline
                                    jolran
                                    OK, got it! hopefully
                                    Made a group of faces from face.clone holes. Took their face.bounds.centers.
                                    Then compared cutting.components (faces.center.bounds) to those other centers.
                                    Since center is a point=position I could use ==comparison. Just delete face if they where in the same position..
                                    The code can probably be optimized, but first do some testing and see if it holds!
                                      πŸ˜• Why are you still using 'face clone holes' and 'bounds center' ??? πŸ˜•
                                      You are still making it too complex...
                                      Simply use the group that is to be trimmed and intersect group.entities with the face.edges+[face], placing the results in the group.entities.
                                      If the original thing to 'trim' is a component-instance, as I tried to explain... make it into a group...
                                      group=instance.parent.entities.add_group(instance) instance.explode
                                      NOW inspect the group.entities to get unneeded off-face edges and then remove them [as explained]...
                                      After you're done every thing IF desired then exploding the group will merge it with the face ? [you could erase the face first]
                                      • jolranJ Offline
                                        jolran
                                        Gee!! πŸ‘Š Now I get what you are saying..
                                        Explode the COLORED face.group onto the face.clone. I did not get that part.
                                        OK I will try your method now. Thanks.
                                        • jolranJ Offline
                                          jolran
                                          I'm sorry. Tried to do what you said, or what I think you mean. 😳
                                          But still don't understand how the faces in holes are supposed to disapear when merging them(exploding) onto the face.
                                          This is done after intersection and trimming the edges..
                                          Just to make sure we talk about the same entities here. face.edges+[face] is the face.clone.entities right?
                                          Group is the selected component or group in Sketchup(turned into a group by definition).
                                          Now, to be able to explode the group onto face.clone the group off course have to be inside face.clone group=gp.
                                          Then after all that, the last step is to transform the group and turn it into a cutting component.
                                            We still speak at cross-purposes πŸ˜’
                                            Try to 'forget' everything so far...
                                            Your code already finds the 'face' and 'group' that is overlaid on it that we need.
                                            [if it's a component-instance you first add it to a group [explode it] and use that group].
                                            You can then use the group.entities.intersect_with()...
                                            Add the intersection geometry into group.entities made when it intersects with (face.edges+[face]).
                                            We now have a group containing all of the edges and faces needed.
                                            Some of these are in holes in the face or outside of the face altogether.
                                            To find these iterate all edges in the group.entities, compose an array of any edges which fail a set of face.classify_point() tests on the edge's midpoint - an edge passes and is NOT erased if it is ON the face [in off or in a hole], OR on a face's edge, OR on a face's vertex. Otherwise it fails.
                                            When you have the list of 'edges2go' you erase them en mass.
                                            Now you should have a group with all edges/faces trimmed to the perimeters of the face - including any holes in the face...
                                            At this point the group is laid on the face and will z-fight between the faces.
                                            You can them convert that group into a gluing cutting component with appropriate axes and in the same transformation, glued_to the face...
                                            You can then offer the user the chance to explode the group and merge the group's trimmed faces and the original face...
                                            πŸ˜•
                                            • 3 / 5
