[Plugin] 2dBoolean ver1.3.1 beta UPDATE 20 dec 2013
I did not know that. Good info. Garbage collection? Well in this case all the groups and defs are made within the block, so all good? Of course the group or definition would have to empty..
Of course if you have references to the groups etc then a simple
group.erase!
or inside a start/commit block thegroup.entities.erase_entities(group.entities.to_a)
will both remove that one group [or instance OR definition when entities go!]... orgroups[0]/parent.entities.erase_entities(groups)
[where 'groups' is an array of all temporary groups]... will all work ! -
Cool. So you can erase the group by erasing it's entities while inside a start/commit block? That could be useful, thanks.
Small update. Now If you have a component that have gluing behavior you don't have to select a face to run the plugin. I noticed you run into situations quite often where that is needed. Like when the face is covered and you can not select it.
This will not work with groups.
I think I know why faces in holes don't get erased.
Face.classify point only deals with points/vertices. So if there is a face in a hole inside the face(inner edge loop). Erasing the vertices from face.classify point outside(holes included) does not erase the face in the hole at all times
Don't know how to solve that one yet.. But at least I know what's wrong.
I reckon the plugin is kinda useless, unless I fix this. So it's got high priority now.
I think I am close fixing this hole problem.
So I have made a collection of verticies(from face.clone) That binds the innerloops in faceclone(faces to go)
I want to use that collection to erase the faces in the boolean group.
This does not work(@verts=vertex collection) need to be instance variable or it will get deleted..
cents.to_a.each{|e| if e.class==Sketchup;;Face and e.outer.loop==@verts.loops gp2faces2 << e end } cents.erase_entities(gp2faces2)
@verts
is an array ?
won't work as an array doesn't have a '.loops' method ??
e.outer.loop==@verts[0].loops[0]
might if there's only one loop ???
@verts[0].loops.include?(e.outer.loop)
might otherwise ????
Not sure... as you posted 'clipped code'... -
Sorry my post was unclear and made in a hurry
Yes it's an array of face.vertices. The one from face.clone, faces to go.
I suppose there are multiple ways of achieving what I want. But I have failed so far.
Will try some combination of @verts[0.loops.include?(e.outer.loop)] as you suggest, see what happends.
There could be scenarios where the faces has multiple "holes", so e.outer.loop==@verts[0.loops[0]] might not work.Thank you TIG.
Off to try! -
Here's a video tutorial on using the plugin for stamping stone patterns into various shapes. So far I've had great results. Thanks again Joel and TIG!
[flash=800,600:1trov9v7]http://www.youtube.com/v/SNTQDBmKIro[/flash:1trov9v7]
Earthmover!
That's quite a demonstration. Really! I can see here experienced modelers can find new workflows. Nice use of styles too.
I know it's a bit slow when having a lot of geometry. It will be faster in Hatchfaces (tiled patterns without faces).
Anyway, thank you for a nice video.
I'm wondering if the "hole" issue can be solved at all using face.classify method.
Watching Eartmover movie one can see he using a lot of detail in his meshes. Doing that, you will probably get faces and edges erased from holes, of the face it's glued to. Wich is the desired result!
But if you are using less geometry for intersecting! For ex just a 2d square covering some holes. The face covering the hole will not be deleted cause there arent any vertices in the hole. The same if you have an edge crossing over the hole it will be assumed to be outside the hole, and therefore not deleted.
Now, I have come so far to create a new group inside the colored group, that is a face_clone of the "holes".
Don't know yet how I am going to use it as a reference for what to delete, since the faces are inside an individual group.
Tried exploding it but the reference to the faces gets deleted.This could take a while to fix...
I think you need to take a step back on this face with holes issue...
If the originally selected face has holes then your cloned face can too...
You make a new group of the selected group/instance and explode it [recursively till it's all raw geometry].
You replicate the edges from the cloned face, inside this new group.
You .intersect_with() everything inside this new group so all edges get split etc.
You then test every edge in this group and if it fails it's collected and later the collection is erased.
The test for the edge needs to look at its start/end vertices positions and use face.classify_point(pt) - where the face tested is the originally selected face - you need to make several tests on each point as 'on face and not in hole', 'on edge', 'on vertex' etc might all count'... but 'off face' or 'in hole' won't.
If an edge has one or two 'on face and not in hole' that edge passed.
If an edge has one 'off face' or 'in hole' it fails.
If an edge has two 'on edge' or 'on vertex' hits then it might be either on OR off the original face - it's on the perimeter of the original face - it could be spanning a convex corner and by 'on' but it could be spanning a concave corner and be 'off'... so to test for this you then offset the start point towards the end point to find the midpoint of the edge mid=edge.start.position.offset(edge.line[1],edge.length/2) - now test that 'mid' point and if theta point returns 'true' for 'on face and not in hole' or 'on edge' then we know that that edge passes as its either a perimeter edge OR spanning a convex corner so it's 'on-face', but if it fails it's across a concave corner and it's listed for erasing later...
Set your tests up methodically and you should end up with a set of edges to go - the unwanted faces will go with them... -
I hope the picture from last post did not make it look like I was having problem with the face.clone? It's the colored face(cutting comp) that is not getting holes, when totaly covering the holes. I provide another (more illustrating) picture.
That is pretty clever That will help to get rid of edges in holes.
Probably not every time? Look at the picture, the big hole has no edges in it. Faces without edges in them will not get erased.
Thank you for the help, TIG. I will try to get this working.
Another question TIG, about start point offset to mid. I put you formula iterating through edges. And yes, I see the additional midpoints being counted(using puts).
Question is. Can points be used for erasing edges that way? Must not there be a vertice on the edge at that position to be able to delete the edge? I'm using If edge used by?
But the edge is not using that offset point, it's just a dot in space. Am I getting it wrong?I suppose I could use edge.split at that mid.point. But that would DOUBLE the vertices and have splits in the middle of every edge in the component! Could kill Sketchup, having patterns like Earthmover was showing?
Yeah, getting crazy about it...
NO !
Each tested pair of points for an edge just tells us that the related edge must go if they fail on some grounds, or if it the result is just 'iffy' then re-test for the midpoint and if that fails then off the edge goes into theedges2go
array; and when all edges are examined fully you doedges2go.flatten!
to remove duplicates [just in case there are any! there shouldn't be] and then useedges2go[0].parent.entities.erase_entities(edges2go)
NO !
Clear enough
Ok, I will continue with this method. You showed me some new moves there I haven't tried.
Also why not look at it this alternative way?
You use the original selected group; or if it's an instance then add that to a new group and immediately explode the instance. Now either way you now have a group to use.
Usegroup.entities.intersect_with()
using the the group.entities for the results, with a new transformations [0,0,0], and the object to intersect being((face.edges)+face)
Now test all of the group.entities edges for being on the originally selected 'face' as already outlined...
Any lines not on the face get erased.
Now it's possible that some faces in the group might still remain over holes in the face...
To find and remove those examine each face within group.entities [let's called each 'tface'].
Test the following pointpt=tface.bounds.center.project_to_plane(face.plane)
for being on the 'face' [but not in a hole!]... It will fail if it's one of the faces over a 'hole' in 'face' - if so add the tface to a 'faces2go' array.
When all faces are tested usefaces2go[0].parent.entities.erase_entities(faces2go)
Now the last step is to check for any un-faced edges left after these unwanted faces were removed...group.entities.to_a.each{|e|e.erase! if e.class==Sketchup::Edge and not e.faces[1]}
NOW we should have things sorted ??? -
I have to call it a day. Been at it since morning without any results. Your new approach here give me hope.
I will sleep on it and try this tomorrow.
Thanks for helping me out TIG.
My alternative way is a bit simpler.
Here it is reiterated.
Select face and group or instance.
Run tool.
Tool sorts out the parts: one face and one group/instance.
If it's an instance it's grouped and exploded and that group is used.
Now you
tr=Geom::Transformation.new() group.entities.intersect_with(true,tr,group.entities,tr,true,(face.edges+[face]))
You then then collect all of the edges in the group.
Make an array -edges2go=[]
Test each edge in turn.
pts=edge.start.position
then
pte=edge.end.position
againstface.classify_point(pts)
etc
If one point is 'on the face' [and not in a hole] AND the other point is 'on the face' [and not in a hole] OR it's on a face's edge OR on a vertex then that edge is OK.
If both of these points are NOT 'on the face' [and not in a hole] AND NOT on a face's edge AND NOT on a face's vertex, then it's
edges2go << edge
If both points are on one of the face's edges or vertices then it could be either 'on' or 'off' face; so we must test the edge's midpoint (mid=pts.offset(edge.line[1], edge.length/2)
) to see if that's 'on the face' [not in a hole] OR on a face's edge OR on a vertex - IF it is any of these then it's OK as it's spanning a convex corner and is all 'on face', otherwise it's off toedges2go << edge
again, as it's spanning a concave corner - either within a 'hole' or an internal L-shape and falls outside of the face !
You then erase all of these unwanted edges [any connected faces go with them] with
group.entities.erase_entities(ents2go)
There should be no 'stray lines' left by this method and this allows loose unfaced edges to be in the group and remain [trimmed to the face edges if needed]...This simpler idea can then be applied to the main hatching tool tool.
We get the hatch/crosshatch parameters.
We iterate through selected faces in turn.
A new 'hatch' group is made that will become bigger than each face bounds... lines are added to form the hatch/crosshatch [in the plane of the face], all of these lines are then intersected_with the 'face'. Each of the edge's two points are again tested with face.classify_point() [and midpoint if questionable] to make an array of unwanted ones to remove. -
Wow, TIG! Will be interesting to test your new approach.
BTW:
Make an array - edges2go=[]
then
against face.classify_point(pts) etcIsent this what I'm doing already? Except (face.edges+[face)] is a group(gp3) for me?
Or did I misunderstand you? Anyway, that may not be of relevance for fixing the problem.I think the main problem is that, after the collection of points "outside" face I have been using if edge.used_by? point to select and erase the edges. Passing on the point as argument. (In reality point gets converted to vertices). That way I can never erase an edge if it's not used by "something".
I guess your way is to tell Sketchup. If point is on edge? Put that edge in the "erase" array. Is that correct?
This all have to be done in an iterator, right? With some conditionals inside the iterator. I spent all day yesterday to find suitable API methods to fit the need, but really need some IF, NOT and OR statements? Or am I wrong here in my assumption?
I guess the iterator will be faster if the statements are made outside..I will try those things and pt=tface.bounds.center.project_to_plane(face.plane) and the edge.midpoint test as well.
Again, thanks a lot!
