    [Plugin] Camera Recorder (Pixero update)
    21 Posts 12 Posters 20.8k Views 12 Watching
    • PixeroP Offline
      Pixero
      My Change transition times script sets the transition time for all scenes at once.
      Since the camera recorder script makes one scene per frame there is really no need for setting different times for different scenes.
      You simply specify what frame rate your movie will have and it sets the transition times to match that.
      There are other scripts for setting transition times for each scene are you thinking of one of them?
      Mine is located under the menu: Camera-> JS Change Transition Times.
      • V Offline
        vodip
        I must mistaken yours to the other plug-in script. For some scene that require extra attention to get the message across, The ability to change the time span for those scene is useful. I'll check into the other plug in. thank you for the great tool.
          JGA
          Has anyone tried this with the rendering packages available?
          Regards,
          JGA
          • Chris FullmerC Offline
            It should work with all packages that let you render every scene in your model, because this plugin will create a scene for each frame of the recording. So you would want to set it up to render 1 scene per frame. If you want 24 frames per second, render 24 scenes per second. Soit should work pretty well with most renderers.
            • petestjohnP Offline
              petestjohn
              I'm excited about this plugin- but I'm having trouble with exporting to images. It gets hung up on random shots. Any ideas? Ahhh... figured it out...if you click off of the sketchup window, to work somewhere else, the update count in the bottom left freezes, but the program keeps outputting to the background.
                ryu
                I was looking for a way to capture a 3d walkthrough from sketchup
                and stumbled across the Chris' way cool clf_camera_recorder. I added a few
                lines of code to the "export_images" section so that it creates
                the left eye view from the captured datapoints. This means when it
                generates the images, it will actually create twice as many and will take
                twice as long. The left sided images all begin with "left_".
                After the images have been created, you can convert it to a video stream
                using quicktime pro, or with the opensource program ffmpeg. For example,
                if my images were called "imagexxxxx.png", then use:
                ffmpeg.exe -i image%05d.png -vcodec png right_image.mov
                ffmpeg.exe -i left_image%05d.png -vcodec png left_image.mov
                You can then view it using your favorite 3d viewer. I use the one
                available from 3dtv.at.
                Enjoy!
                -Robert
                clf_camera_recorder_v1.9.zip
                  Bertier
                  Hello all,
                  I haven't tried this plugin yet, could you please let me know if it is able to create "natural" camera movement like this :
                  • beginning of the path : high frame rate = slow start
                  • main path : 25 fps = normal camera speed
                  • end of the path : high frame rate = slow finish
                  that would be great !
                  Bertier
                  • PixeroP Offline
                    Pixero
                    Probably not by itself, with the walk tool if your good at it but probably better with an additional plugin that works like a FPS. (Sorry I can't share mine.)
                    LightUp's Tourtool has a great smooth realtime flythrough that could work together with it with some editing afterwards.
                    Then there is also the Camera key maker script that works a little different by drawing a curve for the animation. http://forums.sketchucation.com/viewtopic.php?t=36430
                      Bertier
                      thanks
                        rgr87
                        I've tried to install it but nothing happened
                        coppied the extracted files in my pluggins folder but nothing happened
                        can somebody help me out ??
                          Capture.PNGYou have to put the two highlighted items into Plugins, NOT the 'containing-folder' OR the contents of the subfolder separately either - just those two - the .rb file and a subfolder of other files...
                          You can also put the separately linked .rb file into Plugins...
                          • majidM Offline
                            majid
                            I was seeking a camera tool that saw this, really amazing tool, thanx mate , but rotates the camera with no good reason. and a bit hart to use.
                            I was tryng flightpath, on SU6 but it doesn't work with SU8
                              Majid, it is supposed to capature camera movements in real time, and then be able to replay them. Are you saying it is adding additional tail to the camera? Is that automatically, or only after a camera path?
                              • majidM Offline
                                majid
                                mate, when I replayed the animation, saw that the scene camera is rotated...
                                it is maybe over my IQ 😉, is there any easier tool?
