    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.4m Views 345 Watching
      Jim
      Hi Patrick,
      That (my) blog post is over a year old, and I thought FredoScale had been updated to address the problem. I can not find a reference to it being fixed. Fredo will need to clarify.
      • P
        paddyclown
        Hmm, thanks & meantime I found this : http://forums.sketchucation.com/viewtopic.php?t=29032
        which seems to sort the problem for me... so heh makes me happy as I have tons of things loaded that I use...
        Hope one day Google gets 'round to making a loader/unloader for plugins that's easy to use...
        Anyhow, thanks to all you clever people who know how to ruby script !
          meeta
          A big thank you. This plugin will be saving me hours and hours of work!
          Meet A
          • T
            The Pixel Artist
            Dear Fredo,
            FYI, I updated to 2.2a today and found that the radial bending tool seems to break the ability to use ThomThom's UV Toolkit remember/restore feature. It works fine with 2.1a and I've gone back to that version for now. Just thought I'd make you aware of it.
            Here's the link to my post in the UV Toolkit thread that explains the problem better. The combination of Fredoscale and the UV Toolkit to do things like curved brick arches is terrific!!
            LINK: http://forums.sketchucation.com/viewtopic.php?p=346983#p346983
            BTW, thanks for all of your hard work over the years! I've never had to chance to thank you. (I haven't posted here in a couple of years!)
            • L
              lapx
              Hey Adrian,
              You are a sketchup hall of fame'er. I have always admired your worked. Good to see you posting on the board.
              No doubt you've kept busy in chi'town and abroad with all that talent.
              • fredo6F
                Dear Pixel Artist,
                The only difference between 2.2a and 2.1a is that FredoScale activates the Automatic Slicer by default in 2.2a (the slicer is toggled by key F4 and is shown with small orange ticks along the line of curvature).
                If you bend a shape which is already sliced with enough granularity, you don't need the automatic slicer, and thus you would probably not alter the UV settings.
                This may be the explanation. Thanks to advise if this is the case.
                PS: I did the activation of Slicer by default in 2.2a because many users had problem to bend solid shapes like a simple cylinder and did not read the documentation to find out about the Slicer.
                • C
                  cunningham
                  Awesome, Sorry I've been away. But excellent work
                  Should increase workflow no end
                  • dereiD
                    derei
                    Could you modify the Update-Check window? For now it just highlights with red the outdated plugins. It would be useful to link to plugin's forum page.
                    Thank you.
                    DESIGNER AND ARTIST DEREI.UK
                    • fredo6F
                      Thank you.
                      Not sure I understand.
                      In the check for update dialog box, the middle column ("info") is precisely the link to the Forum page.
                      Do you get it?
                      Best is maybe to post a picture of the dialog box.
                      • dereiD
                        derei
                        Do you get it?
                        Thanks for pointing it to me. I only hovered on left column. I guess my I expected the entire line to be a link 💚 So, when I saw that nothing happens, I never thought to try the underlined Info text.
                        • dereiD
                          derei
                          Is it a bug, or I do something wrong?
                          The inference for scaling don't work in certain situations. Please see the image. Is not the first time when it happens.
                          I tried to scale the door, to meet a line which was drawn in a group outside door component. The door scaled arbitrary.
                          Thank you very much.
                          • fredo6F
                            This may be normal. I did not invest enough time in this, so it is not bullet proof. It may be even work in some views and not in another one.
                            • dereiD
                              derei
                              Some time ago I played with projections and seems to not be too hard (like inference lock), is this somehow different? Is it any hope that this feature will be improved? It would be really nice.
                                samlion
                                I have download the fredoscale plugin and the libfredo library.
                                This is a wonderful tool and seems to be ok except the fact that when i click the default parameter option (Tools/Fredo6 collection/Fredoscale/Default parameters...), nothing happen.
                                I just receive a message in the status bar "Load all ruby files for plugin FredoScale --> 40 ms"
                                Other hunction seems to run well.
                                I have tried to uninstall Sketchup and made a new installation of the program and the plugin but nothing happened.
                                Can you help me please ?
                                I'm running Sketchup 8 (free version 0 in Windows 7 environment.
                                Richard G.
                                • fredo6F
                                  @samlion said:
                                  ...except the fact that when i click the default parameter option (Tools/Fredo6 collection/Fredoscale/Default parameters...), nothing happen.
                                  Richard,
                                  Can you open the Ruby console and see if a message is displayed.
                                  Also which version of FredoScale and LibFredo6 do you run (go to their About... menu).
                                    samlion
                                    Hi Fredo, thanks for your answer.
                                    The version for LiFredo6 is v3.7c and the version for FredoScale is v2.2a.
                                    When I open the ruby console, there is nothing; its look like a white square where we can enter some commands.
                                    Thanks in advance for your help.
                                    Richard G.
                                    also, the directory DEFPARAM_Dir is empty; there is no file fredoscale.def.
                                    • fredo6F
                                      Just in case, did you open the ruby console, and THEN, try to call the FredoScale Default Parameters dialog box, to see if a message is displayed in the console?
                                        samlion
                                        Hi Fredo,
                                        I have tried what you mentionned (opening ruby console and then call for default parameters option) and nothing appear in the ruby console.
                                        Thanks in advance.
                                        Richard G.
                                        • dereiD
                                          derei
                                          In this post http://forums.sketchucation.com/viewtopic.php?f=323&t=17948&start=615#p349363 the target point for scaling was outside active model, so I was thinking that is the problem.
                                          Now, in this model, the target is inside active BUT, the axis are not aligned with default. You will see the edges colored by Axis, because I oriented them in accordance with the model, but are not aligned with "Word UCS"(don't know if this is the correct naming; it's a reminiscence from AutoCAD 💚)
                                          Could this help you to try fixing it?
                                            rjjvirusx
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 58
                                            • 59
                                            • 32 / 59
