    [Plugin] Hatchfaces (v1.8 beta) UPDATED 15-Dec-2012
    360 Posts 41 Posters 228.6k Views 41 Watching
      Look at my '2dTools Hatching' tool that uses images as textures rather than 'lines'.
      If you mimicked that but with SKPs instead of JPGs it's be a simple solution without web-dialogs etc.....
      • jolranJ Offline
        jolran
        Haven't dared to look at that script, cause it's darned complexed!
        But I will see if I can understand what is going on in that script. Thank's for the idea. I think it sounds pretty smart, could be the solution I looking for.
        BTW. This material-transfer side of things is seriously complex, no? I managed to get a array list of materials itterating through a components.entities. But then have to transfer that on to the intersected face(gents). Face erasing should only occour on faces without materials.. πŸ‘Š
        I will look on your 2d tools TIG cause this is confusing.. Maybe it's all the cider I drank as well πŸ˜„
        • EarthMoverE Offline
          EarthMover
          This is really progressing nicely. I'm starting to get excited about the possibilities here. I don't think this should be viewed as a mere hatching tool. This could be a serious modeling tool as well.
          Eventually I would like to see this be able to store user made hatch "stamps".
          If this is true, one could save some serious time by storing repetitive lines used in modeling.
          For instance if I'm building a house. I could have a pattern saved for roofing tiles, one for siding, one for decking etc. One could then just apply these to the faces of the geometry and cut the lines into the face for further extrusion. Perhaps an option to intersect the hatch, keep it as a group or apply it as construction guides.
          In essence you could create a Pattern Stamp tool. One benefit would be dropping in hatches and the other for modeling work.
          I work with a lot of curvey patio and pool deck shapes with a multitude of the different patterned stone. I would love to be able to store all of these different patterns and then be able to run the plugin, set the overall size of my stamp and then stamp a pattern into curved edge shape. Right now I do it manually and it involves intersecting and a lot of cleanup.
          There have been a lot of requests for floor generators and brick and tile makers, etc. A user saved pattern database which could be stamped to surfaces would be half the battle and fill those needs.
          Honestly I would pay for a tool such as this.
          Keep up the great work Joel & TIG. Definitely got my eye on this thread.
          Content Creator at Skapeup
            I agree that Jolran's idea could run and run... and we are encouraging him in his efforts...as you say a series of preset 'hatch-patterns' line-SKPs is easily added to to make a custom library of 'stamps' β˜€
            • bazB Offline
              baz
              @tig said:
              Master Jim: you know [Shaolin] Kung-Fu too πŸ˜„
              I wondered if anyone would get the analogy... β˜€
              I thought it was "Glass-opper" πŸ˜„
              • jolranJ Offline
                jolran
                Wow, EarthMover this is exactly the kind of feedback needed, and you have some very great ideas. Thanks! πŸ‘
                I will put effort in trying to make them happend. Hopefully with some push in the right direction from TIG if I would get stuck. Which I will πŸ˜„
                Thanks for posting!
                • jolranJ Offline
                  jolran
                  There are some major problems. 😞
                  Have looked at 2d tools for ideas, but need serious time to study that script.
                  So been trying other things..
                  Getting result nr 3 on the picture is no problem, with or without faces. (Transfering the material is not done yet)
                  Problem is deleting the correct edges. If "face_frame" is not wanted(In this case "face_clone" outer and inner loops)
                  It sounds easy πŸ˜„ But when intersecting, the added result is nr 4 if one delete the face loops. Deleting with reference to vertices won't work? Since they are sometimes connected to same edges one wish to keep.
                  My theoretical fix:
                  Keep all the result from nr3 including faces. And do material transfer.
                  Although! Looking at picture nr 2 one clearly see the problem when adding 2 faces connected on top of each other.
                  There is a normal conflict(?) So it's either delete original face OR turn the result into an component with cutting behavior.
                  (I think I know how to do that in the definition list)
                  I'm working on the later solution, so one can have a better workflow, should one wish to delete the hatches..
                  Now problem is, in wich direction I should troubleseek a solution for material transfer?
                  1. Let say i have a DC or standard component with material/color attributes(forget about textures atm). Can they be transfered to the result component, after intersection? Remember, geometry has changed..
                  2. Iterate trough faces and get material infos from DC.entities. Use method face.position_material.
                  3. Use UV helper?
                  Not much info about the UV helper in the API?...
                  • jolranJ Offline
                    jolran
                    OR do a face_clone of the DC with material and all. Then erase everything outside the original selected face!!!
                    Wonder if that's possible.. Would be the safest method, I believe..
                    There is a problem exploding nested components. And it's needed to get whole model edge, face, vertice collection?
                    Edited: No, no, no... Not face_clone. Will have the material problem then again if moving over stuff to a new entitiy..
                    • jolranJ Offline
                      jolran
                      OK a little more rabbeling. Maybe it can help someone in similar situation.
                      Although I must warn! It's not about booze and women πŸ˜„
                      Have experienced plenty of crashes. Did put the DC in a new group and exploded the entities therein.
                      It's difficult to get to entities and iterate a collection in nested components, if the components are not exploded?
                      Probably the user want's to keep the DC for further editing anyway? So to explode the DC would not be very polite.
                      So new aproach is to make an instance of the DC. Explode the shit out of it, and extract edges and faces and materials if possible and get rid of it. THEN recreate the dc from that information on to the faceclone or vice versa. Probably have enough information to know what to erase, and then do erasing.
                      That IS probably the way to play safe.
                      I get the feeling it's risky doing things with entities of current Sketchup selection? Grouping, exploding etc.
                      If you clone them, or copy. You can do what the heck you want with the copies?
                      That IS probably the way to play safe. And I sence that is what TIG is doing in his scripts.
                      I noticed that faces and edges created in code doesent behave like they do in normal Sketchup modeling. In code if you split a face with an edge you don't get 2 faces! The edge lie on top of the face. Therefore one must use intersect with.
                      Although I have also noticed some inconsistency in this!
                      But if it's true, orders of drawing things won't matter that much, wich is a good thing.
                      • jolranJ Offline
                        jolran
                        Things are not going so well. Doing a pattern like on the picture will be difficult.
                        Unless black and white. That's no problem to do.
                        TIG recommended to clone current selection to avoid bugsplats. I'm fine with that as long as doing faces only.
                        But that won't give much flexibility if doing a pattern like on the picture.
                        How to clone the edges from an array? And what if you have an edgeloop where you DON'T want a face?
                        And materials are still a big problems. If it where only 1 material, things would be relatively easy.
                        I guess faces can have attributes like materials, but how to store them and transfer to the face_clone is the question.
                        I'm thinking doing an intersection with face, then recreate the facecolor pattern and erase vertices outside the face.
                        ATM I get splats when using lot of patterns or nested components with intersection. Things are a lot more stable, since
                        being able to explode all the components and add entities to group AFTER the group was created.
                        Using few components with plenty geometry is OK. Many components are bad. Even if they contain few entities..
                        Could need a push with the materials.. Otherwise I probably will have to restrict the plugin features.
                          I'm still not entirely sure what you are are trying to do πŸ˜’
                          If you want add colored shapes onto a face as a hatch pattern try this...
                          Make the cloned face inside the group.
                          Add the instances to the group.entities, placed where you will.
                          Apply materials to these instances.
                          Explode the instances and the default materials in them become their face materials and they merge with the background face.
                          Now you need to erase the bits outside of the face bounds.
                          Test all of the edges in the group.
                          Test their start.position and end.position, on the original face with classify_point to see if that point is 'on the face' [you need also to cover on edge, on vertex and not in hole etc] if both point test OK it's inside the original face. If one or both of them are not the you want to erase them - push into an edges2go array. The erase all of those edges and the faces go with them. Finally erase any faces with 'nil' material [in the gaps from the cloned face], and then any unfaced edges if you don't want a perimeter. You should now be left with the colored shapes trimmed to the original face's edges.
                          • jolranJ Offline
                            jolran
                            Thank's TIG, I will try.
                            • jolranJ Offline
                              jolran
                              Actually when I reread you post TIG. It is probably the way to go.
                              I had the idea to make a huge face. Same size as entities.bounds. Add the edgeloops from original selected face.
                              And then delete the original face. (Sort of oposite of the face). Then do an intersection with the components.
                              The result of intersection could be deleted, and all what's desired would then remain..
                              It is all theoretical..
                              • jolranJ Offline
                                jolran
                                I will test TIG' solution tomorrow, if time gives. I have another test to do.
                                If someone please tell me how I can get the pt's from a boundingbox object. It will only be 4 pt's, boundingbox from 2d hatches.. Will create a face from those points later. Had a look at Thomthoms edges from boundingbox, but it's for a whole "cube" boundingbox. Don't need that much information his script gives.
                                I've tried something like this. But it doesent work.
                                	centbox=gp2.bounds  #boundingbox object
                                			 centpoints=[]; range=(0..7); centbox.corner.range.each{|e|
                                			  if e.valid? and e.class==Geom;;Point3d
                                			      centpoints << e
                                Edited. It probably should be centbox.corner.range. I changed the original. Still doesent work..
                                  You don't want the limits of a bounding-box - it's a rectangle, the face might be a circle ! Use my selected_face.classify_points(pt) tests for all edges after the explode/intersect etc...
                                  • jolranJ Offline
                                    jolran
                                    Really? 😲 Bounds=boundingbox, no?
                                    So boundingbox will not be like on the picture? darn... Typical.
                                      entity.bounds== a bounding-box rectangular cube - even if the object is the shape of a banana 🀣
                                      Use selected_face.classify_point() tests πŸ˜’
                                      • jolranJ Offline
                                        jolran
                                        Yes. That's what I want πŸ˜„
                                        It's for the exterior bounds of ALL entities, not the face. Then from that huge face do a boolean with the selected face.
                                        If you intersect with the result from that you have everything intersected in a group wich can be deleted?
                                        But ok, I will try what you say.
                                        BTW. An exploded comp. don't always transfer the materials to the face lying underneath? It's risky.
                                        • jolranJ Offline
                                          jolran
                                          No. Exploded instances do not merge materials to the face lying underneath. Is it supposed to happend?
                                            On an explode it should [untested].
                                            Alternative 'intersect' after the explode ??
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 17
                                            • 18
                                            • 12 / 18
