    San Carlo alle Quattro Fontane
    33 Posts 18 Posters 15.3k Views 18 Watching
    • gdbalckG Offline
      gdbalck
      Ha, yes I've been lurking around for almost two years 😳 There's just so much information here that I read mostly, well always really.
      Thanks leedeetee, here are some more images from the Twilight thread.
      http://img546.imageshack.us/img546/3089/sc01.jpg
      Longitudinal section
      http://img233.imageshack.us/img233/1503/sc02p.png
      Cross Section
      http://img842.imageshack.us/img842/93/sc03v.jpg
      View up to the dome, the main altar is to the right. The Lantern is yet to be done.
      http://img831.imageshack.us/img831/8184/sc04.jpg
      Looking back towards the altar.
      http://img696.imageshack.us/img696/7686/sc05k.jpg
      View from entrance towards the dome above.
      • zdesaynZ Offline
        zdesayn
        nice detail...i will wait for your final output.
        http://zdesignviz.blogspot.com/
          Now this makes me thinking...
          If just every 10th (or say 100th) "lurkers" here had something similar to show and if they all did it, this place could be completely different!
          πŸ˜•
          • daleD Offline
            dale
            Wow
            Can't wait to see you develop the dome which is so beautiful in this building.
            Can you post a wireframe of those column capitals. That looks like brilliant modeling!
            Thanks for jumping in.
            • gdbalckG Offline
              gdbalck
              I've spent the last week doing more in depth geometric studies of the building before starting the final model. Here are a plan and a section study.
              http://img824.imageshack.us/img824/1470/sancarlinop1.jpg
              http://img855.imageshack.us/img855/7338/sancarlinos1.jpg
                Now these seem to be excellent for geometrically and perfectly building up the whole thing.
                Are you planning to texture the church at the end? (I realise it will be as big of a challenge as the geometry itself - if not bigger...)
                There are some very nice procedural marble materials over the Kerkythea site. They work perfectly with Twilight and you do not need to wrap your head around meticulously positioning the materials in SU on those extreme walls and curvy surfaces.
                • massimoM Offline
                  massimo Moderator
                  Looking good. πŸ‘
                  • gdbalckG Offline
                    gdbalck
                    I've been working on and off on this project, it takes a lot of brain power! Most of the time has been spend on geometric studies of the half domes. The latest lead to the image below.
                    http://img534.imageshack.us/img534/1443/71495374.jpg
                    • daleD Offline
                      dale
                      I happy to see your still at it.
                      In itself a beautiful object.
                      • gdbalckG Offline
                        gdbalck
                        Thanks dale.
                        I've refined my geometric studies of the plan even further over the past few weeks. I've also added a slight flare in order to help them look a bit more "authentic" to the time period 😎
                        For your viewing pleasure.
                        http://img31.imageshack.us/img31/2675/sancarlinosequence16a.png
                        http://img217.imageshack.us/img217/7886/sancarlinosequence712a.png
                        I'll be working on the sections next before proceeding with the full model.
                        • gdbalckG Offline
                          gdbalck
                          Update:
                          Borromini's Capital
                          http://img843.imageshack.us/img843/4758/capitaltwilight.jpg
                          http://www.brynmawr.edu/cities/Cities/wld/04890/04890l.jpg
                          Quick render without materials next to actual column at San Carlino.
                          Since June I've been splitting time between studying the plan and column geometries. You might say, why not just grab one form the 3d warehouse. This was a consideration until I learned that Borromini had done something very unorthodox at San Carlino. He inverted the volute of his composite columns under the arches. Well, I couldn't just grab someone random column to put in the model knowing this.
                          After much labor and effort, here it is. A couple of things are missing, all of them ornamental. I'm not sure if that's something that can be taken care of with textures.
                            Daniela_864
                            Hi gdbalck,
                            I'm an italian student of architecture, I saw your S.Carlo alle quattro fontane's model. I'm writing my thesis about the light in this church. Should it be possible to receive a copy of your model or just any views of the inside? I can imagine the hard work to create the model, so if it is necessary I can pay you (if you don't want too much money πŸ˜„ ) bye bye.
                              pier70
                              bellissimo lavoro, complimenti. Very nice work good job
                              • DanielD Offline
                                Daniel
                                Beautiful work, Mike.
                                My avatar is an anachronism.
                                • pietervP Offline
                                  pieterv
                                  I like the geometric studies!
                                  This is my website:
                                  Citypixels - 3d Visualisatie Architectuur
                                    smicha
                                    Is this book available for sale? Who wrote it?
                                    Great modelling!
                                    • KrisidiousK Offline
                                      Krisidious
                                      fantastic... inspiring.
                                      By: Kristoff Rand
                                      • gdbalckG Offline
                                        gdbalck
                                        Great modelling!
                                        Thank you sir. About the book, funny you should mention that. A friend of mine has been encouraging me to put all of these studies and models in a book. So, it isn't for sale yet but it is in the works.
                                        Thank you for your kind words.
                                        @daniela_864 said:
                                        Hi gdbalck,
                                        Do you still need this? Feel free to contact me via private message here on the forums, I'd be happy to help you.
                                        • gdbalckG Offline
                                          gdbalck
                                          Hu, and I thought this thread was dead.
                                          Well, I wasn't idle this whole time. I went back and developed the geometric studies even further. Here's a test print showing plan and section studies.
                                          https://sphotos-a.xx.fbcdn.net/hphotos-frc1/s720x720/580731_4595144153994_1888410790_n.jpg
                                          The columns came out a little funny but it is still a work in progress.
                                          I've also restarted the model, this time based of the more detailed geometric studies.
                                          Here are a couple of progress shots after a couple of days' worth of work.
                                          https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash4/382549_10200664389549513_1010968175_n.jpg
                                          https://sphotos-b.xx.fbcdn.net/hphotos-prn1/1015803_10200663570889047_124884431_o.jpg
                                          • gdbalckG Offline
                                            gdbalck
                                            Some more progress shots.
                                            https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-prn2/1072593_10200669629400506_898480057_o.jpg
                                            https://sphotos-a.xx.fbcdn.net/hphotos-frc1/887306_10200669629320504_2042991281_o.jpg
                                            Old black and white picture from similar angle for comparison
                                            The two arches are place holders, I was experimenting with twisting its profile as it rises from its base. Feel free to share any tips or ideas on how to build it and make look smoother.
