    Shape bender question: bend along the inside of the curve
    15 Posts 5 Posters 1.2k Views 5 Watching
      Jet
      Hi everybody,
      I tried to bend my object along the inside of the curve line, but couldn't make it work. I tried place the object in different position, I can make it bend along the outside of the curve, aligned center along the curve, but just couldn't get it bend along the the inside of the curve(unless my object doesn't have a thickness. )
      Please see attachment. Appreciate your response.
      Never give up, Never surrender!
      • soloS Offline
        Okay, then just use the profile (no thickness) and bend as you need it then use JPP (joint push pusll) after to create the thickness.
          Jet
          I know, I've tried that already. but it would create a hollow back. you know what I'm talking about. I need to remain the back. I know I can use the curved profile for the back, but that's not what I want. Also, I can't do that to the other object, because the joint push pull will distort the structure. That's why I need to create the thickness before I bend it.
          • soloS Offline
            Before using JPP copy the face then attach it to the back after.
              Jet
              Yes. That's what I mentioned in the previous post.
              • BoxB Offline
                I'm not sure why you started another thread, but that's beside the point.
                Are you doing this to understand shape bender or do you just want this shape?
                The shape you want can be made simply by creating a curved object of the correct thickness then extruding your profile through it, intesecting and removing the excess.
                This would give you straight sides but they can always be corrected.
                You have not explained in your threads what it is that you want to achieve.
                It's difficult for people to give you the correct advice if they don't know what you really want to produce.
                  Jet
                  I'm sorry. I don't know how to explain this clearly. I guess I just have to let the images tell the story.
                  On the left of the 1st image you can see that some lines are missing after curving. That's why I need to create the thickness before curving the object.
                  the 2nd image shows you that joint push pull can not generate the shape.
                    Jet
                    bent to a different direction:
                    • BoxB Offline
                      I'm sorry, but now you are showing a third image.
                      I think you have several issues that need to be addressed but it's hard to understand what they are.
                      And from what I've seen, none of them relate to Organic Modelling.
                      Edit: Apart from that, you need to look at the placement of your axis and the adjustment via the arrow keys.
                        d12dozr
                        Are the missing faces very small? Perhaps its a small-face issue?
                        ShapeBender is finicky, but it will usually work if you understand how it works - if you want to upload your model, I'll take a look.
                        http://goo.gl/f7ooYh
                        • EarthMoverE Offline
                          EarthMover
                          [flash=800,600:mb7cdwsb]http://www.youtube.com//v/jqc2FhUcEVA[/flash:mb7cdwsb]
                          Content Creator at Skapeup
                            d12dozr
                            @jet said:
                            someone told me about the up and down arrow before, but the thing is on my Mac the up and down arrow does not change anything.
                            That's why its not working for you then...maybe someone can help you get the arrow problem sorted on your Mac, but until then here is a workaround...flip the arc along the red axis before running shape bender - then you don't need to use the arrow keys
                              Jet
                              yes, I was trying to do this, and this is the only way I can make it work. And Thank you.
                                Jet
                                Oh, Adam, you are so sweet. Thank you very much for making a tutorial for this.
                                  EarthMover
                                  Hi Jet,
                                  You're example worked fine for me. Perhaps try keeping your camera in perspective mode instead of parallel projection. It's easier to see where your control lines are positioned.
                                  Some other things to consider with Shape Bender -
                                  1. Make sure the control line is not touching the geometry to be bent.
                                  2. The position of the control line to the geometry is relative to the position of the bent shape to the curve. (if your control line is 5mm from the geometry to be bent, the final bent geometry will be 5mm from the curve.)
                                  3. The segments in the curve will be relative to how many slices the plugin uses to bend the geometry. More segments in the curve will result in a smoother bent geometry, but will process slower.
                                  4. The plugin recognizes the direction which the control line is drawn. Using the down arrow will reverse the direction of the control line and flip the start end points and the resulting alignment.
                                  5 The up arrow will toggle which side of the curve the bent shape adheres to.
                                  1. Be mindful when bending shapes with curves or extra verticies in them that the plugin will have to add triangles to your bent mesh to stitch those faces together. The results can often mess up the shading. Always clean your mesh well (ThomThom's Cleanup script) before processing and make sure your segment count of each curve is reasonable.
                                  2. The bent shape is also relative to the axis. More predictable results occur when you keep things on the zero Z plane. Not raised into the air.
