    Military vehicles rendered with V-Ray
    21 Posts 10 Posters 6.1k Views 10 Watching
    • W Offline
      watkins
      Dear Shareck,
      These are excellent models and you are to be complimented. The level of detail is superb. Do you work from drawings or from photographs? Is the building your Tank Museum?
      Kind regards,
      Bob
        shareck
        @watkins said:
        Dear Shareck,
        Kind regards,
        Bob
        Thanks Bob. I work from blueprints to get the basic size/shape and proportions right. Than i use loads of pictures for all the details. The building is just a bulding i modeled based on this picture:
        http://www.barbadospropertylist.com/wp-content/uploads/2010/04/warehouse.jpg
        . I wanted to render something like the picture but couldnt get the sunlight right.
          shareck
          Another two images. This model is actually the one i built for sketchyphysics animation so it doesn't have that many polygons and small details are faked in textures. Its the same model with two different textures.
          http://fc06.deviantart.net/fs70/f/2011/135/8/7/king_tiger_tank_sketchup_model_by_shareck-d3gdxlf.jpg
          http://fc00.deviantart.net/fs71/f/2011/135/e/6/king_tiger_tank_sketchup_by_shareck-d3gdxpy.jpg
          • numbthumbN Offline
            numbthumb
            @shareck said:
            @numbthumb said:
            Cool, shareck, excellent job as usual 👍
            Some zimmerit would be nice 😄
            You know that UV unwraping does'nt exist in SU and using other applications is limited or difficult.
            I have noticed that. 😄 However, it didn´t stop you from doing a really nice ambush scheme on that Königstiger 😉
            Anyway, I did not mean to criticize your work. Once again, excellent job.
            Comfortably numb...
              shareck
              Anothers:
              http://fc05.deviantart.net/fs71/f/2011/135/6/9/challenger_2_tank_by_shareck-d3gfdfh.jpg
              http://fc04.deviantart.net/fs71/f/2011/135/6/a/1918_ford_3_ton_tank_by_shareck-d3gfdka.jpg
                darkwolf29a
                Firstly, these are very good. 😄 However, you might want to see about viewing a few images of the real tank. I think, but I would have to verify with my research at home, that the King Tiger (for example) has tires covering the wheels, to help reduce some of the bumps.
                  designerstuart
                  very, very nice work, well done.
                    numbthumb
                    To the best of my knowledge, Kingtiger did not have rubber tyred wheels, they used 'Gummigefederten Stahllaufrollen' or steel tyred wheels with internal rubber cushioning.
                    It was early production Tiger Is that were fitted with dished steel wheels with rubber tires.
                    Comfortably numb...
                      shareck
                      i guess it wouldn't harm anybody if i add few more pics...
                      http://fc08.deviantart.net/fs70/f/2011/153/9/d/t_34_85mm_tank_by_shareck-d3huy2b.jpg
                      http://fc06.deviantart.net/fs71/f/2011/154/8/3/jeew_willys_and_t34_85_tank_by_shareck-d3hx44p.jpg
                      http://fc09.deviantart.net/fs70/f/2011/145/0/e/t34_85mm_tank_detils_by_shareck-d3h7r1e.jpg
                      http://fc04.deviantart.net/fs70/f/2011/141/d/9/m38_jeep_willis__sketchup_3d_by_shareck-d3gw75l.jpg
                      http://fc08.deviantart.net/fs71/f/2011/141/f/5/t72_tank__wip_by_shareck-d3guyek.jpg
                      the images are big... sorry
                        numbthumb
                        Great job, shareck - details like weld seams and tow cables really add a touch of reality.
                        Did they add significantly to the file size?
                        Comfortably numb...
                          shareck
                          Thanks. The welds are just simple geometry that have a material with strong bump map applied. The cable definitely increased file size but it was huge already so it wasn't a big deal.
                          • holmes1977H Offline
                            holmes1977
                            The texture you used on the T34/85 is very impressive.
                            Where did you get the bumpmap from?
                            Exaggeration makes a dull story better.
                              tomislavm
                              What to say, this is professional work and I appreciate You !
                                shareck
                                Well the textureas are not really UV mapped so theres no big deal about the bump maps. There are 3 different materials on this tank. The difuse layer on all three materials is a simple dark green colour. But the bump map layer has a seamless texture of some eroded metal i found on google. Reflaction/specularity layer is another seamless texture of rusty metal or something like that. I only adjusted the strenght of the bump maps and reflections for each material and than applied the right materials to the right parts of the tank. welds are flat geometry with just a material with strong bump map.
                                  Przemo25
                                  Hi !
                                  I'am just wondering what kind of material did You use for welds. I'am looking good material...and still nothing.
                                  Best regards !
                                    Przemo25
                                    What kind of material did You use to render welds ? Please help me wiht that.
                                    Best regards !
                                    • Bryan KB Offline
                                      Insane details and great renders. Good job!
                                      • leonmetalowiecL Offline
                                        leonmetalowiec
                                        Nice 😄
