    Swedish Yacht
    11 Posts 2 Posters 3.2k Views 2 Watching
    • axeonaliasA Offline
      axeonalias
      Heres am example with the plan overlay :
      http://farm7.static.flickr.com/6026/5932866475_05456ab470_b.jpg
      https://sketchfab.com/Axeonalias
        axeonalias
        Added a rather bland looking side, Planks are abit to dark, ill still be getting it right ,parts are all coloured and ready for texturing.
        http://farm7.static.flickr.com/6009/5934210514_1f8ab9a251_b.jpg
        • Bryan KB Offline
          Another good one!
            axeonalias
            Thanks Bryan K
            Taking a little break from texturing to do the sails, the goal here is to create one texture for 5 moving sails,the surface are is quite large so I dont think a 1024x1024 will look so great,but will see, can always make it a 2048 and rescale it if its oversized, here is a shot directly from SU :
            http://farm7.static.flickr.com/6136/5937367510_58d0c16cac_b.jpg
              axeonalias
              Hmmm sharing the Jib texture with Sails that are not the same in angles is going to prove to be interesting πŸ˜„
              Had an issue with Max that has been bugging me for a long time now, months infact maybe even years, when using the mirror mod in the dropdown menu from the top menu bar to flip the sail to create your left and right model, it would flip the lighting in game so the light would seem to come from below on the model in game, well.... I tried using the mirror mod in the modifier Tab, worked like a charm πŸ˜„
              http://farm7.static.flickr.com/6139/5937783647_acd876fd5a_b.jpg
                axeonalias
                All parts in and marked, sail textures already made just not shown in this shot,had to remap all the sails as overlapping the jib textures was just not going to work out, will keep it hidden until everything is textured πŸ˜„
                http://farm7.static.flickr.com/6133/5939818330_b0b2df5d12_b.jpg
                  axeonalias
                  Ive uploaded the hull with the blank Sketchup hull next to it if you guys want to have a look at it, Sketchup tends to loose some of the mapping on import so white poly`s can be expected.
                  http://farm7.static.flickr.com/6027/5939847143_627372479e_b.jpg
                  Swedish_Hull.skp
                    axeonalias
                    Texturing pretty much complete, still need to add the furled sails and texture them, Another nice thing about using custom textures like this is the bump mapping that can be used ,Ive added this bump map using the main texture, looks good in game but the bump texture is twice the size as the original texture.
                    http://farm7.static.flickr.com/6148/5945404811_d303a98f92_b.jpg
                    Sunset shot showing the bump at work clearly
                    http://farm7.static.flickr.com/6017/5945405141_d594c83a02_b.jpg
                    http://farm7.static.flickr.com/6002/5945961944_39dd2b9b4b_b.jpg
                    http://farm7.static.flickr.com/6144/5945962268_9c75d47e47_b.jpg
                    http://farm7.static.flickr.com/6006/5945962810_b80bce6184_b.jpg
                    • Bryan KB Offline
                      Oh wow. Once again... 😲
                      That last picture is beautiful!
                        axeonalias
                        Thanks Brayn
                        Well thats this one complete, thanks for your input guys!
                        http://www.graphic-park.com/VS_WIP/The Shop/Swedish_yacht/shots/1.jpg
                        http://www.graphic-park.com/VS_WIP/The Shop/Swedish_yacht/shots/2.jpg
                        http://www.graphic-park.com/VS_WIP/The Shop/Swedish_yacht/shots/3.jpg
                        http://www.graphic-park.com/VS_WIP/The Shop/Swedish_yacht/shots/4.jpg
                        http://www.graphic-park.com/VS_WIP/The Shop/Swedish_yacht/shots/5.jpg
                        http://www.graphic-park.com/VS_WIP/The Shop/Swedish_yacht/shots/6.jpg
                        Panoramio
                        Below is the attached Ship in Sketchup.
                        Swedish_Yacht.skp
