    How to convert String to Path?
    10 Posts 4 Posters 1.3k Views 4 Watching
    • dereiD Offline
      derei
      Hy, I'm trying to "learn" by doing something and I need some help.
      I got the current model's path like this:
      model = Sketchup.active_model
      pth = model.path
      and pth is returned as string, so I cannot do this:
      pth = model.path.dirname
      My question: how I can convert the returned string to path, so I can get model's directory?
      Or is any easier way to get model's directory?
      Thanks.
        Use the 'File' methods...
        ` pth=model.path >> "C:/Temp/MySkip.skp"
        if the file has never been saved it '' ! so trap for that??
        folder=File.dirname(pth) >> "C:/Temp"
        file_name=File.basename(pth) >> "MySkip.skp"
        file=File.basename(pth, ".*") >> "MySkip"
        ext=File.extname(pth).downcase >> ".skp"
        OR
        ext=File.extname(pth).upcase >> ".SKP"
        file_path=File.join(folder, file+".txt") >> "C:/Temp/MySkip.txt"
        f=File.open(file_path, "w")
        opens/makes the file to 'w'rite to...
        or 'r'ead, 'a'ppend, 'b'inary etc
        f.puts("Hello word!")
        f.close
        important to close any open file as it's 'locked' by SUp/Ruby otherwise...`
          pth = File.dirname( model.path )
          • Dan RathbunD Offline
            Dan Rathbun
            On new unsaved model, model.path returns an empty string.
            On an empty string, File.dirname("") returns ".", which usually means the current working directory (but is false really, as there is no actual path set for the model.)
            Dir.getwd() will return the path for the current working directory (which is likely to be the user's HOME directory, when Sketchup first starts, if no other script has changed it.)
            The HOME dir on Mac: ENV['HOME']
            The HOME dir on Win: ENV['USERPROFILE']
            So you test pth this way:
            pth =( model.path.empty? ? nil ; File.dirname( model.path ) )
            if pth
              # not nil, a valid path
              # do something here with the model path
            else
              # model was not saved
              # perhaps save the model here
              # then do something else
            I'm not here much anymore.
              As I explained in my earlier post πŸ˜•
              pth=model.path will be '' [an empty string] if the SKP's never been saved NOT nil, so a test like if pth will always return true because an empty string is not equivalent to false or nil ! so you need a if pth != '' test etc...
                Dan Rathbun
                @tig said:
                ... so a test like if pth will always return true
                NOT if you use the conditional statement on line 1 of my code example, which will set pth to nil if the model.path.empty? test is true, otherwise the valid path will be referenced by pth.
                There are many ways to do the same thing, here's another:
                if model.path.empty?
                  # perhaps save the model here;
                  pth = "some/new/path/filename.skp"
                  valid = model.save(pth)
                else
                  # it's a valid path
                  pth = model.path
                  valid = true
                if valid
                  # do some more stuff
                else
                  puts("Model save was unsucessful to path; #{pth}.")
                  So didn't spot your initial .empty? test.
                  Of course you could have avoided some more extra steps with a streamlined
                  if pth=model.path.empty?
                    ### do stuff with an alternative path
                  else
                    ### do stuff with 'pth' as it's not empty
                    Dan Rathbun
                    Isn't Ruby great! So many ways to do the same thing... we can all be happy and flexible.
                    phrase for today: COBOL SUCKS!
                      > else
                      > end
                      ### do stuff with 'pth' as it's not empty - incorrect. pth will have the result of .empty? - true/false.
                        Thomthom you are right!
                        Here is a fixed version
                            if (pth=model.path).empty?
                            else
                        πŸ˜’
