    SketchUp and Windows XP [64 bit]
    20 Posts 7 Posters 4.1k Views 7 Watching
      rock1
      okay, so it's not a good idea to install RAM more than 4GB specially for sketchup render on a 32 bit windows xp. actually i have an old hard disk 80gb. so, not willing to buy another hard disk for windows 7 64 bit as it will take a lot of space. ๐Ÿ˜† I'm planning to buy win xp 64 bit for a performance boost.
      But tell me would I need to buy new softwares as well?
      The softwares that I'm using that use up a lot of RAM are:
      %(#4000FF)[AutoCAD 2008
      CorelDRAW 12
      SketchUp 8 pro [renderers too]
      Photoshop CS3 extended.]
      are these compatible with windows xp 64 bit ?
      Signature removed by SCF Admin
        No, a 32bit Windows will never be able to utilize more than 4GB RAM.
        Buy an 10 year old OS that is no longer supported by Microsoft? Even lots of applications are dropping XP support. I'd really not recommend anyone buying that. Bite the bullet and get Win7 - it really is a good OS.
        What performance boost are you expecting? Remember 64bit != is speed.
        32bit software can be run on 64bit OS. The only thing that won't work is drivers - 64bit OS requires 64bit drivers. (And this is where I suspect Win7 got better support.)
          rock1
          microsoft has support for windows xp. i update my windows regularly. what kind of support are you talking about? Man, i would need to buy a new hard disk too. my current one is 80gb sata. ๐Ÿ˜† Don't have much money to spend ๐Ÿ˜†
            It has gotten End of Life declaration: http://windows.microsoft.com/en-us/windows/products/lifecycle
            Mainstream support ended in 2009 - though extended support is still active, until 2014. But as I mentioned, software developers are starting to drop support as well.
              rock1
              ๐Ÿ˜ž . so i'll have 2 buy a new hard disk. ๐Ÿ˜ž but how come i got my updates? maybe i had an old cd so got updates. haven't received any updates alert in few days.
                Aerilius
                Support ended 2009, that means Microsoft is not anymore obliged to provide any new features or Service packs or bug-fixes.
                The fact that you still get updates is because they only fix serious security vulneribilities (no other bugs), which is still too often the case.
                • AnssiA
                  Anssi
                  XP 64 is already a problematic OS. Try, for instance, to find a security package that supports it - the major players like Symantec or F-secure don't. It's not anymore a supported OS for Microsoft Office either, you have to use workarounds to be able to install it. And it's slower than Win7.
                  Anssi
                    rock1
                    Anssi
                    I'm currently using ESET smart security 4. it has both 32 bit and 64 bit versions. xp 64 slower than win 7? ๐Ÿ˜ฎ . i thought a lighter OS would be faster than a heavier OS.
                    • N
                      numerobis
                      i have xp64 running on my render nodes and it's working great!
                      It is NOT slower than win7 and it consumes LESS memory than 7. Which is good for rendering large scenes.
                      I have Kaspersky IS running on them for years without any problems - no workarounds!
                      The only thing that can be problematic with xp64 is the printer driver support and pdf writer compatibility because it installs some kind of printer too.
                      But if you need it for a workstation i would take win 7 x64 because it "feels" much better. I have 7 x64 running on my workstation (24GB) and macbook pro (4GB) ๐Ÿ˜‰
                        rock1
                        i don't care about the look ๐Ÿ˜† my printer is supporting winxp 64 bit. i think i should go 4 win xp. will save disk space too. donno the place where i can buy this OS. ๐Ÿ˜†
                        • N
                          numerobis
                          it's not only the look... it's more comfortable and has some useful features - e.g. better wifi- and network support.
                          If you wan't to buy a new license now for aworkstation, i would say get win 7 x64! Better take some more Ram if you need it - it's cheap now! ๐Ÿ˜‰
                          • sketch3d.deS
                            sketch3d.de
                            XP is a dead end road.
                            W7 needs ~1gb working memory instead of the ~512mb of XP, nothing one should care of on a 4gb+ system.
                            if you wanna use XP64 anyhow, check that drivers for every piece of hardware you are using are avail before buying it...
                            @rock1 said:
                            ...save disk space...
                            who cares?
                            Norbert
