    Show us yer desktop ...
    53 Posts 22 Posters 6.5k Views 22 Watching
    • L
      liam887
      Bah no dual monitor for me right now so ill make do with one...
      VISIT MY ONLINE GALLERY
      • RichardR
        Richard
        Organised right / Temp left!
        BUILTBRAND.COM.AU
        • GaieusG
          What do you use for that, Richard?
          I have had a look at the ones linked in this topic already but I am not convinced yet.
            Csaba have a look at Dexpot maybe?
            • Z
              Zacchia
              nothing more to say...
              • RichardR
                Richard
                Mate I just organised my icons into groups on my desktop (titled: Temp files, music / pitures, references, projects, applications, system) then took a screen shot. Then used that in photoshop as a guide, created a background that I liked with lines and titles for the groups. Then save and use as wallpaper. Easy!
                Problem I changed my screen res since and have been too lazy to relocate the divisions.
                I find it a really efficient way to stay organised, at any time just hit the "show desktop" icon and then go straight to the exact shortcut / file / app!! So easy!
                Everything working pretty much ends up on the left side for eventual filing when it fills!
                BUILTBRAND.COM.AU
                  You didn't use LayOut? That's a first πŸ˜‰
                  • RichardR
                    Richard
                    Yeah! πŸ˜„ Funny! Way pre LO days!
                    BUILTBRAND.COM.AU
                    • GaieusG
                      Too bad. I would like a simple desktop utility with which I can split my desktop into regions like that. I tried what Rich suggested but it is more complex than if I do not have anything but mess. πŸ˜’
                      • bazB
                        baz
                        Gaieus, Fences has been mentioned a few times above, I 'lurve' it, you might too, very easy to set up and customise and free.
                        Baz
                        http://www.stardock.com/products/fences/downloads.asp
                        Edit: Just noticed you have been pointed to it already.
                        • GaieusG
                          Yes, there have been a couple mentioned here and I am checking them out all. Thanks for bumping it - this is next then!
                          πŸ˜„
                          • GaieusG
                            Okay, played around with Fences (although once I completely screwed up my desktop). So does it seem any better now? πŸ˜’
                            Anyway, for me this is not a perfect solution either. It does not allow custom location inside the fences (works like as if automatic icon sorting were on in the Default Windows desktop settings).
                            I will try to get used to it and see what's next. Thanks! πŸ‘
                              What are you exactly looking for?
                              • GaieusG
                                Something like this actually. I keep many things on my desktop - but do not use the quick launch bar for instance. So things on my DT need some organizing. This is not bad for the time being.
                                Whenever I download something (meant as temporary thing like an skp file helping someone out), I also download it to my DT instead of my documents somewhere. This will eventually clutter my DT and needs regular clean-up. Now as I can separate my "normal" stuff from the litter I download every day, maybe it will be better.
                                  Aerilius
                                  I also use my desktop for temporary files or downloaded files. Thus I decided to ban all program icons from the desktop so that it's not anymore mixed. If I don't need a file anymore, I archive it into a well-sorted folder structure (or delete it).
                                  For programs, I use a launcher and a quicksearch, but there are many alternatives, like a programs menu, or Launchy (as mentioned above) or JumpPad (which is like a desktop).
                                    I presume your speaking about Dexpot? I do find it very useful. There's also a plugin for FF that can send particular file extensions to defined areas. So you can place .rb directly into your plugins when you download. QTT is an explorer that allows tabs in Windows Explorer with a handy image preview on hover and the ability to dig through folders without the clicking. I could go on πŸ˜’ but it's kinda OT
                                    • H
                                      HFM
                                      @Gaieus
                                      The left alignment of the fences takes some time getting used to, but the double click desktop cleanup never gets old πŸ˜„
                                      • RichardR
                                        Richard
                                        Thats what I love about the organisation I've used - anything downloaded and dumped to DT ends up on the left side naturally.
                                        Clean up is then just a drag and drop from the files left onto the folder shortcuts on the right!
                                        BUILTBRAND.COM.AU
                                        • DanielD
                                          Daniel
                                          Work computer - picture of the Meyer May house, taken by my father. At home, I use Microsoft's blue crystal background.
                                          My avatar is an anachronism.
                                          • michaliszissiouM
                                            michaliszissiou
                                            Just this.
                                            This particular grey color is coming from 2000. The same I used for Win XP, still the same now, on all my computers-OSs.
                                            No inspiration πŸ˜† But never, never shortcuts and documents on this. Even the apple dock is hidden.
                                            • 2 / 3
