    Steampunk Mobile Phone
    33 Posts 13 Posters 4.7k Views 13 Watching
    • EscapeArtistE Offline
      EscapeArtist
      Very cool.
      Finally, buttons suitable for my fat fingers to use for SMS.
      Too bad it's only a render (a very good one!)
        SketchUpNoobie
        What else can I say? This is eye candy! Great concept, nice modelling, and excellent renders. IMO, the render with the ruler looks the most photo-realistic. It looks too imperfect for a render. ๐Ÿ˜ฎ Looking forward to seeing your next project. ๐Ÿ˜‰
        Hmmm. I know I've seen this somewhere before. ๐Ÿ˜• Perhaps the Kerkythea forums a few months back?
        SketchUpNoobie: the complete noob in all things SketchUp.
          Technohippy
          Yep it was at the kt forums.
          thanks for your comments, my goal is realism, not perfection.
          http://www.realitybuildingdesign.co.uk
            SketchUpNoobie
            And you sure nailed it. ๐Ÿ‘
              Technohippy
              thanks man!
              • Bryan KB Offline
                ๐Ÿ˜ฎ
                • BoxB Offline
                  Such a wonderful piece of work.
                  And seriously valuable, if you could get it produced, perhaps with a larger screen, you would make millions.
                  I would buy one on the spot.
                    EscapeArtist
                    Is there any way you could share some tips to get that nice, buffed (but not too shiny) soft silver look with the wear scratches? It's very nice.
                    • majidM Offline
                      majid
                      ammmazing... really amazing , and good knowledge of KT materials (and render settings). ๐Ÿ‘
                        Technohippy
                        I'd be happy to, I'm doing some screenshots for you now
                          Technohippy
                          Thank you, I have looked into 3d printing for this but its expensive and just wouldn't do it justice. frankly i'd buy one too if I could afford it! although if it got made i figure i could afford it based on your figures!! ๐Ÿ˜›
                            Technohippy
                            thanks majid most of the work was materials, for render settings I use preset mlt(bpt) and for lighting I used one of bob groothuis's excellent globals
                              Technohippy
                              I started putting together a couple of screenshots and ended up turning them into a mini tutorial!
                              I should point out that the average size of the phone is 45mm x 95mm, and a lot of the work in this and the rest of the materials was ensuring the scale of the material was right for the piece!
                              This material was based on the silver available in the Metals Ashikhmin (mlt) library available at the Kerkythea website
                              the weighting of the layers is as follows
                              the anisotropic layer is left untouched
                              the only part of the matt/phong layer that is changed is the specularity
                              the real work in this material is the was in the specularity and the bump maps, bump map 1 was about making the metal seem imperfect and not perfectly flat (which is virtually impossible in the physical world and way too easy in the digital world)
                              bump 2 was about creating the micro scratches which accompany any piece of silver
                              Its a good idea to save this finished material to your material library if you want to use engravings.
                              For the engraving I used a monochrome frame i sourced at openclip art, I mapped it in sketchup to ensure the dimensions were correct prior to exporting. In kerkythea, I opened the materials editor for the engraving and selected the diffuse label in the reflectance panel. In the texture editor right click on the engraving bitmap and copy it.
                              left click the preview panel and choose your new material as saved above and once it has loaded click apply, then in the empty bump mapping panel select 'texture' and in the texture editor right click and paste. kerky will place the engraving bitmap, correctly mapped, into the spare bump map slot. Next fiddle with the strength control until it looks right.
                              Alternatively you can convert your image to a normal map using GIMP (which is what I ended up doing eventually) and use that instead. if you start by exporting a mapped image kerky will remember the mapping, so it doesn't matter if you use a different version of the image.
                              I hope thats not too in depth, once I get on a roll, I tend to cover ALL bases!!
                                EscapeArtist
                                ๐Ÿ‘
                                Thank you very much!
                                I'm going to try to get this to work in Thea.
                                • urgenU Offline
                                  urgen
                                  ....o-o-o Very cool! ๐Ÿ‘
                                  --pupil forever...------
                                    EscapeArtist
                                    Not to usurp the thread, but the silver mat I was able to come up with is not quite as good. Missing that soft haze yours has, but I've uploaded it over at the Thea forums if anyone wants it or can improve on it.
                                    Silver ingot
                                      Technohippy
                                      Looking good! if you produced that from my tute, then I'm happy.
                                      The only things I would change are the bump and specular maps and how they interact, I don't know how thea works in this regard, does it have the same procedurals as kerky?. what are you using for the scratches? they look a little minerally.
                                      I had a thought and googled 'scratch' under images and came up with the file which I based my scratches on
                                      http://www.stock-textures.com/images/wallpapers/44719319/Metal/metal-scratch.jpg
                                      I fiddled with it in GIMP using the photocopy filter to make it more monochrome, but this was the basic image.
                                      I think a lot of the hazyness in my image comes from the light probe... it adds so much realism.
                                      Also I love the sterling engraving... nicely done
                                        EscapeArtist
                                        Funny enough, that's the same scratch I used. I used a high pass filter in Gimp to even it out a bit. The minerally look is actually something I applied to make it look like a poured ingot; a displacement windy procedural texture, but it washes the scratch bump out. Maybe with some more tweaking I can get that soft haze. I don't know if it's the light probe, I used image based lighting as well to get some good color. Likely just need to add a detailed bump layer with a .jpg or .bmp for haze. Thea has a roughness setting, but it's much too heavy handed for this job.
                                          Technohippy
                                          LOL must be a good scratch then!!
                                          I think the haze must come from the specularity, primarily using the windy texture scaled either to match or at a slightly different scale from the windy bump.
                                          the windy bump on mine is very light, almost unnoticeable and quite large in comparison to the piece.
                                          question for you, I had heard thea can open kerky files, is this true?
                                            EscapeArtist
                                            To some extent, yes. The best way to do it is to save a simple scene with the mats from Kerky and then open it in Thea.
