    HELP !!! I don't know what to call this
    9 Posts 3 Posters 472 Views 3 Watching
      tchiu
      I am using Windows 7 64 bit.
      Here is what happen after a while. it happens when i use the "rotate" and "circle" tool.
      after i minimize and reopen the window, the screen turn black.
      Extremely frustrated here.
      madness
        Hi tchiu,
        What happens if you turn hardware acceleration off under Window > Preferences > OpenGL?
          tchiu
          @gaieus said:
          Hi tchiu,
          Yay!, it works. Thank You!!
          but why does this happen?
            Your video card (or just the driver) is not capable to fully support OpenGL. You can try to update the driver first to see if it helps (with HW acceleration ON). If not, learn to live with the slower performance or get a decent card. What card do you have, by the way?
              tchiu
              sorry i thought the report button was respond.
              i am suprised that my video card is not good enough, because this is a new Dell XPS 15 with NVDIA GeForce GT 540M 2GB.
              Is it a setup problem then?
                Well, that card should do it (in fact, that card is a fairly good one which makes me jealous). Make sure to update the driver then. Also, under the nvidia card settings, set antialiasing and anisotropic filtering to "application controlled".
                  rock1
                  @gaieus said:
                  Well, that card should do it (in fact, that card is a fairly good one which makes me jealous)..
                  ๐Ÿ˜† which card you have Gaieus?
                  Signature removed by SCF Admin
                    GeForce 9600 GT (1Gb). Not bad, not complaining - but it could be better/faster/bigger...
                      tchiu
                      I turned out that i wasn't running that card at all.
                      The problem is now fixed and is running smoothly
                      Thank you very much.
