    Extrude line on path - Help-
    8 Posts 3 Posters 517 Views 3 Watching
      piskerlo
      Hello guys!
      I'm Italian and I do not speak English very well. I wanted to know, there is a plug-in that extrudes a border along a path? for example, "extredelinetool" but with the path.
      thanks for your help
      bye
      Michele
        see Projection by Didier Bur πŸ˜‰
        last tool of the bare-tool πŸ€“
          piskerlo
          thanks for the link!
          Unfortunately no good for what I do.
          I try to extrude a command line not only in blue axis but also in red.
          Maybe, I'll explain attaching photos!
          Thank you!
          01
          02
            Extrusion Tools zipped set ?
            EEbyVector to extrude selected edges along a picked path??
            EEbyOffset to offset faces etc ???
            Can you please post a before-and-after image so we can see what you want to have made...
              piskerlo
              Ok. I'm sorry and you have patience with me. πŸ˜„
              I try to attached these photos and I hope you understand!
              Thanks for your time
              before
              after
                You want to be able to offset the topmost edges a certain amount.
                Because they are not coplanar you'll have problems with any 'offset' tool.
                The extruded surfaces will be 'twisted' - if you viewed your 'after' SKP with Hidden Geometry 'on' you'd see triangulated forms rather than flat planes...
                  @Tig
                  It's a pity that your "Extrude Edges By Offset" must be only "Coplanar" πŸ˜‰
                    piskerlo
                    Thanks guys! You are the best!! πŸ‘
                    πŸ˜„
