    Newbie to Sketchup / Ruby
    12 Posts 5 Posters 2.3k Views 5 Watching
      BillM
      Hi Everyone,
      I'm Bill from the UK and new to Sketchup.
      I'm currently a programmer for a truss rafter design program and started creating Ruby scripts from a .NET application that will create the truss geometry.It creates all the beams, nail plates etc that represent the truss in the model.
      Currently the truss is added as a component definition containing beam and plate groups. So we have a separate group for each beam and plate in the truss. Typically there can be up to 20 unique beams and plates per truss component definition. With many trusses it will result in many groups perhaps hundreds.
      The truss definitions may well be repeated as component instances in many locations throughout the model. With all these groups it has a dramatic effect on the execution on the script.
      To increase the speed I have changed the script so that I don't create separate groups for all the beams and plates. This speeds up the import greatly and the result is the same visually but I now don't have the beams and plates as groups for BOM and solid information. Once loaded into SU the speed is fine.
      As I am new to both SU and Ruby scripting is there anyway I can increase the speed of the script execution or is it just that I have so many groups defined. Any help greatly appreciated
      Thanks very much.
      Bill
      • TIGT Online
        BillM
        I've moved this post the the Developers' forum - although you are a 'newbie' it'll get more exposure here...
        Firstly it'd be good if you could post an image of a typical 'trussed-rafter' and perhaps some code [use 'code' tags] so we can appreciate the issues better.
        Whenever you have a repeated object make a component-definition and place instances - this is the most efficient method. So each type of trussed-rafter, nail-plate etc can all be 'components'. The timber parts of the trusses will usually be too differing to allow the use of a component [although square-cut members could be 'componentized' and then scaled in their length?] - so the 'wood' can to be made as groups [note that these are only a special kind of definition/instance though]...
        Your code should make the trussed-rafter-component definition and then add instances/groups into its entities collection. Then place instances of the trussed-rafter-component as needed.
        Clearly the definitions of the nail-plates etc need to exist prior to you placing instances of them within a trussed-rafter-component definition...
        It sounds like you are already doing it much as I would approach it...
        Some examples will help us help you...
          Check out the Optimization sticky thread for various optimizations within SketchUp Ruby: http://forums.sketchucation.com/viewtopic.php?f=180&t=25305
            BillM
            Thanks for your replies
            Below is a example of one truss. This will run execute very quickly but I do have models with many trusses that take a while to execute.
            I take your point about making the plates components as these are inventory type items but the truss beams/pieces are mostly unique with different lengths, cuts etc..
            I did do a simple test with a script that just adds a few hundred empty groups. This also ran very slowly.
            I've attached the script that creates this. Please excuse any bad coding practices this is my first attemp at SU and Ruby.
            https://lh4.googleusercontent.com/-zvWoUxX4Xtw/TgsU01FNqpI/AAAAAAAAABE/VeWPN91JCag/s800/SUTruss.JPG
            Ruby script for Truss
              Looking at the code now.
              One thing I'd strongly recommend is wrap all your code into a module with a unique name. Otherwise it's all added to the global namespace and you risk conflicting with other plugins that doesn't use namespaces.
                <span class="syntaxdefault"><br />def&nbsp;draw_face</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">group</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">points&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;</span><span class="syntaxdefault">entities&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />&nbsp;&nbsp;entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_face&nbsp;points<br />end<br /></span>
                Why do you use a wrapper like this? It's add a lot of unnecessary method calls and object creations.
                Instead of
                <span class="syntaxdefault"><br />grouppiece&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">grouppieces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_group<br />grouppiece</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"T1"<br /></span><span class="syntaxdefault">points&nbsp;</span><span class="syntaxkeyword">=&nbsp;<br /></span><span class="syntaxdefault">draw_face</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">grouppiece</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">points&nbsp;</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">points&nbsp;</span><span class="syntaxkeyword">=&nbsp;[...]<br /></span><span class="syntaxdefault">draw_face</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">grouppiece</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">points&nbsp;</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">points&nbsp;</span><span class="syntaxkeyword">=&nbsp;[...]<br /></span><span class="syntaxdefault">draw_face</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">grouppiece</span><span class="syntaxkeyword">,&nbsp;</span><span class="syntaxdefault">points&nbsp;</span><span class="syntaxkeyword">)<br />...<br />&nbsp;</span><span class="syntaxdefault"></span>
                do this:
                <span class="syntaxdefault"><br />grouppiece&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">grouppieces</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_group<br />grouppiece</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxstring">"T1"<br /></span><span class="syntaxdefault">ents&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">grouppiece</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />points&nbsp;</span><span class="syntaxkeyword">=&nbsp;[...]<br /></span><span class="syntaxdefault">ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_face</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">points&nbsp;</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">points&nbsp;</span><span class="syntaxkeyword">=&nbsp;[...]<br /></span><span class="syntaxdefault">ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_face</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">points&nbsp;</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">points&nbsp;</span><span class="syntaxkeyword">=&nbsp;[...]<br /></span><span class="syntaxdefault">ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_face</span><span class="syntaxkeyword">(&nbsp;</span><span class="syntaxdefault">points&nbsp;</span><span class="syntaxkeyword">)<br />...<br />&nbsp;</span><span class="syntaxdefault"></span>
                Should increase some performance. Though probably not greatly. But if you are running thousands of iterations - which it sound you might do - it could help some.
                  BillM
                  I've tried these small changes but it still looks like the number of groups is causing the speed issue.
                  An example script with piece and plate groups defined take 55 sec to execute and 5 sec without these groups defined. This has the same number of faces etc just many more groups.
                  • TIGT Online
                    There are typically 8 timber 'groups' in a truss - 2 rafters, 1or2 ties, 2x2 struts etc - probably one of each type.
                    There are perhaps 4/5 different plate components in a truss - several of each; make a set of standard plates as SKPs and load/insert these as needed.
                    Make each type of truss as a component and insert multiple instances of it at the centers needed along the wall-plate.
                    You seem to be drawing all the trusses' timber-parts' faces... draw one vertical face and then push pull it to suit the timber's thickness.
                    It shouldn't take that long to process this type of thing - it's relatively simple...
                      kwalkerman
                      What about wrapping everything with "start_operation" and "commit_operation"
                      (http://code.google.com/apis/sketchup/docs/ourdoc/model.html#start_operation)
                      this can significantly improve execution time as the model is not trying to track all the changes as they are made, but only updates once, when "commit_operation" is called.
                      Karen
                        Karen
                        Given that you use the disable_ui argument.
                          BillM
                          Add update on the original problem with the speed import of Trusses into SU. I've done as TIG suggested making components of all pieces and plates that are the same even if there are in different trusses.
                          This has made a huge difference in speed as the number of groups has reduced. The import has gone from 55 secs to 4 secs.
                          Thanks for your help
                            Jim
                            Bill, Serge, Everyone - I've moved the Hotkeys discussion to a new topic. Keep on trussing.
