    [Plugin] Solids Penetration Check
    23 Posts 7 Posters 15.7k Views 7 Watching
      Trying to read your code - but I struggle to follow the code flow. Seems that your indentation isn't properly aligned throughout your code...
      • voljankoV
        voljanko
        Updated version:
        -now is a tool (you can zoom to check the penetration area)
        -automatic x_ray view
        -red colored penetration area
        -new name 😄
        SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
          Now seems very cool 😄
          • K
            kyyu
            @thomthom said:
            @voljanko said:
            I would also like to change the colour of the result to make it more visible,but I don't know how.
            Any suggestions?
            Create a material and apply it to the entities.
            http://code.google.com/apis/sketchup/docs/ourdoc/material.html
            ` my_material = model.materials.add( 'IntersectionMaterial' )
            my_material.color = 'orange'
            face.material = my_material
            group.material = my_material`
            voljanko, I see this is how you did it in your plugin. But the way you have it set up, you add a new identical material every single time your plugin is run. You can open up "Window > Model Info > Statistics" to check the number of materials.
            You don't need to define a new material. Instead use the following, which will only ever add one pre-defined material to your drawing, no matter how many times you use it:
            group.material = 'red'
            • voljankoV
              voljanko
              Ok,thanks.
              Updated.
              Please note,if you have a big model (more than 20 solids),the plugin will need more time to compute all the intersections.
              If you want to see that plugin is doing something (not freezed),you can select the Outliner (Window menu) as the activity display.It can be some kind of progress bar.
              • K
                kyyu
                @voljanko said:
                Please help me find the solution for this bug:
                -when one solid is a subcomponent and a subgroup in a component, the plugin can't find the penetration.
                I know the problem is in line 132 def1=solid1.entities.parent ,but don't know what to do about it.
                You probably have more experience playing with components, than me. 😛 But what I can see is, there is no need to blame sub(groups or components), yet. Your plugin doesn't even work for two simple intersecting components. "def1=solid1.entities.parent" finds the definition of groups, not components. Component instances don't have the method for "entities". It's the component definition that has that method. That's why the error message saids undefine method. It should be something like "def1 = componentInstance.definition" for components.
                Also, another strange thing(bug?) I see is when you have (group or component) inside a (group or component), I get a volume of "-1.0"
                • voljankoV
                  voljanko
                  Ups,I was sure that tested with components.Now it is ok and updated for download.
                  Now the code indentation is properly aligned so perhaps readable 😄
                  You wrote :"Also, another strange thing(bug?) I see is when you have (group or component) inside a (group or component), I get a volume of "-1.0"
                  Sketchup assign the volume to -1 when the item is not a solid.If you mean something related to my plugin,please explain more.
                  You wrote:"That's why the error message saids undefined method."
                  How do you get this message?Hod do you debug? Im only using message boxes to debug.
                  • voljankoV
                    voljanko
                    EDIT:SOLVED
                    checkSolids.skp
                    • K
                      kyyu
                      No, I just mention it just in case you didn't know about it. Components are hard for me to follow, so I just briefly looked through your code to learn more. At 1st, I was thinking this was causing your bug. But then figured out the error message.
                      Error messages are printed out in the Ruby Console. See picture of one way I debug, by running small snippets of code with Jim Foltz's "Web Console" plugin. Jim also has a "Ruby Toolbar" plugin, that lets you reload your plugin. But I think you need to add a check for if the plugin has been installed previously, or you will get multiple menu items.
                      require 'sketchup.rb'
                      if( not file_loaded?('solids_penetration_check.rb') )
                      	plugins_menu = UI.menu("Tools")
                      	plugins_menu.add_item("Solids Penetration Check") { penetrationcheck }
                      file_loaded 'solids_penetration_check.rb'
                      • voljankoV
                        voljanko
                        Thank you thomthom for your suggestions.
                        I have test the plugin on a model with 31 solids organised in many subgroups and it takes 40 seconds to
                        find 10 "penetrations".So it is slow and need some speed-up like you suggest.
                          richhaas
                          Any way to get this to Intersect With Model to make bright orange(selectable color) lines to check all the other geometry that is NOT solids?
                          Richard
                          • voljankoV
                            voljanko
                            Yes,there is a way,why are you asking 😄
                            Anyway,if you want to find the mistakes,that makes your group a non-solid,there is another plugin - Solid Inspector from thomthom.
                            • G
                              glro
                              is the plugin able to check intersections between solids when they are part of components?
                              i checked, and it doesn't seem so
                              the connections are solids, intersection is detected when they are outside the component, and not when theyare inside
                              is there a way to solve the problem?
                              bracing connection intersection
                                richhaas
                                I don't draw with solids. Need a tool to check all the other things I draw to look for possible overlap conflicts between components, groups etc. 'Tile components' "intersecting" 'cabinet components' for instance...
                                Richard
                                • G
                                  glro
                                  EDIT:SOLVED
                                  i cannot help you concerning the ruby programming, but i tried your plugin on the model included in your post, and it worked perfectly; event when i made a component from the component and the group
                                  i tried it also on the file included; components with solids inside, it worked, but in a strange way; i would like to know which are the components that interfere, but the information vanishes when the program stops...
                                  where are the components that intersect?
                                  penetration detected
                                    Matt666
                                    Aaaar it does not work with free versions... Can you do something?
                                    Error: #<ArgumentError: 'intersect' is a Pro only feature.>
                                    C:/Program Files/Google/Google SketchUp 8/Plugins/solids_penetration_check.rb:141:in intersect' C:/Program Files/Google/Google SketchUp 8/Plugins/solids_penetration_check.rb:141:in check_penetrations'
                                    C:/Program Files/Google/Google SketchUp 8/Plugins/solids_penetration_check.rb:32:in activate' C:/Program Files/Google/Google SketchUp 8/Plugins/solids_penetration_check.rb:159:in select_tool'
                                    C:/Program Files/Google/Google SketchUp 8/Plugins/solids_penetration_check.rb:159:in `penetrationcheck'
                                    C:/Program Files/Google/Google SketchUp 8/Plugins/solids_penetration_check.rb:13
                                    Frenglish at its best !
                                    My scripts
