    How to transform a normal room into an Ames Room...?
    32 Posts 6 Posters 7.0k Views 6 Watching
    • G
      gulcanocali
      Hi Simon,
      Yeah, I do not know a way to quickly apply the same transformation to all items in the room.
      But, I still do not get why you need to apply the transformation to ALL the points. The way I see it, if you preserve the "normal" view from front, all you need to do is to make sure other objects in the room maintain some "reality" in other views, i.e. table legs should touch the ground, if there is a picture frame on the wall it should stay touching the wall, etc and that does not require to update all the points of the object as in table example before.
      Anyways, I must be missing a point.
      Good luck. Do tell, if you find a quick solution, I am curious now πŸ˜„
      Gulcan Ocali
      Product Manager
      http://www.Tgi3D.com
        driven
        hi Simon,
        i played a bit more with the locked camera/scene approach and each plane appears to need a different transformation, I think you could 'fudge' an acceptable view this way, but it depends on your 'purpose'.
        I once designed a theatre set on this principle and it was only 'complete' from one spot as the audience entered,
        from then on it was very disconcerting to watch, but that was the point.
        why do you need this? if you don't mind saying.
        i resized your room to start...
        • B
          bjornkn
          Apart from Fredos Scale tool I can only think of SketchyFFD that may help you (apart from Amorph and hand-editing).
          AFAIK SketchyFFD only works on lines and faces (no groups or components), and you can only have one FFD in a model.
          But I can't really see why you think that Amorph can't do it? Or using construction lines from camera through points (Amorph can make these too BTW by selecting a line etc and using the slice tool). With these tools you should be able to deform any objects inside the room, as well as the room itself. It may be a little tedious though if you want to have a lot of details, like long tables with lathed legs etc...
          I noticed that you started a new thread, but chose to post in this old one..
          • T
            treehaus
            Hi everyone,
            thanks again to Gulcan, John & Bjorn.
            This may sound pedantic, but: the illusion needs to be perfect, if it be from one angle only.
            The room will have objects in background, midground and foreground, so the displacement parallax needs to be held to an absolute minimum. Putting rectangular pictures or furniture in a trapezoidal room won't cut it once this is projected onto a 35ft screen. You will see the mismatch and this will take your attention away from the drama.
            This sort of thing was done on Lord of the Rings and Coraline. I can seriously find nothing at all about projection transformations as plug ins for the big commercial platforms like Maya, Cinema 4D or 3D Max. I think the only way to do this is to build a plug in myself. Too bad I'm not smart enough. 😞
            • B
              bjornkn
              Nothing prevents you from adding the distortion to any objects you like, for instance to the furniture. How perfect it will look depends on how much work you want to put into it.
              Using Viewlock makes it a lot easier. You could even make 2 tables next to each other that slants different ways, but still looks like they are with flat/horizontal tops. AFAIK the original Ames room contained a channel where a ball was rolling "upwards".
                driven
                hi Simon,
                the SU 'Scene and Stage' ruby or the updated 'Advanced Camera Tools' [Pro Only] ruby, combined with Fredo Scale 'tapering to target', is almost working...
                I just don't know 'Fredo Scale' well enough, but if you set a 'line' on the "eye line" and use that for the scale orientation it seems to work.
                by that I mean all components scale at once, in the right directions.
                needs more playing
                • T
                  treehaus
                  Hi John,
                  thanks again for getting back.
                  I couldn't find the scene and stage ruby - I will also try the Fredo Scale one last time. Maybe it can be jinxed to behave appropriately.
                  Best Regards,
                  Simon
                    driven
                    it's actually the film and stage plugin, the mac version...
                    sorry
                    it was for v5, if it doesn't work for any reason post back here and I'll PM my copy that I may [or may-not] have tweaked over the years...
                    Error 404 (Not Found)!!1
                    (sketchup.google.com)
                      driven
                      i did have a bit more of a play trying to sort out a basic workflow, but when you started your new thread I gave up.
                      here it is if your interested.
                      the scenes should have the locked camera position...
                      this needs a tiny more tweaking , but all done with fredoscale
                      build a new room on the wireframe then scale that to the ames room dims.
                      having made one on a drawing-board in the past, I'm just curious to see what SU can do...
                      • T
                        treehaus
                        Hi John,
                        Wow. I'm impressed. That looks pretty good - definately the best so far.
                        I tried to download the stage plugin - but it said something about PPC and crashed.
                        I think I will try to develop what you have already started. Thanks again for all your time and help.
                        Best Regards,
                        Simon Sieverts
                          sorry
                          There is an update to Film and Stage available for SketchUp 8:
                          http://sketchup.google.com/intl/en/download/plugins.html
                          It's now called "Advanced Camera Tools"
                          (sketchupdate.blogspot.com)
                            driven
                            that ones a "Pro Only" .rbs which is a real shame.
                            I think Google should price things like this and solid tools as free for 'Pro' or individually for 'Free' users.
                            The free old one still works on my Intel mac so I had a look and...
                            the installer Plist has v5 as the target so your better off right clicking it to show package content and then copy/paste the contents of the 'installer items' folder directly into your plugins folder.
                              The old version had many bugs which has been addressed in this new version. In addition to a few improvements. It's not just a repackage.
                                driven
                                it looks great, but it's not free,
                                the mac version of the old one has never given me any grief [i.e. bug-splats],
                                there was a problem with exporting the camera view, but that wasn't specific to 'film and stage' and that's been sorted out in v8.
                                it's actually one of the ones I leave permanently installed, without any obvious problems.
                                • Alan FraserA
                                  Alan Fraser
                                  I scanned the thread briefly, so apologies if it's already been suggested...but wouldn't the easiest way simply be to construct a perfectly normal room then apply FFD 2x2? Why work out all the trigonometry when SU can do it for you? πŸ˜‰
                                  Ames.skp
                                  3D Figures
                                  • 2 / 2
