    Hidden objects are visible
    9 Posts 5 Posters 1.2k Views 5 Watching
      archtrot
      Sometimes when I open SU8 models, geometry that should be hidden is visible.
      I can reopen the file and everything is fine.
      Has anyone experienced this?
      Windows 7
      64-bit
      Intel Core i5 3.2 GHz
      Nvidia Quadro FX 1800 with 768 Mb RAM
      • ToboboT Offline
        Tobobo
        Have you got Hidden Geometry on?
        I know its a stupid question but i have done it in the past. 😳
        Toby
        Philippians 4:13
          archtrot
          No...it's not anything obvious like that.
          It has nothing to do with view settings or styles.
          It happened to me again this morning. I opened a model and a bunch of items that should have been hidden were visible. I immediately closed and reopened...everything is fine. It has happened with a coworker too, which makes me think it's a bug rather than an isolated issue with my installation.
            Can you share a model where you see this behaviour?
            I have never - to this date - seen this behaviour you describe.
            Is it not that the visibility state has been saved with some scenes?
            Is it geometry that's hidden, or placed on hidden layers?
              @rv1974 said:
              +1. It used to happen a lot in the past. I think it's some ruby fault (or confict between ruby and the SU starting).
              In which case - does disabling all rubys (temporarily renaming the Plugins folder) correct the issue?
                rv1974
                +1. It used to happen a lot in the past. I think it's some of the rubys fault (or confict between ruby and the SU starting).
                  rv1974
                  It's hard to tell. I migrated to the new PC (Win7 X64) and did some order in my plugins mess.
                  What was deleted me does not remember.
                  • ashscottA Offline
                    ashscott
                    Quick comment: I've had a similar problem that I couldn't reproduce on other machines - turned out that my graphics card was packing a sad. Something us simple as updating your drivers might help
                    Just some stuff I do with Sketchup.
                      archtrot
                      Thomthom,
                      I believe that it is only hidden geometry.
                      I tried renaming the Plugins folder so it wouldn't load at startup.
                      That seems to eliminate the problem. Any suggestions on how to proceed if it's a Ruby conflict?
                      by ashscott on Tue Jun 21, 2011 5:26 pm
                      ashscott,
                      What do you mean by "packing a sad"? I've not tried updating drivers yet. The card has been performing great so far.
                      Thanks for the input.
