    [Plugin] Selection Toys
    594 Posts 121 Posters 468.2k Views 121 Watching
      danbig
      I think I'm still missing something simple on how to operate this incredibly helpful plugin.
      I have a model with hundreds of instances of multiple components. I want to select all the instances of a single component definition. I cannot seem to get the plugin to do this; can someone go through the steps to perform this function?
        Dan, this doesn't help you with the plugin I know but for something like what you want to do, couldn't you just right click on the component's thumbnail in the In Model component library and and choose Select Instances?
          With the plugin, you should just right click on one instance and go to Instances > Select all or active (it can select instances even inside other components/groups)
            danbig
            Hi Dave -
            Yes, that would work. Thanks for the tip. I haven't used the component library to browse components in my model very much, so I wasn't aware of that function.
            Gai - that's exactly how I'm trying to use the plugin, to no avail. I'm stumped.
              FWIW, Csaba's directions work for me but using the Components tool on the Selection Toys toolbar doesn't seem to do anything.
                Can you provide a sammple model and/or video?
                Any errors in the Ruby Console?
                  Maybe I'm using it wrong Thomas. I've tried selecting a component which I know has more than one instance. Then I click on the tool with the two green boxes. Nothing changes. I've tried getting the tool first and then clicking on a component. Nothing different there, either. I'll send you an example model though.
                    That button is to filter the selection.
                    To select similar instances, use the context menu.
                      Thanks Thomas.
                      • leedeeteeL Offline
                        leedeetee
                        Could someone help me with this ...
                        I'm trying to get the Selection Toys to work, I have the following fodlers in Plugins:
                        TT_Lib TT_Lib2
                        and then also tt_selection_toys in there, too.
                        SU loads up fine but then nothing is shown in the plugins.
                        What am I doign wrong?
                        Thanks.
                          leedeetee
                          @leedeetee said:
                          TT_Lib TT_Lib2
                          Thanks.
                          IGNORE ME! Sorry, Sorted. πŸ‘
                            danbig
                            I get no error message, but the context menu doesn't seem to do anything for me. I'll check the console next time I try.
                              Can you describe more specifically the steps you are doing? And what you have pre-selected etc?
                                danbig
                                In the model, I have 420 instances of a single component.
                                I select one of the instances, and right click.
                                Under the "Instances" context menu, I choose "Select All".
                                What I want to happen, is that all 420 instances of this component to be selected. In my case, nothing happens. Nothing posts to the console. Am I trying to use it correctly?
                                  Can you post or send me a sample model?
                                    Lorelalala
                                    Really useful stuff!
                                    TT, Thank you so much!
                                      danbig
                                      Here's a sample model. I can't get the selection toys plugin to select all the instances of either component. I'm pretty sure that there is something simple about operating this plugin that i'm missing.
                                      Test 1.skp
                                        I tried both Instance -> Select Active and Instances -> Select All and both of them worked... πŸ˜•
                                          (Okay, so this was when I got stumped for losing my toys.)
                                          Now I am fine and I also tried and can select all or active instances with no issues.
                                            danbig
                                            Strange. I wonder if I have an obscure conflict with other plugins that doesn't result in an error message, but which prevents selection toys from operating normally. Is such a thing possible?
                                            I'll scrub through my plugins and see if it works when it's the only plugin installed.
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 29
                                            • 30
                                            • 20 / 30
