    Ruby Plugin Help
    10 Posts 4 Posters 439 Views 4 Watching
      AlexS
      Hello,
      I've made a a plugin for Ruby before, but I'm writing another one and it requires something a bit tougher... πŸ˜„
      I want to gather all the groups that have the name that starts with "SPECIAL". In reality these groups will contain no faces, but simply curves. I want to get each "point" in the group and write it to a file (I know how to do that).
      Now question is, how do I get the points for a line segment?
      If I need to clarify more simply ask,
      Thanks,
      Alex
      • TIGT Online
        verts=[]
        group.entities.each{|e| verts << e.vertices if e.class==Sketchup::Edge }
        verts.flatten!
        each e.vertices returns a two element array, flatten explodes these
        inner arrays so that verts is then one array...
        verts.uniq!
        this removes duplicate vertices from verts, i.e. because in a curve
        most vertices get listed twice because they will have two edges...
        points=[]
        verts.each{|v| points << v.position }
        points is now a list of all points represented by
        all of the edges' vertices inside the given group...
          AlexS
          Thanks, TIG!
          How can I separate the groups whos names start with SPECIAL and the ones that don't, though? Thanks for your help,
          Alex
          EDIT: And also, I'm trying to use the 'puts' function, but when I'm doing this: file.puts "<model/>", it thinks that when I use the < & > symbols that I'm trying to define a constant or something. This is the same for the 'print' function. How can I add the < > characters? Thanks for your patience with me. πŸ˜›
          • Dan RathbunD Offline
            Dan Rathbun
            Well since you use the group.name= method to set the group's name, you will use the group.name method to retrieve it. Use a comparison expression:
            verts=[
            Sketchup.active_model.entities.each {|ent|
            if ent.kind_of?(Sketchup::Group) && ent.name == 'SPECIAL']
            ... then iterate the group's entites ...
            ... then flatten and uniqify the verts array,
            ... which can be done in one line:
            %(#BF0000)[verts.flatten!.uniq!
            end # if SPECIAL group
            points=[]]
            ... rest of code as shown above.
            I'm not here much anymore.
              AlexS
              Sorry I wasn't clear enough... I mean to retrieve whatever groups whos name STARTS with SPECIAL... Is there is an equivalent to C's "StartsWith" in Ruby?
                Dan Rathbun
                You test for substrings using .include?
                if ent.kind_of?(Sketchup::Group) && ent.name.include?('_SPECIAL_')
                If you wish to really use starts with, then you can test a subrange of a string:
                if ent.kind_of?(Sketchup::Group) && ent.name[0..8] == '_SPECIAL_'
                or:
                if ent.kind_of?(Sketchup::Group) && ent.name[0,9] == '_SPECIAL_'
                You can look up Core methods online:
                http://www.ruby-doc.org/core-1.8.6/index.html
                .. or download the CHM for offline use, from my post here:
                http://forums.sketchucation.com/viewtopic.php?f=180&t=10142&p=266725#p266725
                  You can use RegEx:
                  my_string.test(/^_SPECIAL_/)
                  Or simple text operation:
                  my_string[0,9] == '_SPECIAL_'
                  • TIGT Online
                    To explain a little more about 'patterns'...
                    /^_SPECIAL_/
                    The ^ at the start says 'starts_with'
                    A $ at the end says 'ends_with'
                    /_SPECIAL_$/
                    Using both is equivalent to 'is_equal_to'.
                    Using neither says 'contains_this_text_anywhere' in the string...
                    Note that the my_string.test(//) method is equivalent to my_string =~ // that you might also come across...
                    The whole pattern thing can be quite complex - e.g.
                    /^[^a-z0-9]/
                    says starts with any character (^ inside the [] reverses the match) that is NOT a lowercase letter or number.
                    With gsub you can use something like it to 'squeeze' everything out of say a file-name so it only uses letters, numbers, '-' or '_' - e.g. as used in OBJ-file naming conventions, thus:
                    filename.gsub!(/[^-_A-Za-z0-8]/, '_')
                    There are several websites that cover this in considerable detail.......
                      AlexS
                      Thank you guys, you've been a great help.
                      Now... just one LAST question. I'm trying to use the 'print' and 'puts' function, and I'm trying to put in these characters: < >
                      But when I load Sketchup, it gives me an error. I guess it thinks I'm trying to do something within the string when I put a < or >.
                      How can I fix this?
                        Dan Rathbun
                        Those characters are both Ruby operators and instance method names.
                        Use the String concate method + to add those chars (which must be quoted.)
                        my_string = 'Some special string' + ' > ' + 'the last part of the string.'
                        or you can use replacement within double-quoted string:
                        my_string = "The value: #{biggernum.to_s} > #{smallernum.to_s}"
                        where biggernum and smallernum are numeric references.
                        The 3rd way is to use the Integer instance method chr if you know the character's ordinal within the UTF-8 set.
                        Since decimal 60 is the ordinal for "less than" ...
                        60.chr returns the single char string "<"
