    Question plugin rectangular subdivision
    16 Posts 6 Posters 2.7k Views 6 Watching
      What exactly would you need it for?
        jorge2011
        For example, I had to make this mesh.
        so I got the idea for a plugin to create meshes from a pre-selected face
        01.skp
          bjornkn
          Looks pretty flat to me?
          Anyway, here is a method that can be used with any slope, and even verticals.
          Just rotate slicer grids as necessary, if you need the grid perpendicular to a face.
          And add another slicer array at 45 degrees (snap it to a corner) if you need the diagonals.
          It's actually often faster than the Move/Copy/Erase method πŸ˜„
            kyyu
            You might have a look at thomthom's Plan Tools: http://forums.sketchucation.com/viewtopic.php?t=30512
            I once wrote a test plugin to crop, using a face. I later saw, thomthom had made the exact same tool. There is a youtube video showing it, in the thread.
              jorge2011
              bjornkn, thanks for your reply and example.
              But I find it a complicated method.
              kyyu
              thank you very much. It is a very good tool, not knew.
              I've tested this plugin and it works very well with lines, but with smooth lines not working properly.
              Maybe I can consult to senior thomthom about this problem.
              thank you very much for your reply
              Sub-div.skp
              • sdmitchS Offline
                sdmitch
                jorge2011, Check out my "Mesh Maker.rb". I used it on part of 01.skp as a test and on the shape in Sub-div.skp. The resulting models are attached along with the plugin.
                01.skp
                Sub-div.skp
                Mesh Maker.rb
                http://sdmitch.blogspot.com/
                  jorge2011
                  oooo thank you very much. Works perfect
                  It is the first plugin I ask you very kindly and you has scheduled.
                  thank you very much again.
                  Just a suggestion:
                  • is possible add subdivision to the creation of inclined faces?
                  • is possible use the axles of a group or component? currently uses the axis the model.
                  • It is possible create the mesh of subdivision in the face inside of a group or component?
                  • is possible remember the last settings used?
                  Greetings
                  • sdmitchS Offline
                    sdmitch
                    jorge2011, All things are possible but are they worth the effort to achieve them. I will consider your suggestions and try to impliment them if possible. I make no promises though.
                      jorge2011
                      Thank you very much for your response. and thanks for your time.
                      • sdmitchS Offline
                        sdmitch
                        jorge2011, The attached version of Mesh Maker.rb saves the previous cell size entered and will work on tilted faces, suggestions 1 and 4.
                        Mesh Maker.rb
                          jorge2011
                          Thank you very much sdmitch.Works perfect
