Question plugin rectangular subdivision
16 Posts 6 Posters 1.8k Views 6 Watching
    jorge2011
    There is some plugin that allows creating a rectangular subdivision, like the attached image?
    1 - Choose the surface
    2 - Run the plugin
    3 - Choose a starting point and axis
    4 - Income to the extent of the grid (eg 20:20)
    5 - Previewing a grid and I can modify values
    6 - I press the enter key
      rocorona
      The image you posted shows a "triangular subdivision", more than rectangular. This is not important anyway.
      Don't know if there is a plugin for this, but it appears simple enough, to do without.
      Create a component (a sticky one will be better) with the grid, big enough. Place it on the face and scale to your need (Fredo6 scale, if you want more options). Then select face and component and run the command "intersect selected". Delete component and you are done.
        bjornkn
        Or just use the Move/copy tool?
        Select left edge,
        Move tool with Ctrl down and drag the edge over to the right one and type the number of divisions, like "8/".
        The same the other way, selecting the lower edge and move/copy upwards with divisions.
        Or use "8*" instead if you need to have each square a specific size.
        If you need the diagonals you just a diagonal line and uses the Move/Copy tool with that one too.
        Erase all unneeded edges.
        It will take you 15 secs? It would probably take longer just to find the plugin on the menu and fill in the settings? 😉
        Sometimes we forget that SU does have a powerful toolset by itself, and that we don't need a plugin for everything?
          There's a new plugin that subdivides faces:
          http://forums.sketchucation.com/viewtopic.php?f=323&t=37719
            jorge2011
            thank you all for your response.
            actually, I have to do this manually is not complicated to attach the example above. But it is for the example herein below.
            because, I should intersect the mesh geometry, delete the faces and lines do not work and soften the mesh.
            and vertical or sloping sides is a bit more complicated.
            Gaieus, thanks for your advice.
            but the plugin does not work for complex forms, only creates a rectangular division and not smooth
              What exactly would you need it for?
                jorge2011
                For example, I had to make this mesh.
                so I got the idea for a plugin to create meshes from a pre-selected face
                01.skp
                  bjornkn
                  Looks pretty flat to me?
                  Anyway, here is a method that can be used with any slope, and even verticals.
                  Just rotate slicer grids as necessary, if you need the grid perpendicular to a face.
                  And add another slicer array at 45 degrees (snap it to a corner) if you need the diagonals.
                  It's actually often faster than the Move/Copy/Erase method 😄
                    kyyu
                    You might have a look at thomthom's Plan Tools: http://forums.sketchucation.com/viewtopic.php?t=30512
                    I once wrote a test plugin to crop, using a face. I later saw, thomthom had made the exact same tool. There is a youtube video showing it, in the thread.
                      jorge2011
                      bjornkn, thanks for your reply and example.
                      But I find it a complicated method.
                      kyyu
                      thank you very much. It is a very good tool, not knew.
                      I've tested this plugin and it works very well with lines, but with smooth lines not working properly.
                      Maybe I can consult to senior thomthom about this problem.
                      thank you very much for your reply
                      Sub-div.skp
                        sdmitch
                        jorge2011, Check out my "Mesh Maker.rb". I used it on part of 01.skp as a test and on the shape in Sub-div.skp. The resulting models are attached along with the plugin.
                        01.skp
                        Sub-div.skp
                        Mesh Maker.rb
                        http://sdmitch.blogspot.com/
                          jorge2011
                          oooo thank you very much. Works perfect
                          It is the first plugin I ask you very kindly and you has scheduled.
                          thank you very much again.
                          Just a suggestion:
                          • is possible add subdivision to the creation of inclined faces?
                          • is possible use the axles of a group or component? currently uses the axis the model.
                          • It is possible create the mesh of subdivision in the face inside of a group or component?
                          • is possible remember the last settings used?
                          Greetings
                            sdmitch
                            jorge2011, All things are possible but are they worth the effort to achieve them. I will consider your suggestions and try to impliment them if possible. I make no promises though.
                              jorge2011
                              Thank you very much for your response. and thanks for your time.
                                sdmitch
                                jorge2011, The attached version of Mesh Maker.rb saves the previous cell size entered and will work on tilted faces, suggestions 1 and 4.
                                Mesh Maker.rb
                                  jorge2011
                                  Thank you very much sdmitch.Works perfect
