    [Plugin] Dxf_In v2.2 20110517 Dxf2Skp
    200 Posts 41 Posters 323.1k Views 41 Watching
    • honoluludesktopH
      honoluludesktop
      Hi Corb, SUv7's "Import Dxf" is hard coded, and doesn't depend on a Ruby Plugin. Until SketchUp incorporates a higher version of Ruby, plugins will be subject to the current restrictions. It's good that you have a alternate solution. SketchUp's "import dxf" will import more entities then Dxf_In, however it may not work with Acad v2010, and higher dxf files.
      • C
        Corb
        I see.
        Again, thanks really a lot for the great and friendly support to your plugin !
        My best to you and Hawaii (I`d love to go there sooner or later).
        • honoluludesktopH
          honoluludesktop
          Corb, one of the resident genius on this forum suggested a way to accomplish using Japanese characters. I will need your help to see if I understand his suggestion, and to test it. If you are willing to work on this problem, pm me.
          • C
            Corb
            hi,
            tested your v2.1.
            Warning message appears.
            This will be useful to notify users of the language problem.
            Best !
            • honoluludesktopH
              honoluludesktop
              This is the update link for Dxf_In v2.2. Functionally it is no different from v2.0, but I have added messages regarding use of ASCII Drive\Path\File.dxf names, and ASCII Dxf files.
              • F
                franbec
                Hi, Thank you for share your valuable plugin, I downloaded today and is working fine for my needs.
                  mysterd429
                  Hi all. I'm using Mac OS X 10.6 and Sketchup 8.0.4810. When I tried using the plugin, Sketchup crashed with no explanation. From then on, it wouldn't launch, even if I removed Dxf_in_v2.d.rb from the plugins folder. I had to reinstall Sketchup. I found the 2.0 installer at http://modelisation.nancy.archi.fr/rld/plugin_details.php?id=735, but that gives me "<Error> or empty file".
                  Thanks for your work on this. Hopefully I can get it working.
                  • honoluludesktopH
                    honoluludesktop
                    mysterd429, You wrote "Dxf_in_v2.d.rb". Is that a typo? Is my understanding that Dxf_In v2.2 (the latest update found here) crashes your system, and v2.0 (the version found at http://modelisation.nancy.archi.fr/rld/....) results in a error message, correct? I do not have access to a Mac, and your help is required to identify the problem.
                    The only differences between v2.0, and v2.2 are some error messages. First that Dxf_In is for ASCII Dxf files only (Dxf_In can not read Binary Dxf files), and second that the Drive\Path\FileName.dxf must be standard ASCII characters (SketchUp Ruby will not read non-standard ASCII characters). I do not know how these error messages could cause SketchUp to crash, but if v2.0 runs without crashing, and v2.2 doesn't, I suspect the problem is with attempting to translate a binary file on the Mac.
                    For now, can you open SketchUp with Dxf_In v2.0 installed, then from SketchUp open the Ruby Console (Window > Ruby Console), then attempt to import the problem Dxf file. If you get a error message in the Ruby Console, please copy, and upload the error message here.
                    Thanks, hdt
                      mysterd429
                      Hi, hdt. Yes, the 2.d was a typo. It was supposed to be 2.2.
                      Using 2.0, I don't get anything in the Ruby console. I do get two progress bars across the bottom of the model window after choosing the DXF file, one after the other. The first is marked "Stage 1 [ 1 ]" and the second is marked "Stage 2 [ 1/1 ]".
                      So if there's anything you'd like me to try, let me know. I write software for a living, though I've never used Ruby.
                      • honoluludesktopH
                        honoluludesktop
                        mysterd429, Can you upload your Dxf file, here or pm it to me? If not, see if you can import the attached Dxf file of a box.Box00.dxf
                          mysterd429
                          I was unable to import Box00.dxf; I got the <Error> or empty file again. There was nothing in the Ruby console. The DXF file is from Illustrator; I've sent it to you by PM.
                          • honoluludesktopH
                            honoluludesktop
                            mysterd429, Thanks for the file. It contains one entity, a spline. Dxf_In doesn't support splines as the math is beyond me. Attached is a image of a SketchUp Pro's import of your file. If your drawing doesn't resemble this image, it is because SketchUp Pro's importer doesn't support the Objects in your Dxf file. Go here for a way to change Dxf splines into Dxf polylines.
                            It appears that the nature of the problem has nothing to do with v2.2. You should be able to run it on your system.
                            Get Dxf_In help from the Dxf_In Options menu to see which Acad entities are supported by Dxf_In.
                              mysterd429
                              [attachment=0:9wu3z971]<!-- ia0 -->Temp00.png<!-- ia0 -->[/attachment:9wu3z971]
                              Thank you for your help. Are there other Mac users who are able to use v2.2, or am I the only one having issues? Or am I the only person using this plugin on a Mac?
                              I'm on my lunch break at work right now, but when I get home, I'll check to see if Illustrator can export DXF v12 and try that with the 2.0 version of the plugin. If that works, I'll have a solution that works for me.
                              • honoluludesktopH
                                honoluludesktop
                                mysterd429, Yes, I know of a Mac OS 10.5 user that uses Dxf_In v2.0. If you decide to install, and run it, open the Ruby Console just in case. If you get an error message, send it to me for analysis. Aloha, hdt
                                  mysterd429
                                  Thanks for the reply, hdt. After several tries of using the 2.0 plugin with the "<Error> or empty file", I am now getting a crash on startup. It looks like it's crashing pretty badly. I opened the Mac "Console" application, which dumps out error messages, and I saw this awful mess about classes being defined in multiple places and a bunch of malloc errors. I can send this to you by PM if you'd like, but none of it seems ruby-related.
                                  I'm running MacOS 10.6 for what it's worth. Thanks again!
                                  • honoluludesktopH
                                    honoluludesktop
                                    mysterd429, It may be a Ruby related problem. First of all, make sure that you do not have multiple copies of Dxf_In installed. SketchUp loads all of the plugins at once. If a plugin "method" has the same name as another plugin's, the system may fail. If the problem is not multiple copies, pm the error message, and I will ask for help.
                                    • honoluludesktopH
                                      honoluludesktop
                                      mysterd429, Thanks for the error message, I have posted in the "Developers" section to see if anyone understands it. Dxf_In uses the Pc Registry (the MAC's 'plist') to store user preferences. One of our resident geniuses has suggested this area may be the problem.
                                      The application, Intrinsic Alchemy is identified in the first line of the error message, is it running whenever you experience a SketchUp failure?
                                      If you are interested, the discussion of the problem is here. There may be a easy way to restore your system without reinstalling SketchUp. Do you have access to the MAC's version of a PC's 'regedit', a editor for the MAC's 'plist'?
                                      A MAC user suggested that the 'plist' message minor, and that:
                                      "if someone else with 10.6 could run console starts with and without your plugin and compare those results, it will show if it's yours..."
                                      His post is here. If you can, do this before the following. Please pm the results to me.
                                      Check your pm for a version of Dxf_In with a new section/key for the MAC's 'plist'. Test it without running Intrinsic Alchemy. If OK, try running it along with Intrinsic Alchemy. Don't forget to remove all versions of Dxf_In before installing it. I Googled the error message CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary., and apparently it is associated with MACs.
                                        mysterd429
                                        I think that the crash is not related to your plugin. See my post in the other thread. I've submitted a bug report to Google.
                                          Jim
                                          I believe Intrinsic Alchemy is a graphics library/game engine used by SketchUp - it shows up in my debugger whenever I run SketchUp.
                                            Marc_Vierboom
                                            LS,
                                            I have installed (and working) the Sketchup 8 Dutch version. I have pasted the plugin ( Dxf_In_v2.2.rb ) to the directory: C:\Program Files\Google\Google SketchUp 8\Plugins
                                            Unfortunately I have no additonal dxf or dwg import line in my pull down menu File - Import (not even in the bottom of the list)
                                            Any idea what's up?
                                            Screendump from file - import
                                            • 8 / 10
