    [Plugin] Boolean helper update 08122011
    77 Posts 15 Posters 46.8k Views 15 Watching
      driven
      hi,
      had a short play last night, everything seems to work as designed... however, an interesting but 'odd' feature was the ability to independently scale anything selected.
      I had assumed it would only work on a 'scale all' basis and was checking a not-grouped object when I had only a single line selected.
      to my surprise it scaled the line and I played around modifying solids for far too long.
      I think this ability should be a separate feature or even a second tool.
      It could cause huge confusion when preparing models for printing, but is great fun for creating objects.
      I would suggest limiting Boolean Helper to 'auto select-all' and scale up/down at the pre-set's.
      and then a second plugin 'edge scaler' with a incremental slider at the tool-tip would be great.
      just my thoughts
      • liquid98L Offline
        liquid98
        Hi John,
        I see! when scaling up and down a separate line or face you get all kind of weird shapes... really fast 😮
        Edge scaler is a great idea! Maybe that will be my next project... thanx for the suggestion.
        So the plugin has to select all before scaling. Thats better indeed, I'll fix that.
        What do you think about the X message-scale-feedback?
        Nice to hear it functions on Mac, too
        Liquid
        Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
          driven
          liquid,
          the "X" factor is good... (but not the TV show)
            You don't need to 'select-all' in the code, just use model.entities.to_a as the collection of things to transform in the scale up/down - that way everything gets caught in the scaling up/down changes.
            A screen-note wouldbe useful to remind you that you have scaled... then the code can erase it when you've scaled down...
              d12dozr
              👍 I like where this is going!
              http://goo.gl/f7ooYh
              • liquid98L Offline
                liquid98
                @ TIG
                yeah, "select all" is user language.
                model.entities.to_a = programmers language 😉
                • liquid98L Offline
                  liquid98
                  Working on the feedback of the scale action (X = one time scaled up XX =two times etc.)
                  I have some variable (array) filled with X characters. Its called $xfeedback
                  To put it on screen I use:
                  @xnote = model.add_note $xfeedback.to_s, 0.01, 0.02.
                  That works. But to update it I would like to delete the screen-note entity before showing it again like this:
                  model = Sketchup.active_model entities = model.active_entities entities.erase_entities(@xnote) if @xnote
                  I know to delete something with erase_entities it has to be an array. So I tried also this:
                  entities.erase_entities(@xnote.to_a) if @xnote
                  but it's not working.
                  Code structure is like this:
                  <span class="syntaxdefault"><br />require </span><span class="syntaxstring">'sketchup.rb'<br /><br /></span><span class="syntaxdefault">$xfeedback </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">[</span><span class="syntaxstring">"X"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"X"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"X"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"X"</span><span class="syntaxkeyword">]</span><span class="syntaxdefault">  </span><span class="syntaxcomment"># Test situation presuming 4 times scaled up.<br /><br /></span><span class="syntaxdefault">module Test<br /><br />class Scaledown<br />    <br /><br />def initialize</span><span class="syntaxkeyword">()</span><span class="syntaxdefault"> <br />         </span><span class="syntaxcomment"># Scaling action<br /></span><span class="syntaxdefault">         <br />     model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />     entities </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />     if entities</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">!=</span><span class="syntaxdefault"> nil<br />    <br />    l </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> $xfeedback</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_i </span><span class="syntaxkeyword">-</span><span class="syntaxdefault"> 1  <br />    $xfeedback</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">delete_at</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">l</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    <br />     model </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />    entities </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities<br />    entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">erase_entities</span><span class="syntaxkeyword">(@</span><span class="syntaxdefault">xnote</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> if </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">xnote<br /><br />    </span><span class="syntaxkeyword">@</span><span class="syntaxdefault">xnote </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_note $xfeedback</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">to_s</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 0.01</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 0.02<br /><br /><br /><br />    else <br />    nil<br />    end</span><span class="syntaxcomment">#if<br /><br /><br /><br /><br /><br /><br /></span><span class="syntaxdefault">end</span><span class="syntaxcomment">#def<br /></span><span class="syntaxdefault">end</span><span class="syntaxcomment">#class<br /></span><span class="syntaxdefault">end</span><span class="syntaxcomment">#module             &nbsp;</span><span class="syntaxdefault"></span>
                  Please help
                    Shouldn't it be @@xnote ?
                    Anyway, something like...
                    should work... or use [@xnote] to make it an array, if it MUST be one (?)...
                    However, this will work too
                    @xnote.text='newtext'
                    to change it ???
                      driven
                      may not be of any help, but
                      when you create a screen note SU creates a new Text entity (each time)
                      "#Sketchup::Text:0x1ef0a000", "#Sketchup::Text:0x1f0131a4", etc...
                      so I guess if you capture those you can delete them.
                      • liquid98L Offline
                        liquid98
                        Hello friends,
                        I made some improvements to the boolean-helper plugin:
                        • it scales everything in the model
                        • it gives feedback on the total scale-factor
                        • it auto zooms to the model-extents.
                        But I need some help:
                        When the model is scaled up, feedback is generated in the form of a sketchup::text
                        entity. My problem: when the the model is deleted (not select all), the text entity remains on the screen ( entities[0]) while there is no model.
                        So I have to monitor that.
                        How do I do that??
                        I came up with this solution:
                        <span class="syntaxdefault">if  entities</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">class </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Text </span><span class="syntaxkeyword">&&</span><span class="syntaxdefault"> entities</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">]</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> nil<br />         </span><span class="syntaxkeyword">@@</span><span class="syntaxdefault">xnote </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> entities</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">         </span><span class="syntaxkeyword">@@</span><span class="syntaxdefault">notetext </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxstring">"   "<br /></span><span class="syntaxdefault">         </span><span class="syntaxkeyword">@@</span><span class="syntaxdefault">xnote </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_note </span><span class="syntaxkeyword">@@</span><span class="syntaxdefault">notetext</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 0.01</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> 0.99</span>
                        But if I put this code in booleanhelper.rb it only runs when the user invokes it.
                        While it has to run all the time.
                        I've also read something about Sketchup::EntityObserver. Is that relevant in this case???
                        Thnx for your help
                        • mitcorbM Offline
                          mitcorb
                          Well, for those who work in Imperial units==inches, it would be cool if you could set the scale factor to overcome the small faces problem but type in the VCB the same numbers as you would if you had not scaled it. Basically, to do away with a bunch of mental math for every value. When finished, reset the scale factor to 1. There's a flaw here somewhere??
                          • liquid98L Offline
                            liquid98
                            Hi mitcorb,
                            That's a nice idea, but I have no clue to achieve it..
                            Indeed, the script I'm working on scales up as much as you want and than scales everything down to scalefactor 1.
                            In scaled up state there's a screen-note reference to the actual scale-factor.
                              Liquid98
                              About the screen-text...
                              Do you mean that it disappears if there is suddenly no other model geometry ?
                              As soon as any new geometry is added it should reappear ??
                              I don't see the problem ? On the rare occasions when the user has deleted the entire model [and why would they do that?] the scaling becomes irrelevant anyway, so they can just delete it ?
                              To spot if the only thing left is your screen-text and then erase with an observer to watch for this use
                              class OnlyScreenTextLeftEntitiesObserver < Sketchup;;EntitiesObserver
                                def onEraseEntities(entities)
                                  return if entities[1]
                                  entities[0].erase! if entities[0].class==Sketchup;;Text and entities[0].text==$xfeedback.to_s ###??
                              # Attach the observer - do this once at startup
                              Sketchup.active_model.entities.add_observer(OnlyScreenTextLeftEntitiesObserver.new)
                              • liquid98L Offline
                                liquid98
                                Hi TIG,
                                I admit, that situation won't occur very often. But I only want to tackle it to learn new stuff... 😛
                                When I put your code in a .rb file, like this:
                                <span class="syntaxdefault">    require </span><span class="syntaxstring">'sketchup.rb'<br /><br /></span><span class="syntaxdefault">    class OnlyScreenTextLeftEntitiesObserver </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">EntitiesObserver<br />      def onEraseEntities</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox </span><span class="syntaxstring">"OK"<br /></span><span class="syntaxdefault">     end<br />    end<br />  <br />   <br />    Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">OnlyScreenTextLeftEntitiesObserver</span><span class="syntaxkeyword">.new)</span><span class="syntaxdefault"> </span>
                                and then start sketchup, create some entities and delete them,
                                Nothing happens... Why??
                                  Well if it did work every time you erased something you'd get the messagebox...
                                  The EntitesObserver is known to be buggy... if we did get it to work and erased an entity within it it'd probably crash anyway - so my snippet probably wasn't the best idea 😒
                                  How about using a selectionObserver...onBulkChange() - you select the things and then erase them and the selection changes... and then looking at model.entities if no [1] and [0] meets test erase it ...
                                  http://code.google.com/apis/sketchup/docs/ourdoc/selectionobserver.html
                                  • liquid98L Offline
                                    liquid98
                                    I updated the booleanhelper plugin! Please see the first post of this topic.
                                      driven
                                      hi,
                                      I believe I just exposed a bug, doing another testhttp://forums.sketchucation.com/viewtopic.php?f=180&t=38858&p=354541#p354541
                                      when I have 'auto paint tool' Mac preference set, your twee tekst and LEEEEEG message boxes pop up every time I select or delete something even though I wasn't using your tool.
                                      appears to be "Sketchup::SelectionObserver" related.
                                      I'd rather use this then that, but I'd like the option of both...
                                      cheers
                                      • liquid98L Offline
                                        liquid98
                                        Hi John,
                                        Just download and install latest version -see first post of this topic.
                                        Good luck!
                                          driven
                                          cheers,
                                          I'll let you know if I have any issues,,,
                                            CT4
                                            Thank you Thank you Thank you. I model small parts for RC aircraft and run into so many problems when I try and lathe them or intersect them. This fixes all of the problems.
                                            • 3 / 4
